Community Member
URGENT!! NEED HELP CONFIGURING AN AUTO ATTENDANT SCRIPT USING ONLY THE CURRENT UC520 CONFIG!
I am tasked with creating a basic auto attendant script for a client who's office has
only 10 users. They have a UC520 and recently their auto attendant script has
become corrupt. It now long prompts to enter extension, it simply dials the main
number and the call is able to be answered. The client is only using Cisco Configuration
Assistant 3.1 to configure the VoIP environment. How do I configure an auto attendant
script in IOS or in Cisco Configuration Assistant 3.1? I don't have access to the
network remotely so I only have this config to build a default script from. How do
I do this?
Please help.
Current configuration : 34406 bytes
! Last configuration change at 22:23:17 PST Wed Aug 24 2011 by 1N$P1r8T10N8L
version 12.4
parser config cache interface
no service pad
service internal
service compress-config
hostname UC520
boot-start-marker
boot system flash uc500-advipservicesk9-mz.124-20.T2
boot-end-marker
logging message-counter syslog
aaa new-model
UC520#
Aug 25 02:37:26.143: %IPPHONE-6-REG_ALARM: 25: Name=SEP0021A0D97AB2 Load= SCCP41.8-2-2SR2S
Last=Initialized
Aug 25 02:37:26.191: %IPPHONE-6-REGISTER: ephone-5:SEP0021A0D97AB2 IP:10.1.1.16 Socket:10
DeviceType:Phone has registered.
UC520#sh run
Building configuration...
version 12.4
no service pad
service internal
hostname UC520
boot-start-marker
boot-end-marker
aaa new-model
aaa authentication login default local
aaa authentication login Foxtrot_sdm_easyvpn_xauth_ml_1 local
aaa authorization exec default local
aaa authorization network Foxtrot_sdm_easyvpn_group_ml_1 local
aaa session-id common
clock timezone EST -5
clock summer-time PST recurring
crypto pki trustpoint TP-self-signed-2249520590
enrollment selfsigned
subject-name cn=IOS-Self-Signed-Certificate-2249520590
revocation-check none
rsakeypair TP-self-signed-2249520590
crypto pki certificate chain TP-self-signed-2249520590
certificate self-signed 01
  3082023D 308201A6 A0030201 02020101 300D0609 2A864886 F70D0101 04050030
  31312F30 2D060355 04031326 494F532D 53656C66 2D536967 6E65642D 43657274
  69666963 6174652D 32323439 35323035 3930301E 170D3131 30383235 30323231
  31385A17 0D323030 31303130 30303030 305A3031 312F302D 06035504 03132649
  4F532D53 656C662D 5369676E 65642D43 65727469 66696361 74652D32 32343935
  32303539 3030819F 300D0609 2A864886 F70D0101 01050003 818D0030 81890281
  8100BD58 739EB721 FE990F4F AAE48BF3 524871B7 0F5913DF 9DB9C9B4 88B25A7A
  0F34C82E 6833D25C 80AF1E5A F79D258E 1759DEA4 CDE1319B 9744084E 271F4EB8
  415DC939 039DA57E 17E0E819 D2C01AC7 28135979 FBA67EFD 702664C2 6AABB894
