11-15-2011 03:52 AM - edited 03-21-2019 04:56 AM
Hi Team,
My understanding is UC560 can be integrated with CUCM via H323/SIP, however, my question is this integration supported by TAC or SBCS?
Aamir
11-15-2011 05:44 AM
SBCS would not support that configuration. If you had a smartnet agreement on your CUCM, TAC would support your configuration to get things working.
It would be an odd configuration because ISR's are added as MGCP gateway's so that CUCM can have control over the gateway's ports. It also pushes the SRST config and dial plan to the gateway. If you add the UC500 as a H323 device, you will need to configure and maintain the dial plan on CME and you would lose the PRI Backhaul failover capability, that comes with MGCP.
07-09-2012 10:55 PM
My customer has exiting UC 560 deployed. Now he is moving to CUCM 8.6. He will only be using the UC 560 for trunk lines termination.
Is this a working scenario? I will use UC560 as an H.323 gateway.
Appreciate your feedback.
07-10-2012 04:01 AM
Yes. Not supported by Cisco as indicated above.
