Community Member
UC560 Site to Site VPN problem
Hi, I install on my client two UC560. Before that I had 2 RV180w router with vpn connectivity. After that change the RPC from my two server are not connecting. Some time that work but many of the time that doesn't. I can ping both side and use shared by ip but not by dns. I can ping the dns name. But when I try to connect with name I got network not found. I also have a lot of problem with the Active Directory not syncing. I have error from RPC. When I call to the SBCS Cisco they said this is a problem with my Server Windows... I don't think so because everything was working fine before the upgarde to the UC560... Can someone help me, I try a lot of hot fix or change in the config but now I doesn't have anymore idea.
Everyone's tags (4)
Hall of Fame Super Gold
A lot more details about configuration and relevant traces would be needed. My recommendation is to involve a reputable consultant or Certified Cisco partner for assistance.