  7A096B34 8D7C7897 15797292 50C4DA2A E2FB112F 85F57671 E08D3940 713FFC19
  60910203 010001A3 65306330 0F060355 1D130101 FF040530 030101FF 30100603
  551D1104 09300782 05554335 3230301F 0603551D 23041830 16801406 D58FF329
  436E8BD8 E1A73800 062B115A 99AC0F30 1D060355 1D0E0416 041406D5 8FF32943
  6E8BD8E1 A7380006 2B115A99 AC0F300D 06092A86 4886F70D 01010405 00038181
  009363CC 0B0F53AE E8FB2786 06E63879 680534A3 AEDEE63A C9E693F1 7B29627F
  2E9D4027 D3D7FA11 810AC2AD 2F5E4B98 EE5D9AA4 CA58C64B 3CCFBF94 02EAC365
  CA01FEA3 6B339220 06D1D3AA 52D9EAB3 341E0EBC E3A5F0C4 873610E2 3A563529
  406C2D9A F0DD277D 6B92E806 8BDC72E2 58440160 6A1CB3A0 345003D8 5A319069 F3
        quit
dot11 syslog
dot11 ssid uc520-data
   vlan 1
   authentication open
dot11 ssid uc520-voice
   vlan 100
   authentication open
ip source-route
ip cef
ip dhcp relay information trust-all
ip dhcp excluded-address 10.1.1.1 10.1.1.10
ip dhcp excluded-address 192.168.10.1 192.168.10.10
ip dhcp pool phone
   network 10.1.1.0 255.255.255.0
   default-router 10.1.1.1
   option 150 ip 10.1.1.1
ip dhcp pool data
   import all
   network 192.168.10.0 255.255.255.0
   default-router 192.168.10.1
   dns-server 4.2.2.2 63.203.35.55
ip name-server 68.87.73.242
ip name-server 68.87.71.226
ip inspect log drop-pkt
ip inspect name SDM_LOW cuseeme
ip inspect name SDM_LOW dns
ip inspect name SDM_LOW ftp
ip inspect name SDM_LOW h323
ip inspect name SDM_LOW https
ip inspect name SDM_LOW icmp
ip inspect name SDM_LOW imap
ip inspect name SDM_LOW pop3
ip inspect name SDM_LOW netshow
ip inspect name SDM_LOW rcmd
ip inspect name SDM_LOW realaudio
ip inspect name SDM_LOW rtsp
ip inspect name SDM_LOW esmtp
ip inspect name SDM_LOW sqlnet
ip inspect name SDM_LOW streamworks
ip inspect name SDM_LOW tftp
ip inspect name SDM_LOW tcp
ip inspect name SDM_LOW udp
ip inspect name SDM_LOW vdolive
no ipv6 cef
stcapp ccm-group 1
stcapp feature access-code
trunk group  ALL_FXO
voice call send-alert
voice rtp send-recv
voice service voip
allow-connections h323 to sip
allow-connections sip to h323
allow-connections sip to sip
supplementary-service h450.12
sip
  no update-callerid
voice class codec 1
codec preference 1 g711ulaw
codec preference 2 g729r8
voice register global
max-dn 88
max-pool 22
voice translation-rule 1111
voice translation-rule 1112
rule 1 /^9/ //
voice translation-rule 2222
voice translation-profile CALLER_ID_TRANSLATION_PROFILE
translate calling 1111
voice translation-profile CallBlocking
translate called 2222
voice translation-profile OUTGOING_TRANSLATION_PROFILE
translate called 1112
voice-card 0
no dspfarm
crypto isakmp policy 1
encr 3des
authentication pre-share
group 2
crypto isakmp client configuration group EZVPN_GROUP_1
key 86753092009!
