07-07-2011 11:45 AM - edited 03-21-2019 04:19 AM
Hi all,
I currently have a UC560 running 8.1 with SPA525G Phones attached. Every few weeks, I will get reports that the system has crashed. The phones will show connecting... and the console port will not connect. I basically have to pull the power and reboot the system. I have attached my running config. Any help would be appreciated.
login as: admin
Cisco Configuration Assistant. Version: 2.2 (6). Wed Dec 01 17:15:37 EST 2010Using keyboard-interactive authentication.
Password:
UC560#show run
Building configuration...
Current configuration : 48613 bytes
! Last configuration change at 14:15:05 EDT Thu Jul 7 2011
version 15.1
parser config cache interface
no service pad
service timestamps debug datetime msec localtime
service timestamps log datetime msec localtime
service internal
service compress-config
service sequence-numbers
hostname UC560
boot-start-marker
boot system flash uc500-advipservicesk9-mz.151-2.T2
boot system flash flash:/uc500-advipservicesk9-mz.150-1.XA3a
boot-end-marker
no logging queue-limit
logging buffered 3000000
no logging rate-limit
no logging console
no logging monitor
enable secret 5 $1$Bp/.$85XyCt54vD51NMiJRLxgz0
aaa new-model
aaa authentication login default local
aaa authentication login sdm_vpn_xauth_ml_1 local
aaa authorization exec default local
aaa session-id common
clock timezone EST -5 0
clock summer-time EDT recurring
crypto pki trustpoint TP-self-signed-1774138792
enrollment selfsigned
subject-name cn=IOS-Self-Signed-Certificate-1774138792
revocation-check none
crypto pki certificate chain TP-self-signed-1774138792
certificate self-signed 02
3082024F 308201B8 A0030201 02020102 300D0609 2A864886 F70D0101 04050030
31312F30 2D060355 04031326 494F532D 53656C66 2D536967 6E65642D 43657274
69666963 6174652D 31373734 31333837 3932301E 170D3131 30313232 31363037
33365A17 0D323030 31303130 30303030 305A3031 312F302D 06035504 03132649
4F532D53 656C662D 5369676E 65642D43 65727469 66696361 74652D31 37373431
33383739 3230819F 300D0609 2A864886 F70D0101 01050003 818D0030 81890281
8100C4B4 8A5FD988 22F2CE6B D8ACEE39 1F2B0056 75EA1686 5D7FB796 E745A8E9
BA1D688F 4732BA27 5C2E21B7 D8F9A88B E4C98979 18A46979 833689C6 9AAB2FAE
7D62DF9F 63B58D9A 41223867 C8F35819 9D93A03C 4990BBD3 7EA420D8 BBC73878
679B3BB6 C5F4E066 71A9098C 6E62204E F802C9B4 5C320850 BAF959CD 248C1BDF
48C90203 010001A3 77307530 0F060355 1D130101 FF040530 030101FF 30220603
551D1104 1B301982 17554335 36302E61 70696370 732E6F6E 766F6970 2E6E6574
301F0603 551D2304 18301680 14DBEC32 2A7C22A4 99329E2A D6163D82 1E42694A
D5301D06 03551D0E 04160414 DBEC322A 7C22A499 329E2AD6 163D821E 42694AD5
300D0609 2A864886 F70D0101 04050003 81810080 6825C136 8BF2ED06 935CB3B0
6143A131 AE145F3A A0F9F1FA 1277D71C 697BEB04 84611EF2 7A70DC3E C9CFDA1A
6F11E396 FABA90A9 0B8D874D F26613DE 0460B3C7 FB58AD50 89FFC9CD C421B484
36644C5D 5CDBEECA A1C66C13 3CB6F004 E55B8684 3BA9F18C 28D40BB4 98B24ED7
E306353A 0B1B1D13 EECB833E D29FCBAE A222C4
quit
dot11 syslog
ip source-route
no ip cef
ip dhcp relay information trust-all
ip dhcp excluded-address 10.1.1.1 10.1.1.9
ip dhcp excluded-address 10.1.1.241 10.1.1.255
ip dhcp excluded-address 192.168.20.46 192.168.20.249
ip dhcp excluded-address 192.168.20.254 192.168.20.255
ip dhcp excluded-address 10.1.1.1 10.1.1.10
ip dhcp pool phone
network 10.1.1.0 255.255.255.0
default-router 10.1.1.1
option 150 ip 10.1.1.1
lease infinite
ip domain name apicps.onvoip.net
ip name-server 4.2.2.2
ip name-server 8.8.4.4
ip name-server 8.8.8.8
ip inspect WAAS flush-timeout 10
no ipv6 cef
stcapp ccm-group 1
stcapp
stcapp feature access-code
meetme-conference **9
stcapp supplementary-services
port 0/0/0
fallback-dn 1050
port 0/0/1
fallback-dn 302
port 0/0/2
fallback-dn 304
port 0/0/3
fallback-dn 303
trunk group ALL_FXO
max-retry 5
voice-class cause-code 1
hunt-scheme longest-idle
voice call send-alert
voice rtp send-recv
voice service voip
ip address trusted list
ipv4 0.0.0.0 0.0.0.0
allow-connections h323 to sip
allow-connections sip to h323
allow-connections sip to sip
supplementary-service h450.12
no supplementary-service sip moved-temporarily
no supplementary-service sip refer
sip
registrar server expires max 3600 min 3600
localhost dns:apicps.onvoip.net
voice class codec 1
