Community Member
UC560 Backup and Restore
I have a new RMA UC560 version 8.0.2
I have a backup from UC560 version 8.0.1
I did a restore to the new UC560 some functions do not work.
I can not communicate with the unit.  The DHCP is not working and when I configured my PC as static 192.168.10.x ; when I ping I get "Destination net unreachable"
I do have CLI through the serial port.
Any suggestions?
Everyone's tags (2)
Community Member
Re: UC560 Backup and Restore
I tried upgrading my IOS without moving to default and it caused an angry mess of nonsense. I then reinstalled to factory default and ran everything through the wizard and reconfigured. There was nothing I could do to get the old config to work. As of this moment Im going to move it back so I can move forward, due to the fact that even with a fresh start this OS won't take my config through CCA to allow me to use the BACD scripts. My thoughts are that it's a bummer of an OS. I'd get your OS from the download site at I was looking for the 8.0.1 from this site as well and thought it was what I should run with, but I'm going to move back to get things going.
I'd love to know if you get yours working though
Community Member
I loaded 8.0.1
I Loaded IOS 15.0(1)XA2
I restored and there are problems
The main problem is that the network is down. I can not communicate with the unit through the network I can connect using the RS232 serial connection. Please help
I wonder if it's as simple as a  no shutdown on the vlan or physical interface ?