dns 68.87.73.242 68.87.71.226
pool SDM_POOL_1
acl 105
max-users 10
crypto isakmp profile sdm-ike-profile-1
   match identity group EZVPN_GROUP_1
   client authentication list Foxtrot_sdm_easyvpn_xauth_ml_1
   isakmp authorization list Foxtrot_sdm_easyvpn_group_ml_1
   client configuration address respond
   virtual-template 1
crypto ipsec transform-set ESP-3DES-SHA esp-3des esp-sha-hmac
crypto ipsec profile SDM_Profile1
set transform-set ESP-3DES-SHA
set isakmp-profile sdm-ike-profile-1
archive
log config
  logging enable
  logging size 600
  hidekeys
process-max-time 50
ip tftp source-interface Loopback0
class-map match-any sdm_p2p_kazaa
match protocol fasttrack
match protocol kazaa2
class-map match-any sdm_p2p_edonkey
match protocol edonkey
class-map match-any sdm_p2p_gnutella
match protocol gnutella
class-map match-any sdm_p2p_bittorrent
match protocol bittorrent
bridge irb
interface Loopback0
description $FW_INSIDE$
ip address 10.1.10.2 255.255.255.252
ip access-group 103 in
ip nat inside
ip virtual-reassembly
interface FastEthernet0/0
description $FW_OUTSIDE$
ip address 173.15.202.245 255.255.255.252
ip access-group 104 in
ip verify unicast reverse-path
ip nat outside
ip inspect SDM_LOW out
duplex auto
speed auto
snmp trap ip verify drop-rate
interface Integrated-Service-Engine0/0
description cue is initialized with default IMAP group
ip unnumbered Loopback0
ip nat inside
service-module ip address 10.1.10.1 255.255.255.252
service-module ip default-gateway 10.1.10.2
interface FastEthernet0/1/0
switchport voice vlan 100
macro description cisco-phone | cisco-phone
spanning-tree portfast
interface FastEthernet0/1/1
interface FastEthernet0/1/2
interface FastEthernet0/1/3
interface FastEthernet0/1/4
interface FastEthernet0/1/5
interface FastEthernet0/1/6
interface FastEthernet0/1/7
interface FastEthernet0/1/8
switchport mode trunk
macro description cisco-switch | cisco-switch
interface Dot11Radio0/5/0
no ip address
shutdown
ssid uc520-data
ssid uc520-voice
speed basic-1.0 basic-2.0 basic-5.5 6.0 9.0 basic-11.0 12.0 18.0 24.0 36.0 48.0 54.0
station-role root
interface Dot11Radio0/5/0.1
encapsulation dot1Q 1 native
bridge-group 1
bridge-group 1 subscriber-loop-control
bridge-group 1 spanning-disabled
bridge-group 1 block-unknown-source
no bridge-group 1 source-learning
no bridge-group 1 unicast-flooding
interface Dot11Radio0/5/0.100
encapsulation dot1Q 100
bridge-group 100
bridge-group 100 subscriber-loop-control
bridge-group 100 spanning-disabled
bridge-group 100 block-unknown-source
no bridge-group 100 source-learning
no bridge-group 100 unicast-flooding
interface Virtual-Template1 type tunnel
ip unnumbered BVI1
ip nat inside
tunnel mode ipsec ipv4
tunnel protection ipsec profile SDM_Profile1
interface Vlan1
no ip address
bridge-group 1
interface Vlan100
no ip address
bridge-group 100
interface BVI1
ip address 192.168.10.1 255.255.255.0
ip access-group 101 in
ip nat inside
interface BVI100
ip address 10.1.1.1 255.255.255.0
ip access-group 102 in
ip nat inside
ip local pool SDM_POOL_1 192.168.50.10 192.168.50.50
ip forward-protocol nd
ip route 0.0.0.0 0.0.0.0 173.15.202.246
ip route 10.1.10.1 255.255.255.255 Integrated-Service-Engine0/0
ip http server
ip http authentication local
ip http secure-server
ip http path flash:
ip nat inside source list 1 interface FastEthernet0/0 overload
access-list 1 remark SDM_ACL Category=2
access-list 1 permit 192.168.10.0 0.0.0.255
