UC540 SSL VPN
johnhsnow
Hi guys,
i have been looking at Ciscos documentation on SSL VPN but cant seem to find if this can be configured on the UC540 and does it require a license?
Thanks in advance.
6 Replies 6
jtreister
Need SPA525G2 for remote phone (it is only phone that supports it). Need port 443 open to UC.
Configure phones at main office then ship out:
Connect SPA525G2 to UC
Use  CCA: Home - Phone VPN SETUP Wizard.
It will be ready to connect from anywhere.
trgood
Hi John,
SSL VPN can be configred on the UC500.  I don't believe it requires a license but I think you can have 8 active users.
If you're trying to configure it you can do this by going through CCA to Configure > Security > SSL VPN.
For better documentation go to this link(page 261):
http://www.cisco.com/en/US/docs/net_mgmt/cisco_configuration_assistant/version3_2_1/administration_guide/cca_sbcs_admin_guide.pdf
Let me know if you have any questions.
-Trent Good
-Trent Good ** Please rate useful posts! **
I got a document from Cisco which outlines everything.
No license is required and its max 10 VPN connections SSL IPSEC etc
I will post the link soon for reference in the community.
Here is the link to the VPN information:
Table 5 - indicates 10 licences for VPN - includes SSL, IPSEC and GRE.
http://www.cisco.com/en/US/prod/collateral/voicesw/ps6788/vcallcon/ps7293/C78-557768-00_540_platform_reference_guide_DS_v2a.pdf
Are you able to terminate the VPN on a Cisco ASA where the UC device is sitting behind it and use the SPA525G?
Yes, you should be able to.
This may be of help to you:
https://supportforums.cisco.com/thread/2024749