codec preference 1 g711ulaw
voice class sip-profiles 1000
request ANY sdp-header Connection-Info remove
response ANY sdp-header Connection-Info remove
voice class sip-profiles 2
request INVITE sip-header Allow-Events modify "REFER" ""
request INVITE sip-header Allow-Header modify "REFER" ""
response 200 sip-header Allow-Header modify "REFER" ""
response 200 sdp-header Audio-Attribute remove
voice class cause-code 1
no-circuit
voice iec syslog
voice register global
voice translation-rule 4
rule 1 /3524321619/ /3098/
voice translation-rule 5
rule 1 /3524321620/ /3098/
rule 2 /3524321621/ /3098/
rule 3 /3524321622/ /3098/
rule 4 /3524321623/ /3098/
rule 5 /3524321624/ /3098/
rule 6 /3524321625/ /3098/
rule 7 /3524321626/ /3098/
rule 8 /3524321627/ /3098/
rule 9 /3524321628/ /3098/
rule 15 /.*/ /3098/
voice translation-rule 6
voice translation-rule 410
rule 1 /^9\(.*\)/ /\1/
rule 2 /^9\(.*\)/ /\1/
voice translation-rule 411
rule 1 /^9\(.*\)/ /ABCD9\1/
rule 2 /^9\(.*\)/ /ABCD9\1/
voice translation-rule 412
rule 1 /^ABCD\(.*\)/ /\1/
voice translation-rule 1000
rule 1 /.*/ //
voice translation-rule 1111
rule 15 /^....$/ /3524321620/
voice translation-rule 1112
rule 1 /^9/ //
voice translation-rule 1234
rule 1 /.*/ /1019/
voice translation-rule 2001
voice translation-rule 2002
rule 1 /^6/ //
voice translation-rule 2222
rule 1 /^91900......./ //
rule 2 /^91976......./ //
voice translation-profile AA_Profile
translate called 2001
voice translation-profile ADSCORPAA-AA_Called_5
translate called 5
voice translation-profile CALLER_ID_TRANSLATION_PROFILE
translate calling 1111
voice translation-profile CallBlocking
translate called 2222
voice translation-profile INN!
voice translation-profile INN1
translate called 1234
voice translation-profile IOD-AA_Called_5
translate called 5
voice translation-profile Incoming-AA_Called_4
translate called 4
voice translation-profile Incoming-AA_Called_6
translate called 6
voice translation-profile OUTGOING_TRANSLATION_PROFILE
translate called 1112
voice translation-profile PSTN_CallForwarding
translate redirect-target 410
translate redirect-called 410
voice translation-profile PSTN_Outgoing
voice translation-profile SIP_Incoming
translate called 411
voice translation-profile SIP_Passthrough
translate called 412
voice translation-profile XFER_TO_VM_PROFILE
translate redirect-called 2002
voice translation-profile nondialable
translate called 1000
voice-card 0
dspfarm
dsp services dspfarm
fax receive called-subscriber $d$
fax interface-type fax-mail
mta send server 10.1.10.1 port 25
mta send with-subject both
mta send mail-from hostname adsimaging.com
mta send mail-from username fax
mta receive aliases 10.1.10.2
mta receive maximum-recipients 7
application
service cca_fax_detection flash:/applications/faxmail/app_fax_detect.2.1.2.2.tcl
param fax-dtmf 2
param mode listen-first
param voice-dtmf 1
param prompt flash:/applications/faxmail/en_listen_first.au
service onramp flash:/bacdprompts/app_faxmail_onramp.2.0.1.3.tcl
service cca_offramp flash:/applications/faxmail/app_faxmail_offramp.2.0.1.1.tcl
service cca_onramp flash:/applications/faxmail/app_faxmail_onramp.2.0.1.3.tcl
license udi pid UC560-FXO-K9 sn FHK1419F2G1
archive
log config
logging enable
logging size 600
hidekeys
username admin privilege 15 secret 5 $1$6abA$TtVA57tP8piWZXQa.JnrA0
username psouliere password 0 ""
username dhargroves secret 5 $1$uoEp$kWTg.CTjuFcVKBGZvt/I71
username tcoleman secret 5 $1$NzLH$.ekuVH5qVpl3IxZBetD4J/
ip ftp username cisco
ip ftp password cisco
ip tftp source-interface Vlan1
class-map match-any media
match dscp ef
class-map match-any signaling
match dscp cs3
match dscp af31
policy-map queue
class signaling
bandwidth percent 5
class media
priority percent 40
class class-default
fair-queue
policy-map shape
class class-default
shape average 4500000
service-policy queue
interface Loopback0
ip address 50.50.50.50 255.255.255.0
ip nat inside
ip virtual-reassembly in
interface Loopback1
ip address 51.51.51.51 255.255.255.0
ip nat inside
interface Loopback2
ip address 52.52.52.52 255.255.255.0
ip nat inside
interface Loopback3
ip address 53.53.53.53 255.255.255.0
ip nat inside
interface Loopback4
ip address 54.54.54.54 255.255.255.0
ip nat inside
interface Loopback5
ip address 55.55.55.55 255.255.255.0
ip nat inside