access-list 1 permit 10.1.1.0 0.0.0.255
access-list 1 permit 10.1.10.0 0.0.0.3
access-list 100 remark auto generated by SDM firewall configuration
access-list 100 remark SDM_ACL Category=1
access-list 100 deny   ip 192.168.10.0 0.0.0.255 any
access-list 100 deny   ip host 255.255.255.255 any
access-list 100 deny   ip 127.0.0.0 0.255.255.255 any
access-list 100 permit ip any any
access-list 101 remark auto generated by SDM firewall configuration##NO_ACES_6##
access-list 101 remark SDM_ACL Category=1
access-list 101 permit udp any host 192.168.10.1 eq non500-isakmp
access-list 101 permit udp any host 192.168.10.1 eq isakmp
access-list 101 permit esp any host 192.168.10.1
access-list 101 permit ahp any host 192.168.10.1
access-list 101 deny   ip 10.1.10.0 0.0.0.3 any
access-list 101 deny   ip 10.1.1.0 0.0.0.255 any
access-list 101 deny   ip 173.15.202.244 0.0.0.3 any
access-list 101 deny   ip host 255.255.255.255 any
access-list 101 deny   ip 127.0.0.0 0.255.255.255 any
access-list 101 permit ip any any
access-list 102 remark auto generated by SDM firewall configuration##NO_ACES_8##
access-list 102 remark SDM_ACL Category=1
access-list 102 permit udp any host 10.1.1.1 eq non500-isakmp
access-list 102 permit udp any host 10.1.1.1 eq isakmp
access-list 102 permit esp any host 10.1.1.1
access-list 102 permit ahp any host 10.1.1.1
access-list 102 permit tcp 10.1.10.0 0.0.0.3 any eq 2000
access-list 102 permit udp 10.1.10.0 0.0.0.3 any eq 2000
access-list 102 deny   ip 10.1.10.0 0.0.0.3 any
access-list 102 deny   ip 192.168.10.0 0.0.0.255 any
access-list 102 deny   ip 173.15.202.244 0.0.0.3 any
access-list 102 deny   ip host 255.255.255.255 any
access-list 102 deny   ip 127.0.0.0 0.255.255.255 any
access-list 102 permit ip any any
access-list 103 deny   ip host 255.255.255.255 any
access-list 103 deny   ip 127.0.0.0 0.255.255.255 any
access-list 103 permit ip any any
access-list 103 remark auto generated by SDM firewall configuration##NO_ACES_8##
access-list 103 remark SDM_ACL Category=1
access-list 103 permit udp any host 10.1.10.2 eq non500-isakmp
access-list 103 permit udp any host 10.1.10.2 eq isakmp
access-list 103 permit esp any host 10.1.10.2
access-list 103 permit ahp any host 10.1.10.2
access-list 103 permit tcp 10.1.1.0 0.0.0.255 eq 2000 any
access-list 103 permit udp 10.1.1.0 0.0.0.255 eq 2000 any
access-list 103 deny   ip 10.1.1.0 0.0.0.255 any
access-list 103 deny   ip 192.168.10.0 0.0.0.255 any
access-list 103 deny   ip 173.15.202.244 0.0.0.3 any
access-list 104 remark auto generated by SDM firewall configuration##NO_ACES_15##
access-list 104 remark SDM_ACL Category=1
access-list 104 permit udp any host 173.15.202.245 eq non500-isakmp
access-list 104 permit udp any host 173.15.202.245 eq isakmp
access-list 104 permit esp any host 173.15.202.245
access-list 104 permit ahp any host 173.15.202.245
access-list 104 deny   ip 10.1.10.0 0.0.0.3 any
access-list 104 deny   ip 10.1.1.0 0.0.0.255 any
access-list 104 deny   ip 192.168.10.0 0.0.0.255 any
access-list 104 deny   ip host 0.0.0.0 any
access-list 104 deny   ip any any log
access-list 104 permit udp host 68.87.73.242 eq domain any
access-list 104 permit udp host 68.87.71.226 eq domain any
access-list 104 permit icmp any host 173.15.202.245 echo-reply
access-list 104 permit icmp any host 173.15.202.245 time-exceeded
access-list 104 permit icmp any host 173.15.202.245 unreachable
access-list 104 deny   ip 10.0.0.0 0.255.255.255 any
