05-14-2013 03:33 AM - edited 03-21-2019 07:21 AM
I have an UC560 and a gateway patton ISDN/T0 who's connecting to the phone provider (Orange / France Telecom).
Is someone had already configure this ?
Thank you very much,
Stephane.
05-14-2013 08:22 AM
It would be miuch better if you connect the ISDN circuit diectly to the UC560 (if it has one), or buy a VIC BRI to be added to the UC560.
05-14-2013 12:56 PM
Thank for your answer.
Yes you have right.
But the T0 line coming in another "room" than Cisco UC560.
I have two switch (support vlan) in each room.
And I cannot (or I wrong me) make T0 through VLANs.
It's for that I must use a patton gateway for convert T0 to SIP and send SIP data to a dedicated VLAN.
Thank you for your help,
Stephane.
05-14-2013 01:53 PM
You can extend the BRI S/T bus over ethernet wiring. I takes two pairs per circuit, so you can take two circuits on a single cable.
Or move the UC500 to the place where the circuit is installed.
Both solutions are easier and will give better results than using an external gateway,
05-14-2013 03:39 PM
Sorry i dont give many details.
I cannot install Cisco UC in the another room it's a problem of responsibility (not a technical problem but an administrative problem).
And because this config dont want help me, I have only one fiber channel for link my room to another t0 room. Vlan data/admin/VoIP are in the trunk.
Thank you,
Stephane.