interface Loopback6
ip address 56.56.56.56 255.255.255.0
ip nat inside
interface Loopback7
ip address 57.57.57.57 255.255.255.0
ip nat inside
interface Loopback8
ip address 58.58.58.58 255.255.255.0
ip nat inside
interface GigabitEthernet0/0
bandwidth 4500
ip address 10.10.10.2 255.255.255.0
ip flow ingress
ip nat outside
load-interval 30
duplex auto
speed 100
service-policy output shape
interface Integrated-Service-Engine0/0
description Interface used to manage integrated application modulecue is initialized with default IMAP group
ip unnumbered Vlan90
ip nat inside
service-module ip address 10.1.10.1 255.255.255.252
service-module ip default-gateway 10.1.10.2
interface GigabitEthernet0/1/0
switchport voice vlan 100
macro description cisco-phone | cisco-phone
spanning-tree portfast
interface GigabitEthernet0/1/1
switchport mode trunk
macro description cisco-switch | cisco-switch
interface GigabitEthernet0/1/2
macro description cisco-desktop | cisco-desktop
interface GigabitEthernet0/1/3
description Interface used to communicate with integrated service module
switchport access vlan 90
interface Virtual-Template1 type serial
ip unnumbered Loopback0
ip nat inside
interface Virtual-Template2 type serial
ip unnumbered Loopback1
ip nat inside
interface Virtual-Template3 type serial
ip unnumbered Loopback2
ip nat inside
interface Virtual-Template4 type serial
ip unnumbered Loopback3
ip nat inside
interface Virtual-Template5 type serial
ip unnumbered Loopback4
ip nat inside
interface Virtual-Template6 type serial
ip unnumbered Loopback5
ip nat inside
interface Virtual-Template7 type serial
ip unnumbered Loopback6
ip nat inside
interface Virtual-Template8 type serial
ip unnumbered Loopback7
ip nat inside
interface Virtual-Template9 type serial
ip unnumbered Loopback8
ip nat inside
interface Vlan1
ip address 192.168.20.46 255.255.255.0
ip nat inside
interface Vlan90
ip address 10.1.10.2 255.255.255.252
ip nat inside
interface Vlan100
ip address 10.1.1.1 255.255.255.0
ip nat inside
interface Vlan101
ip address 192.168.2.46 255.255.255.0
ip nat inside
ip local pool SDM_WEBVPN_POOL_1 10.1.1.220 10.1.1.222
ip forward-protocol nd
ip flow-cache timeout active 1
ip flow-export source GigabitEthernet0/0
ip flow-export version 5
ip flow-export destination 192.168.20.14 2055
ip http server
ip http authentication local
ip http secure-server
ip http path flash:/gui
ip dns server
ip nat inside source static tcp 192.168.20.46 80 interface GigabitEthernet0/0 80
ip nat inside source route-map SDM_RMAP_1 interface GigabitEthernet0/0 overload
ip route 0.0.0.0 0.0.0.0 10.10.10.1
ip route 10.1.1.0 255.255.255.0 Vlan100
ip route 10.1.10.1 255.255.255.255 Vlan90
ip route 192.168.2.0 255.255.255.0 192.168.20.1
ip route 192.168.2.0 255.255.255.0 192.168.2.1
ip route 192.168.20.0 255.255.255.0 192.168.20.1
logging esm config
access-list 1 remark SDM_ACL Category=2
access-list 1 permit 10.1.1.0 0.0.0.255
access-list 1 permit 192.168.20.0 0.0.0.255
access-list 1 permit 10.1.10.0 0.0.0.3
access-list 2 remark CCA_SIP_SOURCE_GROUP_ACL_INTERNAL
access-list 2 remark SDM_ACL Category=1
access-list 2 permit 192.168.20.46
access-list 2 permit 192.168.20.0 0.0.0.255
access-list 2 permit 10.1.1.0 0.0.0.255
access-list 2 permit 10.1.10.0 0.0.0.3
access-list 3 permit 10.10.10.1
access-list 3 remark CCA_SIP_SOURCE_GROUP_ACL_EXTERNAL
access-list 3 remark SDM_ACL Category=1
access-list 3 permit x.x.x.x
access-list 3 deny any
access-list 4 remark CCA_SIP_SOURCE_GROUP_ACL_INTERNAL
access-list 4 remark SDM_ACL Category=1
access-list 4 permit 192.168.20.46
access-list 4 permit 192.168.20.0 0.0.0.255
access-list 4 permit 10.1.1.0 0.0.0.255
access-list 4 permit 10.1.10.0 0.0.0.3
access-list 5 remark CCA_SIP_SOURCE_GROUP_ACL_EXTERNAL
access-list 5 remark SDM_ACL Category=1
access-list 5 permit x.x.x.x
access-list 5 deny any
access-list 100 remark SDM_ACL Category=2
access-list 100 deny ip any host 10.1.1.220
access-list 100 deny ip any host 10.1.1.221
access-list 100 deny ip any host 10.1.1.222
access-list 100 permit ip 52.52.52.0 0.0.0.255 any
access-list 100 permit ip 56.56.56.0 0.0.0.255 any
access-list 100 permit ip 51.51.51.0 0.0.0.255 any
access-list 100 permit ip 55.55.55.0 0.0.0.255 any
access-list 100 permit ip 50.50.50.0 0.0.0.255 any