access-list 104 deny   ip 172.16.0.0 0.15.255.255 any
access-list 104 deny   ip 192.168.0.0 0.0.255.255 any
access-list 104 deny   ip 127.0.0.0 0.255.255.255 any
access-list 104 deny   ip host 255.255.255.255 any
access-list 105 remark SDM_ACL Category=4
access-list 105 permit ip 192.168.10.0 0.0.0.255 any
access-list 105 permit ip 10.1.1.0 0.0.0.255 any
access-list 105 permit ip 10.1.10.0 0.0.0.255 any
snmp-server community public RO
tftp-server apps11.8-2-2TR2.sbn
tftp-server dsp70.8-2-2TR2.sbn
tftp-server jar11sccp.8-2-2TR2.sbn
tftp-server jar31sccp.8-2-2TR2.sbn
tftp-server flash:cnu42.8-3-1-22.sbn
tftp-server flash:cnu45.8-3-1-22.sbn
tftp-server flash:cnu75.8-3-1-22.sbn
tftp-server flash:cvm42sccp.8-3-1-22.sbn
tftp-server flash:cvm45sccp.8-3-1-22.sbn
tftp-server flash:WLAN-1.0.4.SBN
tftp-server flash:cp524g-08-01-07.bin
tftp-server DistinctiveRingList.xml
tftp-server RingList.xml
tftp-server flash:AreYouThereF.raw
tftp-server flash:Bass.raw
tftp-server flash:CallBack.raw
tftp-server flash:Chime.raw
tftp-server flash:Analog1.raw
tftp-server flash:Analog2.raw
tftp-server flash:AreYouThere.raw
tftp-server flash:CampusNight.png
tftp-server flash:CiscoFountain.png
tftp-server flash:Fountain.png
tftp-server flash:MorroRock.png
tftp-server flash:NantucketFlowers.png
tftp-server flash:TN-CampusNight.png
tftp-server apps31.8-2-2TR2.sbn
tftp-server apps41.8-2-2TR2.sbn
tftp-server apps70.8-2-2TR2.sbn
tftp-server cmterm_7936.3-3-13-0.bin
tftp-server cnu11.8-2-2TR2.sbn
tftp-server cnu31.8-2-2TR2.sbn
tftp-server cnu41.8-2-2TR2.sbn
tftp-server cnu70.8-2-2TR2.sbn
tftp-server CP7902080002SCCP060817A.sbin
tftp-server cvm11sccp.8-2-2TR2.sbn
tftp-server cvm31sccp.8-2-2TR2.sbn
tftp-server cvm41sccp.8-2-2TR2.sbn
tftp-server cvm70sccp.8-2-2TR2.sbn
tftp-server dsp11.8-2-2TR2.sbn
tftp-server dsp31.8-2-2TR2.sbn
tftp-server dsp41.8-2-2TR2.sbn
tftp-server jar41sccp.8-2-2TR2.sbn
tftp-server jar70sccp.8-2-2TR2.sbn
tftp-server P00308000500.bin
tftp-server P00308000500.loads
tftp-server P00308000500.sb2
tftp-server P00308000500.sbn
tftp-server S00105000200.sbn
tftp-server SCCP11.8-2-2SR2S.loads
tftp-server SCCP31.8-2-2SR2S.loads
tftp-server SCCP41.8-2-2SR2S.loads
tftp-server SCCP70.8-2-2SR2S.loads
tftp-server term06.default.loads
tftp-server term11.default.loads
tftp-server term31.default.loads
tftp-server term41.default.loads
tftp-server term61.default.loads
tftp-server term70.default.loads
tftp-server term71.default.loads
tftp-server flash:SCCP42.8-3-2S.loads
tftp-server flash:SCCP45.8-3-2S.loads
tftp-server flash:SCCP75.8-3-2S.loads
tftp-server flash:apps42.8-3-1-22.sbn
tftp-server flash:apps45.8-3-1-22.sbn
tftp-server flash:apps75.8-3-1-22.sbn
tftp-server flash:cvm75sccp.8-3-1-22.sbn
tftp-server flash:dsp42.8-3-1-22.sbn
tftp-server flash:dsp45.8-3-1-22.sbn
tftp-server flash:dsp75.8-3-1-22.sbn
tftp-server flash:jar42sccp.8-3-1-22.sbn
tftp-server flash:jar45sccp.8-3-1-22.sbn
tftp-server flash:jar75sccp.8-3-1-22.sbn
tftp-server flash:term42.default.loads
tftp-server flash:term45.default.loads
tftp-server flash:term62.default.loads
tftp-server flash:term65.default.loads
tftp-server flash:term75.default.loads
tftp-server flash:APPS-1.0.4.SBN
tftp-server flash:CP7921G-1.0.4.LOADS
tftp-server flash:GUI-1.0.4.SBN
tftp-server flash:SYS-1.0.4.SBN
tftp-server flash:TNUX-1.0.4.SBN
tftp-server flash:TNUXR-1.0.4.SBN
tftp-server flash:Classic1.raw
tftp-server flash:Classic2.raw
