03-19-2010 08:22 AM - edited 03-21-2019 02:20 AM
Hi:
Can anyone tell me why or how to fix an issue with the Cisco UC500. We are getting an unknown SIP Registration message from the Cisco UC500. I don't even have the '6782367070' programmed anywhere in UC500. So, I don't how it is sending out this SIP Register message to our network.
REGISTER sip:192.168.1.1:5060 SIP/2.0
Via: SIP/2.0/UDP 192.168.1.2:5060;branch=z9hG4bK458758
From: <sip:6782367070@192.168.1.1>;tag=522D180-24EB
To: <sip:6782367070@192.168.1.1>
Date: Tue, 16 Mar 2010 14:34:37 GMT
Call-ID: 5AE11A07-2F7711DF-8003C075-80F32E1A
User-Agent: Cisco-SIPGateway/IOS-12.x
Max-Forwards: 70
Timestamp: 1268750077C
Seq: 557 REGISTER
Contact: <sip:6782367070@192.168.1.2:5060>
Expires: 70
Supported: path
Content-Length: 0
03-19-2010 02:23 PM
Check you UC and look at the config (CLI) under sip-ua, or in CCA under Telephony -> Trunks -> SIP Trunks
Good Luck
03-20-2010 03:00 PM
Check the below:
show sip-ua registar status
Does the 678xxxxxxx number show up there? If so what is the peer tag value associated to it? Based on that it maybe config under "sip-ua" or an extension (ephone-dn). Are you sure this DID was never added in via CCA (or CLI) for a hunt group or main caller ID etc.