access-list 100 permit ip 54.54.54.0 0.0.0.255 any
access-list 100 permit ip 53.53.53.0 0.0.0.255 any
access-list 100 permit ip 192.168.20.0 0.0.0.255 any
access-list 100 permit ip 192.168.2.0 0.0.0.255 any
access-list 100 permit ip 10.1.1.0 0.0.0.255 any
access-list 100 permit ip 10.1.10.0 0.0.0.3 any
access-list 100 permit ip 57.57.57.0 0.0.0.255 any
route-map SDM_RMAP_1 permit 1
match ip address 100
snmp-server community public RO
snmp-server ifindex persist
tftp-server flash:/phones/521_524/cp524g-8-1-17.bin alias cp524g-8-1-17.bin
tftp-server flash:/ringtones/Analog1.raw alias Analog1.raw
tftp-server flash:/ringtones/Analog2.raw alias Analog2.raw
tftp-server flash:/ringtones/AreYouThere.raw alias AreYouThere.raw
tftp-server flash:/ringtones/DistinctiveRingList.xml alias DistinctiveRingList.xml
tftp-server flash:/ringtones/RingList.xml alias RingList.xml
tftp-server flash:/ringtones/AreYouThereF.raw alias AreYouThereF.raw
tftp-server flash:/ringtones/Bass.raw alias Bass.raw
tftp-server flash:/ringtones/CallBack.raw alias CallBack.raw
tftp-server flash:/ringtones/Chime.raw alias Chime.raw
tftp-server flash:/ringtones/Classic1.raw alias Classic1.raw
tftp-server flash:/ringtones/Classic2.raw alias Classic2.raw
tftp-server flash:/ringtones/ClockShop.raw alias ClockShop.raw
tftp-server flash:/ringtones/Drums1.raw alias Drums1.raw
tftp-server flash:/ringtones/Drums2.raw alias Drums2.raw
tftp-server flash:/ringtones/FilmScore.raw alias FilmScore.raw
tftp-server flash:/ringtones/HarpSynth.raw alias HarpSynth.raw
tftp-server flash:/ringtones/Jamaica.raw alias Jamaica.raw
tftp-server flash:/ringtones/KotoEffect.raw alias KotoEffect.raw
tftp-server flash:/ringtones/MusicBox.raw alias MusicBox.raw
tftp-server flash:/ringtones/Piano1.raw alias Piano1.raw
tftp-server flash:/ringtones/Piano2.raw alias Piano2.raw
tftp-server flash:/ringtones/Pop.raw alias Pop.raw
tftp-server flash:/ringtones/Pulse1.raw alias Pulse1.raw
tftp-server flash:/ringtones/Ring1.raw alias Ring1.raw
tftp-server flash:/ringtones/Ring2.raw alias Ring2.raw
tftp-server flash:/ringtones/Ring3.raw alias Ring3.raw
tftp-server flash:/ringtones/Ring4.raw alias Ring4.raw
tftp-server flash:/ringtones/Ring5.raw alias Ring5.raw
tftp-server flash:/ringtones/Ring6.raw alias Ring6.raw
tftp-server flash:/ringtones/Ring7.raw alias Ring7.raw
tftp-server flash:/ringtones/Sax1.raw alias Sax1.raw
tftp-server flash:/ringtones/Sax2.raw alias Sax2.raw
tftp-server flash:/ringtones/Vibe.raw alias Vibe.raw
tftp-server flash:/Desktops/CampusNight.png
tftp-server flash:/Desktops/TN-CampusNight.png
tftp-server flash:/Desktops/CiscoFountain.png
tftp-server flash:/Desktops/TN-CiscoFountain.png
tftp-server flash:/Desktops/CiscoLogo.png
tftp-server flash:/Desktops/TN-CiscoLogo.png
tftp-server flash:/Desktops/Fountain.png
tftp-server flash:/Desktops/TN-Fountain.png
tftp-server flash:/Desktops/MorroRock.png
tftp-server flash:/Desktops/TN-MorroRock.png
tftp-server flash:/Desktops/NantucketFlowers.png
tftp-server flash:/Desktops/TN-NantucketFlowers.png
tftp-server flash:Desktops/320x212x16/List.xml
tftp-server flash:/bacdprompts/en_bacd_allagentsbusy.au alias en_bacd_allagentsbusy.au
tftp-server flash:/bacdprompts/en_bacd_disconnect.au alias en_bacd_disconnect.au
tftp-server flash:/bacdprompts/en_bacd_enter_dest.au alias en_bacd_enter_dest.au
tftp-server flash:/bacdprompts/en_bacd_invalidoption.au alias en_bacd_invalidoption.au
tftp-server flash:/bacdprompts/en_bacd_music_on_hold.au alias en_bacd_music_on_hold.au
tftp-server flash:/bacdprompts/en_bacd_options_menu.au alias en_bacd_options_menu.au
tftp-server flash:/bacdprompts/en_bacd_welcome.au alias en_bacd_welcome.au
tftp-server flash:/bacdprompts/en_bacd_xferto_operator.au alias en_bacd_xferto_operator.au
tftp-server flash:/bacdprompts/app-b-acd-3.0.0.2.tcl alias app-b-acd-3.0.0.2.tcl
tftp-server flash:/bacdprompts/app-b-acd-aa-3.0.0.2.tcl alias app-b-acd-aa-3.0.0.2.tcl
tftp-server 192.168.20.10
tftp-server flash:/bacdprompts/app_faxmail_onramp.2.0.1.3.tcl
tftp-server 192.168.20.46
tftp-server flash:/phones/525/spa525g-7-4-4.bin alias spa525g-7-4-4.bin
tftp-server flash:/spa525g-7-4-6-E03.bin alias spa525g-7-4-6-E03.BIN
tftp-server flash:/phones/525/spa525g-7-4-7.bin alias spa525g-7-4-7.bin
tftp-server flash:/phones/525/spa525g-7-4-8.bin alias spa525g-7-4-8.bin
