Community Member
UC560 and SBS2003 webmail and remote workplace functionality stopped
I have recently installed  a UC560 in a simple SBS environment and when my users go to http://webmail.theirdomain.com or remote.theirdomain.com it brings them to the SSL VPN login page.  How do I change it so they get to their webmail or remote workplace sign on page again? The network goes:
ISP->UC560->ESW540 splits phones(spa525) and data.  One site to site vpn but no SSL VPN sign ons needed.  I do not want to change the default port settings on the SBS for webmail etc. as we were sold on the idea that the UC integrates seamlessly into a SBS environment.
Thanks in advance
Everyone's tags (3)
1 REPLY
VIP Purple
Re: UC560 and SBS2003 webmail and remote workplace functionality
If you're familiar with CLI, you will basically need a static NAT and an ACL to allow the traffic such as:
1.1.1.1 = Inside IP address
2.2.2.2 = Outside IP address
ip nat inside source static tcp 1.1.1.1 80 2.2.2.2 80
access-list 104 permit tcp any host 2.2.2.2 eq 80
interface FastEthernet0/0
ip access-group 104 in
Obviously, the above configuration is not exhaustive, but these are the basics you need to make this work.
I'm fairly certain you can do the same thing using CCA. I believe it's under Configure > Security > NAT. Take a look at the administrator's guide here:
http://www.cisco.com/en/US/docs/net_mgmt/cisco_configuration_assistant/version3_0/administration_guide/cca_30_sbcs_admin_guide.pdf
Hope this helps.
Brandon
387
