UC540W Dial Plans
Safar Safarov
I'm going to purchase a UC device soon and would like to know if I can create/change manually dial plans on UC540W-FXO-K9?
I would like to customize it for Azerbaijan dialing rules.
Safar.
paolo bevilacqua
With manual configuration, you can do whatever you want.
6 Replies 6
paolo bevilacqua
Great! Thanks a lot
Thanks for the nice rating and good luck!
silvia.candela
I´m from Perú and I´m about to purchase an UC540W, since there isn´t an specific dial plan for my country, I would like to know if I can modify one of the availables or I how to define a new one??
Hi Silvia,
as far as I know you would be able to create a dial plan manually via CLI.
BR,
Safar.
Hello All,
Dial plans can be customized in the UC500 series. This is also supported within CCA.
-john