control-plane
voice-port 0/0/0
station-id number 1050
caller-id enable
voice-port 0/0/1
station-id name OnRamp
caller-id enable
voice-port 0/0/2
timeouts ringing infinity
shutdown
station-id number 2002
caller-id enable
voice-port 0/0/3
shutdown
station-id number 2003
caller-id enable
voice-port 0/1/0
trunk-group ALL_FXO 64
connection plar opx 61013
description Configured by CCA 4FXO-0/1/0_T37-OP
caller-id enable
voice-port 0/1/1
connection plar 202
shutdown
description Configured by CCA 4 FXO-0/1/1-AA
caller-id enable
voice-port 0/1/2
connection plar 203
shutdown
description Configured by CCA 4 FXO-0/1/2-AA
caller-id enable
voice-port 0/1/3
connection plar 204
shutdown
description Configured by CCA 4 FXO-0/1/3-AA
caller-id enable
voice-port 0/4/0
auto-cut-through
signal immediate
input gain auto-control -15
description Music On Hold Port
sccp local Vlan90
sccp ccm 10.1.1.1 identifier 1 version 4.0
sccp
sccp ccm group 1
associate ccm 1 priority 1
dial-peer cor custom
name internal
name local
name local-plus
name international
name national
name national-plus
name emergency
name toll-free
dial-peer cor list call-internal
member internal
dial-peer cor list call-local
member local
dial-peer cor list call-local-plus
member local-plus
dial-peer cor list call-national
member national
dial-peer cor list call-national-plus
member national-plus
dial-peer cor list call-international
member international
dial-peer cor list call-emergency
member emergency
dial-peer cor list call-toll-free
member toll-free
dial-peer cor list user-internal
member internal
member emergency
dial-peer cor list user-local
member internal
member local
member emergency
member toll-free
dial-peer cor list user-local-plus
member internal
member local
member local-plus
member emergency
member toll-free
dial-peer cor list user-national
member internal
member local
member local-plus
member national
member emergency
member toll-free
dial-peer cor list user-national-plus
member internal
member local
member local-plus
member national
member emergency
member toll-free
dial-peer cor list user-international
member internal
member local
member local-plus
member national
member emergency
member toll-free
dial-peer voice 1 pots
destination-pattern 1050
port 0/0/0
no sip-register
dial-peer voice 2 pots
description ** CCA Analog Fax **
port 0/0/1
no sip-register
dial-peer voice 3 pots
service stcapp
port 0/0/2
no sip-register
dial-peer voice 4 pots
service stcapp
port 0/0/3
no sip-register
dial-peer voice 5 pots
description ** MOH Port **
destination-pattern ABC
port 0/4/0
no sip-register
dial-peer voice 50 pots
description ** incoming dial peer **
incoming called-number ^AAAA$
port 0/1/0
dial-peer voice 51 pots
port 0/1/1
dial-peer voice 52 pots
port 0/1/2
dial-peer voice 53 pots
port 0/1/3
dial-peer voice 54 pots
description ** FXO pots dial-peer **
service onramp
destination-pattern A0
port 0/1/0
no sip-register
dial-peer voice 55 pots
destination-pattern A1
port 0/1/1
no sip-register
dial-peer voice 56 pots
destination-pattern A2
port 0/1/2
no sip-register
dial-peer voice 57 pots
destination-pattern A3
port 0/1/3
no sip-register
dial-peer voice 2000 voip
description ** cue voicemail pilot number **
translation-profile outgoing XFER_TO_VM_PROFILE
destination-pattern 4000
b2bua
session protocol sipv2
session target ipv4:10.1.10.1
voice-class sip outbound-proxy ipv4:10.1.10.1
dtmf-relay sip-notify
codec g711ulaw
no vad
dial-peer voice 2001 voip
description ** cue auto attendant number **
translation-profile outgoing PSTN_CallForwarding
destination-pattern 3098
b2bua
codec g711ulaw
no vad
dial-peer voice 2012 voip
description ** cue prompt manager number **
destination-pattern 3001
b2bua
codec g711ulaw
no vad
dial-peer voice 58 pots
trunkgroup ALL_FXO
corlist outgoing call-emergency
description **CCA*North American-7-digit*Emergency**
translation-profile outgoing OUTGOING_TRANSLATION_PROFILE
preference 5
destination-pattern 9911
forward-digits all
no sip-register
dial-peer voice 59 pots
trunkgroup ALL_FXO
preference 5
destination-pattern 911
forward-digits all
no sip-register
dial-peer voice 60 pots
trunkgroup ALL_FXO
corlist outgoing call-local
description **CCA*North American-7-digit*7-Digit Local**
preference 5
destination-pattern 9[2-9]......
