02-27-2013 09:08 AM - edited 03-21-2019 07:01 AM
I have an issue with message waiting indicator. It works but has serious limitations. Let me explain, hoping someone can help.
IOS Version: Version 15.1(4)M4b
The mwi ephone-dn's:
ephone-dn 599
number 8001.... no-reg primary
mwi off
ephone-dn 600
number 8000.... no-reg primary
mwi on
The CUW config:
ccn application ciscomwiapplication aa
description "ciscomwiapplication"
enabled
maxsessions 12
script "setmwi.aef"
parameter "CallControlGroupID" "0"
parameter "strMWI_OFF_DN" "8001"
parameter "strMWI_ON_DN" "8000"
end application
ccn subsystem sip
gateway address "10.1.10.2"
dtmf-relay rtp-nte
end subsystem
ccn trigger http urlname mwiapp
application "ciscomwiapplication"
enabled
maxsessions 1
end trigger
UC560#sh voice call status
CallID CID ccVdb Port Slot/DSP:Ch Called # Codec MLPP Dial-peers
0x1DCB1 3091 0x8B33DC30 50/0/595.0 9054365870 g711ulaw 20070/1072
0x1DD17 3181 0x8B160840 50/0/579.0 *2732 g711ulaw 5000/20054
0x1DD0D 3165 0x8B0E9954 50/0/573.0 9057063373 g711ulaw 20048/1072
0x1DD1C 318B 0x89D80514 50/0/546.0 4169493743 g711ulaw 20021/1072
0x1DD2D 31B0 0x89D0D434 50/0/545.0 *2731 g711ulaw 5000/20020
0x1DD23 319C 0x8B3C3F2C 50/0/600.0 *80002571 None 1005/20102
0x1DD32 31B9 0x8B2E51E4 50/0/592.0 3999 g711ulaw 20067/5050
7 active calls found
The message waiting indicator works but look at the above output. See the call going to *80002571? That is a voicemail received and the CUE is using the "8000... ephone-dn 600" to turn on the mwi light. It does, it turns it on. However, if another user receives a voicemail the mwi light will not turn on because the call to *800022571 call is still in progress. The mwi light will not go on for any other user until the call times out. The same for mwi light off.
So, the mwi light will not go on or off is there are other calls using the ephone-dn 599 or 600. The observation is, a user receives a voicemail but the mwi light does not turn on. That's because another user has received a voicemail and the call to 8000.... is still held.
How can I get these calls to tear down faster? The calls to 8000.... or 8001.... stay active for 5 min's or so.
Solved! Go to Solution.
02-27-2013 01:29 PM
Hello David,
Do you have bind statements under voice service voip sip section?
If so please remove them.
Are you using connection reuse?
Also this issue is resolved could be resolved with the new IOS 15.1(4)M5 which is included in SWP 8.6.1.
HTH,
Alex
*Please rate helpful posts
15.1(4)M4b#sthash.PkH5sYxB.dpuf
15.1(4)M4#sthash.PkH5sYxB.dpuf
02-27-2013 01:29 PM
Hello David,
HTH,
Alex
02-27-2013 01:44 PM
Thanks Alexander,
I have another system running the exact same IOS, it works perfect. My voice service voip is below;
voice service voip
ip address trusted list
ipv4 0.0.0.0 0.0.0.0
allow-connections h323 to sip
allow-connections sip to h323
allow-connections sip to sip
supplementary-service h450.12
no supplementary-service sip moved-temporarily
no supplementary-service sip refer
fax protocol t38 version 0 ls-redundancy 0 hs-redundancy 0 fallback pass-through g711ulaw
sip
registrar server expires max 3600 min 3600
localhost dns:SIP_provider.ca
outbound-proxy dns:SIP_provider.ca
no update-callerid
connection-reuse is present in sip-ua.
02-27-2013 02:06 PM
Hello David,
Please try to add "via-port" after connection-reuse under sip-ua if you really need the connection-reuse.
If you cannot add it you should try to change the SIP MWI Notification Mechanism to Unsolicited Notify which will be easier than the other subscribe method.
Also if you do not want to change it you need to update the IOS.
HTH,
Alex
02-27-2013 02:05 PM
Great...
I saw connection-reuse in sip-ua. Not sure how it got there. But removing it fixed it. I now see these calls being active for only a few seconds.
Thanks a million...
