Users might experience few discrepancies in Search results. We are working on this on our side. We apologize for the inconvenience it may have caused.
UC560 at main site & SR520 + APs at remote
We have a client who wants to have the following setup-
UC560 at main site
SR520 & 3 APs at remote site with company & guest WLAN access
Would you recommend a WLAN controller at the remote site with light APs or 3 standalone APs?
I have not had an opportunity to setup a WLAN controller behind a SR.  Do the two devices work well together?
1 REPLY
Re: UC560 at main site & SR520 + APs at remote
This solution should work fine. You will need to create another VLAN at the remote site for the guest network and use lighweight APs. Autonomous APs will not register with a WLC.
Keep in mind that you won't be able to do a complete configuration with CCA as the WLC/LAP products are not designed to be managed by CCA.
Cole
268