forward-digits all
no sip-register
dial-peer voice 61 pots
trunkgroup ALL_FXO
description **CCA*North American-7-digit*Service Numbers**
preference 5
destination-pattern 9[2-9]11
forward-digits all
no sip-register
dial-peer voice 62 pots
trunkgroup ALL_FXO
corlist outgoing call-national
description **CCA*North American-7-digit*Long Distance**
preference 5
destination-pattern 91[2-9]..[2-9]......
forward-digits all
no sip-register
dial-peer voice 63 pots
trunkgroup ALL_FXO
corlist outgoing call-international
description **CCA*North American-7-digit*International**
preference 5
destination-pattern 9011T
forward-digits all
no sip-register
dial-peer voice 64 pots
trunkgroup ALL_FXO
corlist outgoing call-toll-free
description **CCA*North American-7-digit*Toll-Free**
preference 5
destination-pattern 91800.......
forward-digits all
no sip-register
dial-peer voice 65 pots
trunkgroup ALL_FXO
preference 5
destination-pattern 91888.......
forward-digits all
no sip-register
dial-peer voice 66 pots
trunkgroup ALL_FXO
preference 5
destination-pattern 91877.......
forward-digits all
no sip-register
dial-peer voice 67 pots
trunkgroup ALL_FXO
preference 5
destination-pattern 91866.......
forward-digits all
no sip-register
dial-peer voice 68 pots
trunkgroup ALL_FXO
preference 5
forward-digits all
no sip-register
dial-peer voice 6 pots
description "catch all dial peer for BRI/PRI"
translation-profile incoming nondialable
incoming called-number .%
direct-inward-dial
dial-peer voice 1000 voip
permission term
description ** Incoming call from SIP trunk (Generic SIP Trunk Provider) **
session target sip-server
voice-class codec 1
voice-class sip dtmf-relay force rtp-nte
dtmf-relay rtp-nte
ip qos dscp cs5 media
ip qos dscp cs4 signaling
no vad
dial-peer voice 1001 voip
description ** star code to SIP trunk (Generic SIP Trunk Provider) **
destination-pattern *..
voice-class codec 1
dtmf-relay rtp-nte
no vad
dial-peer voice 1003 voip
description ** Passthrough Inbound Calls from CUE **
translation-profile incoming SIP_Passthrough
b2bua
incoming called-number ABCDT
codec g711ulaw
no vad
dial-peer voice 1005 voip
description ** Passthrough Inbound MWI from CUE **
b2bua
incoming called-number A80T
codec g711ulaw
no vad
dial-peer voice 1002 voip
preference 1
session target dns:apicps.onvoip.net
voice-class codec 1
dtmf-relay rtp-nte
no vad
dial-peer voice 3001 voip
description ADSCORPAA-AA
translation-profile incoming ADSCORPAA-AA_Called_5
incoming called-number 352432162[0-8]
voice-class codec 1
dtmf-relay rtp-nte
no vad
dial-peer voice 69 pots
trunkgroup ALL_FXO
preference 5
forward-digits all
no sip-register
dial-peer voice 72 pots
trunkgroup ALL_FXO
preference 5
forward-digits all
no sip-register
dial-peer voice 73 pots
trunkgroup ALL_FXO
preference 5
forward-digits all
no sip-register
dial-peer voice 74 pots
trunkgroup ALL_FXO
preference 5
forward-digits all
no sip-register
dial-peer voice 75 pots
trunkgroup ALL_FXO
preference 5
forward-digits all
no sip-register
dial-peer voice 76 pots
trunkgroup ALL_FXO
preference 5
forward-digits all
no sip-register
dial-peer voice 77 pots
trunkgroup ALL_FXO
preference 5
forward-digits all
no sip-register
dial-peer voice 1030 voip
translation-profile outgoing PSTN_Outgoing
preference 1
voice-class codec 1
dtmf-relay rtp-nte
no vad
dial-peer voice 1031 voip
preference 1
voice-class codec 1
dtmf-relay rtp-nte
no vad
dial-peer voice 1032 voip
preference 1
voice-class codec 1
dtmf-relay rtp-nte
no vad
dial-peer voice 1033 voip
preference 1
voice-class codec 1
dtmf-relay rtp-nte
no vad
dial-peer voice 1034 voip
preference 1
voice-class codec 1
dtmf-relay rtp-nte
no vad
dial-peer voice 1035 voip
preference 1
voice-class codec 1
dtmf-relay rtp-nte
no vad
dial-peer voice 1036 voip
preference 1
voice-class codec 1
dtmf-relay rtp-nte
no vad
dial-peer voice 1037 voip
preference 1
voice-class codec 1
dtmf-relay rtp-nte
no vad
dial-peer voice 1038 voip
translation-profile outgoing CALLER_ID_TRANSLATION_PROFILE
preference 1
voice-class codec 1
dtmf-relay rtp-nte
no vad
dial-peer voice 1039 voip
preference 1
voice-class codec 1
dtmf-relay rtp-nte
no vad
dial-peer voice 2010 voip
description Prompt Management Dial Peer
b2bua
codec g711ulaw
no vad
dial-peer voice 3000 voip
description Incoming-AA
translation-profile incoming Incoming-AA_Called_4
incoming called-number 3524321619
voice-class codec 1
dtmf-relay rtp-nte
no vad
dial-peer voice 3002 voip
translation-profile incoming Incoming-AA_Called_6
voice-class codec 1
dtmf-relay rtp-nte
no vad
dial-peer voice 1006 voip