tftp-server flash:ClockShop.raw
tftp-server flash:Drums1.raw
tftp-server flash:Drums2.raw
tftp-server flash:FilmScore.raw
tftp-server flash:HarpSynth.raw
tftp-server flash:Jamaica.raw
tftp-server flash:KotoEffect.raw
tftp-server flash:MusicBox.raw
tftp-server flash:Piano1.raw
tftp-server flash:Piano2.raw
tftp-server flash:Pop.raw
tftp-server flash:Pulse1.raw
tftp-server flash:Ring1.raw
tftp-server flash:Ring2.raw
tftp-server flash:Ring3.raw
tftp-server flash:Ring4.raw
tftp-server flash:Ring5.raw
tftp-server flash:Ring6.raw
tftp-server flash:Ring7.raw
tftp-server flash:Sax1.raw
tftp-server flash:Sax2.raw
tftp-server flash:Vibe.raw
tftp-server flash:ash:Morropng
tftp-server flash:Nantucck.png
tftp-server flash:TN-Nantucket20x212x16/List.xml
tftp-server flash:ash:Desktops/320x216x16/List.xml
tftp-server flash:cp524g-08-01-13.bin
control-plane
bridge 1 route ip
bridge 100 route ip
voice-port 0/0/0
voice-port 0/0/1
voice-port 0/0/2
timeouts ringing infinity
voice-port 0/0/3
voice-port 0/1/0
trunk-group ALL_FXO
connection plar opx 400
description Configured by CCA Auto Attendant
caller-id enable
voice-port 0/1/1
trunk-group ALL_FXO
caller-id enable
voice-port 0/1/2
trunk-group ALL_FXO
caller-id enable
voice-port 0/1/3
trunk-group ALL_FXO
voice-port 0/4/0
auto-cut-through
signal immediate
input gain auto-control -15
description Music On Hold Port
sccp local Loopback0
sccp ccm 10.1.1.1 identifier 1
sccp
sccp ccm group 1
associate ccm 1 priority 1
dial-peer cor custom
name internal
name local
name domestic
name international
name local-plus
name national
name national-plus
name emergency
name toll-free
dial-peer cor list call-internal
member internal
dial-peer cor list call-local
member local
dial-peer cor list call-domestic
member domestic
dial-peer cor list call-international
member international
dial-peer cor list user-internal
member internal
member emergency
dial-peer cor list user-local
member internal
member local
member emergency
member toll-free
dial-peer cor list user-domestic
member internal
member local
member domestic
member local-plus
member national
member emergency
member toll-free
dial-peer cor list user-international
member internal
member local
member domestic
member local-plus
member national
member national-plus
member emergency
member toll-free
dial-peer cor list call-local-plus
member local-plus
dial-peer cor list call-national
member national
dial-peer cor list call-national-plus
dial-peer cor list call-emergency
member emergency
dial-peer cor list call-toll-free
member toll-free
dial-peer cor list user-local-plus
member internal
member local
member local-plus
member emergency
member toll-free
dial-peer cor list user-national
member internal
member local
member domestic
member local-plus
member national
member emergency
member toll-free
dial-peer cor list user-national-plus
member internal
member local
member domestic
member local-plus
member national
member emergency
member toll-free
dial-peer voice 1 pots
service stcapp
port 0/0/0
dial-peer voice 2 pots
service stcapp
port 0/0/1
dial-peer voice 3 pots
service stcapp
port 0/0/2
dial-peer voice 50 pots
description ** incoming dial peer **
incoming called-number .%
port 0/1/0
dial-peer voice 51 pots
port 0/1/1
dial-peer voice 55 pots
corlist outgoing call-domestic
description ** FXO pots dial-peer **
translation-profile outgoing CALLER_ID_TRANSLATION_PROFILE
preference 5
destination-pattern 91[2-9]..[2-9]......
