Unity Error
Im doing a CCA Lab (UC500-CCA-First-Look-v1-Lab4), but there's a section in a lab the requiere to use the unity express Web config, but when I try to click on:
Configure>Extensions
I get the following error:
Error: Unable to login as administrator to the Cisco CallManagerExpress at site 'local'.
Details: CME login failed
Thanks in advance.
Community Member
Re: Unity Error
Could you provide with CLI config please?
Eivind
Re: Unity Error
Attached is the UC500 config. Another thing, I put the command "IP http server" in the UC500, but when I try to access it via Web, I can't. The URL that I used is:
http://192.168.10.1/ccme.html
Thanks.
Community Member
Re: Unity Error
Make sure that the following is configured:
ip http path flash:/gui
Let us know,
Marcos
Community Member
Re: Unity Error
That isn't the config that is attached.
If you have not changed your IP addreses.  You should connect to https://10.1.10.1.  Once in there, you may have to run the CME/CUE setip wizard to make sure the CUE Admin and CME admin passwords are synd.
Re: Unity Error
Now is the correct config. The Unity doens't allow me to run the initial wizard again, what can I do in this case?
Community Member
Re: Unity Error
The CUE Setup Wizard is a one shot kind of deal. You would have to bring the system to factory defaults for it to show up again. Did you try the command that I suggested?
Marcos
Re: Unity Error
Hi Marcos,
With a lot of response (that is not a bad thing) I don't pay attetion to your response (excuseme man). Now I issue the command that you suggest (ip http path flash:/gui) and all my problems (excluding financial)
  were resolve.
thanks for your help.
Community Member
Re: Unity Error
I am glad to hear that your problem is fixed (the technical one) :-)
Marcos
3075