description ** AA from SIP Trunk (Auto Attendant 1)**
translation-profile incoming AA_Profile
incoming called-number 3524321620
voice-class codec 1
dtmf-relay rtp-nte
no vad
dial-peer voice 2003 voip
description ** cue auto attendant PSTN number **
translation-profile outgoing AA_Profile
destination-pattern 3524321620$
b2bua
codec g711ulaw
no vad
dial-peer voice 1800 mmoip
description ** fax onramp for outbound faxmail to CUE **
service fax_on_vfc_onramp_app out-bound
destination-pattern ^....$
information-type fax
session target mailto:$d$@10.1.10.1
no dial-peer outbound status-check pots
sip-ua
no remote-party-id
retry invite 2
retry register 10
timers connect 1000
registrar ipv4:10.10.10.1 expires 3600
sip-server ipv4:10.10.10.1
host-registrar
telephony-service
sdspfarm units 5
video
fxo hook-flash
max-ephones 114
max-dn 600
ip source-address 10.1.1.1 port 2000
max-redirect 20
auto assign 1 to 1 type bri
calling-number initiator
service phone videoCapability 1
service phone ehookenable 1
service dnis overlay
service dnis dir-lookup
timeouts interdigit 5
system message Automated Document Solutions
url services http://10.1.10.1/voiceview/common/login.do
url authentication http://10.1.10.2/CCMCIP/authenticate.asp
load 521G-524G cp524g-8-1-17
load 525G spa525g-7-4-8
load 501G spa5x5-7-4-2
load 502G spa5x5-7-4-2
load 504G spa5x5-7-4-2
load 508G spa5x5-7-4-2
load 509G spa5x5-7-4-2
load 525G2 spa525g-7-4-8
time-zone 12
keepalive 10
voicemail 4000
max-conferences 8 gain -6
call-forward pattern .T
call-forward system redirecting-expanded
hunt-group logout HLog
web admin system name cisco secret 5 $1$H2p2$OvHgtmQydzvHtduMX/oEy.
dn-webedit
time-webedit
transfer-system full-consult dss
transfer-pattern 9.T
transfer-pattern .T
transfer-pattern 7.T
transfer-pattern 6.... blind
secondary-dialtone 9
night-service day Sun 17:00 09:00
night-service day Mon 17:00 09:00
night-service day Tue 17:00 09:00
night-service day Wed 17:00 09:00
night-service day Thu 17:00 09:00
night-service day Fri 17:00 09:00
night-service day Sat 17:00 09:00
fac standard
create cnf-files version-stamp 7960 Jan 22 2011 14:36:59
ephone-template 15
url services 1 http://10.1.10.1/voiceview/common/login.do VoiceviewExpress
url services 2 http://10.1.10.1/timecardview/common/login.do TimeCardView
softkeys remote-in-use Newcall
softkeys idle Redial Newcall Cfwdall Pickup Gpickup Dnd HLog Login
softkeys seized Cfwdall Endcall Redial Pickup Gpickup Callback
softkeys connected Hold Endcall Trnsfer TrnsfVM Confrn Acct Park
button-layout 7931 2
ephone-template 16
ephone-template 17
softkeys remote-in-use CBarge Newcall
ephone-template 18
ephone-dn 1
number 2001 no-reg primary
description IP-Paging1
name All Page
paging ip 239.1.1.1 port 2000
ephone-dn 6 dual-line
number 302 no-reg primary
label 302
description 302
name 302
ephone-dn 7 dual-line
number 303 no-reg primary
label 303
description 303
name 303
ephone-dn 8 dual-line
number 304 no-reg primary
label 304
description 304
name 304
ephone-dn 9
number BCD no-reg primary
description MoH
moh out-call ABC
ephone-dn 16 dual-line
number 1019 no-reg both
label Extension
name
call-forward busy 4000
call-forward noan 4000 timeout 20
ephone-dn 19 dual-line
number 1004 no-reg both
label Extension
name Helpdesk Phone
ephone-dn 25 dual-line
number 1016 no-reg both
label Extension
name
ephone-dn 29 dual-line
number 220 no-reg primary
label 220
description 220
name 220
ephone-dn 30 dual-line
number 221 no-reg primary
label 221
description 221
name 221
ephone-dn 31 dual-line
number 222 no-reg primary
label 222
description 222
name 222
ephone-dn 113 dual-line
number 314 no-reg primary
label 314
description 314
name 314
ephone-dn 568 dual-line
number 1015 no-reg both
label Extension
name
ephone-dn 569 dual-line
number 1007 no-reg both
name
ephone-dn 570 dual-line
number 1020 no-reg both
name
ephone-dn 571 dual-line
number 1008 no-reg both
name
call-forward all 919788355352
ephone-dn 572 dual-line
number 2007 no-reg both
label Extension
name
ephone-dn 573 dual-line
number 1013 no-reg both
label Extension
name
ephone-dn 574 dual-line
number 1009 no-reg both
label Extension
name
ephone-dn 575 dual-line
number 1001 no-reg both
label Extension
name
ephone-dn 576 dual-line
number 1018 no-reg both
label Extension
name
ephone-dn 577 dual-line
number 1003 no-reg both
label Extension
name
ephone-dn 578 dual-line
number 1010 no-reg both
name
ephone-dn 579 dual-line
number 1022 no-reg both
name
ephone-dn 580 dual-line
number 1021 no-reg both
name
ephone-dn 594 dual-line
number 1017 no-reg both
name
ephone-dn 595
