UC560 WAN port
In UC560-T1E1-K9 there is a WAN port.
Does this port support ADSL2+?
Rajesh
Re: UC560 WAN port
No, it's an ethernet port.  You can add an SR-520W-adsl-k9 (additional router) for ADSL2+.
I think an ADSL card would be a welcome addition to the UC5xx.
UC560 WAN port
+1 Peter
I have been begging for this for ages, either an inbuilt one or a HWIC card that will fit into the slot, they SHOULD have done this with the introduction of the 540/560 series, this was the perfect time to do it and they failed to do it, no clue as to why but I was deeply disappointed to see they never moved down this path... ADSL 2+ Is here to stay for quite some time even though we are moving to an Ethernet/fibre based services, this is still al little way off.
Cheers,
David.
Cheers, David Trad. **When you rate a persons post, you are indicating a thank you or that it helped, but at the same time you are also helping to maintain the community spirit - You don't have to rate posts and you wont be looked down upon :) *
466