port 0/1/0
prefix 1
no sip-register
dial-peer voice 56 pots
corlist outgoing call-international
preference 5
destination-pattern 9011T
port 0/1/0
forward-digits 7
prefix 011
no sip-register
dial-peer voice 59 pots
preference 5
port 0/1/1
prefix 1
no sip-register
dial-peer voice 60 pots
preference 5
port 0/1/1
prefix 011
no sip-register
dial-peer voice 62 pots
corlist outgoing call-local
preference 5
destination-pattern 9[2-9]......
port 0/1/2
forward-digits 7
no sip-register
dial-peer voice 63 pots
preference 5
port 0/1/2
forward-digits 3
prefix 1
no sip-register
dial-peer voice 66 pots
preference 5
port 0/1/3
forward-digits 7
prefix 011
no sip-register
dial-peer voice 69 pots
preference 5
destination-pattern 9[2-9]11
port 0/1/3
forward-digits 3
no sip-register
dial-peer voice 4 pots
service stcapp
port 0/0/3
dial-peer voice 5 pots
description ** MOH Port **
destination-pattern ABC
port 0/4/0
no sip-register
dial-peer voice 2000 voip
description ** cue voicemail pilot number **
destination-pattern 401
b2bua
session protocol sipv2
session target ipv4:10.1.10.1
dtmf-relay sip-notify
codec g711ulaw
no vad
dial-peer voice 2001 voip
description ** cue auto attendant number **
translation-profile outgoing PSTN_CallForwarding
destination-pattern 400
b2bua
codec g711ulaw
no vad
dial-peer voice 52 pots
port 0/1/2
dial-peer voice 53 pots
port 0/1/3
dial-peer voice 54 pots
preference 5
port 0/1/0
forward-digits 7
no sip-register
dial-peer voice 57 pots
preference 5
port 0/1/0
forward-digits 3
no sip-register
dial-peer voice 58 pots
preference 5
port 0/1/1
forward-digits 7
no sip-register
dial-peer voice 61 pots
preference 5
port 0/1/1
forward-digits 3
no sip-register
dial-peer voice 64 pots
preference 5
port 0/1/2
prefix 011
no sip-register
dial-peer voice 65 pots
preference 5
port 0/1/2
forward-digits 3
no sip-register
dial-peer voice 67 pots
preference 5
port 0/1/3
prefix 1
no sip-register
dial-peer voice 68 pots
preference 5
port 0/1/3
prefix 011
no sip-register
no dial-peer outbound status-check pots
telephony-service
video
max-ephones 22
max-dn 88
ip source-address 10.1.1.1 port 2000
auto assign 1 to 1 type bri
calling-number initiator
service phone videoCapability 1
service dnis overlay
service dnis dir-lookup
timeouts interdigit 5
system message IYS
url services http://10.1.10.1/voiceview/common/login.do
url authentication http://10.1.10.1/voiceview/authentication/authenticate.do
time-zone 12
voicemail 401
max-conferences 8 gain -6
call-forward pattern .T
call-forward system redirecting-expanded
moh music-on-hold.au
multicast moh 239.10.16.16 port 2000
web admin system name cisco secret 5 $1$.vjf$Z7NkttuoPiF7927xuB.661
dn-webedit
time-webedit
transfer-system full-consult dss
transfer-pattern 9.T
transfer-pattern .T
secondary-dialtone 9
create cnf-files version-stamp Jan 01 2002 00:00:00
ephone-template  15
softkeys remote-in-use  Newcall
softkeys idle  Redial Newcall Cfwdall Pickup Gpickup Dnd Login
softkeys seized  Cfwdall Endcall Redial Pickup Gpickup Callback
softkeys connected  Hold Endcall Trnsfer Confrn Acct Park