number 3524321620
description SIP Main Number registration
preference 10
ephone-dn 596 dual-line
number 1002 no-reg both
label Extension
name
ephone-dn 597 dual-line
number 1006 no-reg both
name
ephone-dn 598
number 6.... no-reg primary
description ***CCA XFER TO VM EXTENSION***
call-forward all 4000
ephone-dn 599
number A801.... no-reg primary
mwi off
ephone-dn 600
number A800.... no-reg primary
mwi on
ephone 1
device-security-mode none
mac-address 68EF.BD28.F400
ephone-template 16
max-calls-per-button 2
username "" password 1234
type 525G
button 1:596
ephone 2
mac-address 68EF.BD28.F2AC
ephone-template 16
speed-dial 1 918666061866 label "Cisco SBS"
type 525G
button 1:573
ephone 3
mac-address 68EF.BD28.F55C
ephone-template 16
username " password 1234
type 525G
button 1:580
ephone 4
mac-address 68EF.BD28.F2EA
ephone-template 16
username password 1234
type 525G
button 1:570
ephone 5
mac-address 68EF.BD28.E032
ephone-template 16
speed-dial 1
speed-dial 2
speed-dial 3
speed-dial 4
type 525G
button 1:16
ephone 6
mac-address 68EF.BD28.E008
ephone-template 16
type 525G
button 1:19
ephone 7
mac-address 68EF.BD28.F4F4
ephone-template 16
type 525G
button 1:578
ephone 8
mac-address 68EF.BD28.ECFC
ephone-template 16
username "t" password 1234
type 525G
button 1:579
ephone 9
mac-address 68EF.BD28.E018
ephone-template 16
type 525G
button 1:572
ephone 10
mac-address 68EF.BD28.F4E4
ephone-template 16
speed-dial 1
speed-dial 2
speed-dial 3
speed-dial 4
type 525G
button 1:575
ephone 11
mac-address 68EF.BD28.E00C
ephone-template 16
speed-dial 1
speed-dial 2
speed-dial 3
speed-dial 4
speed-dial 5
type 525G
button 1:597
ephone 12
mac-address 68EF.BD28.DFA8
ephone-template 16
type 525G
button 1:25
ephone 13
mac-address 68EF.BD28.F2DA
ephone-template 16
type 525G
button 1:568
ephone 14
mac-address 68EF.BD28.F4EE
ephone-template 16
type 525G
button 1:577
ephone 15
mac-address 68EF.BD28.F4B4
ephone-template 16
type 525G
button 1:569
ephone 16
mac-address 68EF.BD28.F4C2
ephone-template 16
type 525G
button 1:574
ephone 17
mac-address 68EF.BD28.F36E
ephone-template 16
type 525G
button 1:576
ephone 18
mac-address 68EF.BD28.F606
ephone-template 16
type 525G
button 1:571
ephone 20
mac-address 68EF.BD28.F240
ephone-template 16
type 525G
button 1:594
ephone-hunt 1 sequential
pilot 5001
list 1009, 1013, 1019, 1004
final 4000
timeout 8, 8, 8, 8
no-reg pilot
statistics collect
description IT
alias exec cca_voice_mode PBX
alias exec cca_vm_notification schedule from_time=00 to_time=24
banner login ^CCisco Configuration Assistant. Version: 2.2 (6). Wed Dec 01 17:15:37 EST 2010^C
line con 0
no modem enable
line aux 0
line 2
no activation-character
no exec
transport preferred none
transport input all
speed 115200
line vty 0 4
logging synchronous
transport input all
line vty 5 100
logging synchronous
transport input all
ntp master
ntp server 192.168.20.11 prefer
webvpn gateway SDM_WEBVPN_GATEWAY_1
ip address 10.10.10.2 port 443
ssl trustpoint TP-self-signed-1774138792
inservice
webvpn install svc flash:/webvpn/anyconnect-win-2.5.2014-k9.pkg sequence 1
webvpn context SDM_WEBVPN_CONTEXT_1
secondary-color white
title-color #CCCC66
text-color black
ssl authenticate verify all
policy group SDM_WEBVPN_POLICY_1
functions svc-enabled
svc address-pool "SDM_WEBVPN_POOL_1"
default-group-policy SDM_WEBVPN_POLICY_1
aaa authentication list sdm_vpn_xauth_ml_1
max-users 20
inservice
end
UC560#
07-07-2011 12:10 PM
If you search your flash, their should be some crash dump files. I would recommend opening a case with small business support and get these dump files to them to see what is crashing.
07-07-2011 02:29 PM
Hi Peter,
Two things:
1. Can you copy your configuration to a Text file and then upload it and edit your post It is best to use the uploading feature so as to stop the thread from being far to long.
2. As Thomas mentioned there should be some crash files located on the flash card, you can use CCA to view this or you can do it via CLI, either way can you upload them so we can see them and at the same time do as Thomas suggested and open up a SBS case, doing both in tandem and yield good results
Please make sure that you remove any sensitive information from your configuration and have a quick look at the crash dumps to make sure nothing sensitive is in them either.
Other than that your configuration looks fine, but one thing strikes me is that this does not look like a typical CCA 3.0(1) configuration, if it is you must have done some heavy modifications to it, or you have built this with a CCA 3.1 pre-release.
Cheers,
David.
