UC560 not creating xml when executing create cnf
In need ok a little advice.  I have a UC560 handed to me to configure and I'm hitting an issue.  I've defaulted it and created extensions through CCA and assigned mac address along with option 150 in DHCP.  On the surface all looks ok but the phones wont register.  I debug the TFTP server and I can see the phone asking for the XML SEP file but when I looked at the flash its not been created.  So I went into telephone services and "create cnf" it say its created the files but when I check the flash still no SEP...cnf.xml.
Pretty much stumped as to what to do now. Any advice?
Config attached.  It's basic so should just work.
Everyone's tags (1)
Hello, Under telephony
Under telephony-service, you are missing the following. Please put in these commands and create cnf again.
 cnf-file location flash:
 cnf-file perphone
Kind regards,
Jordan
Thanks Jordan, I found the
Thanks Jordan,
I found the issue was related to the erase process I had followed through the CLI.  I did it through the wizard and it setup correctly.  Probably some command missing.
David
116