button-layout 7931 2
ephone-template  16
ephone-template  17
softkeys remote-in-use  CBarge Newcall
ephone-template  18
ephone-dn  1
number 101 no-reg primary
name IP-Paging1
paging ip 239.1.1.1 port 2000
ephone-dn  5  dual-line
number 301 no-reg primary
label 301
description PhoneA Analog
name PhoneA Analog
call-forward busy 401
call-forward noan 401 timeout 10
ephone-dn  6  dual-line
number 302 no-reg primary
label 302
description PhoneB Analog
name PhoneB Analog
ephone-dn  7  dual-line
number 303 no-reg primary
label 303
description PhoneC Analog
name PhoneC Analog
ephone-dn  8  dual-line
number 304 no-reg primary
label 304
description PhoneD Analog
name PhoneD Analog
ephone-dn  9
number BCD no-reg primary
description MoH
moh out-call ABC
ephone-dn  10  dual-line
number 201 no-reg primary
label 201
description Receptionist Desk
name Receptionist Desk
call-forward all 202
call-forward noan 401 timeout 20
ephone-dn  11  dual-line
number 202 no-reg primary
label 202
description Sabrina Davis
name Sabrina Davis
ephone-dn  12  dual-line
number 203 no-reg primary
label 203
description Margaret Duke
name Marlene Jackson
ephone-dn  13  dual-line
number 204 no-reg primary
label 204
description Doris Street
name Linda Durham
ephone-dn  14  dual-line
number 205 no-reg primary
label 205
description Greg Brown
name Greg Brown
call-forward noan 401 timeout 25
ephone-dn  15  dual-line
number 206 no-reg primary
label 206
description Spare Phone
name Spare Phone
ephone-dn  16  dual-line
number 207 no-reg primary
label 207
description Marlene Jackson
name Spare Spare
ephone-dn  17  dual-line
number 208 no-reg primary
label 208
name Spare Phone
ephone-dn  18  dual-line
number 209 no-reg primary
label 209
description James Hunter
name James Hunter
ephone-dn  19  dual-line
number 210 no-reg primary
label 210
description Jefferson Porter
name Spare Spare
ephone-dn  20  dual-line
number 211 no-reg primary
label 211
description Carol Brown
name Carol Brown
ephone-dn  21  dual-line
number 212 no-reg primary
label 212
name Spare Phone
ephone-dn  22  dual-line
number 213 no-reg primary
label 213
description Meeting Room
name Meeting Room
ephone-dn  23  dual-line
number 214 no-reg primary
label 214
description Conference Room
name Conference Room
ephone-dn  24  dual-line
number 299 no-reg primary
label 299
description Strategic Solutions
name Strategic Solutions
ephone-dn  25  dual-line
number 216 no-reg primary
label 216
name Spare Phone
ephone-dn  26  dual-line
number 217 no-reg primary
label 217
name Spare Phone
ephone-dn  27  dual-line
number 218 no-reg primary
label 218
description 218
name 218
ephone-dn  28
number 500
label GDM
description GDM
name GDM
hold-alert 30 originator
ephone-dn  87
number A801... no-reg primary
mwi off
ephone-dn  88
number A800... no-reg primary
mwi on
ephone  1
device-security-mode none
mac-address 333C.946A.0000
max-calls-per-button 2
username "aa"
type anl
button  1:5
ephone  2
mac-address 333C.946A.0001
username "ab"
type anl
button  1:6
ephone  3
mac-address 333C.946A.0002
username "ac"
type anl
button  1:7
ephone  4
mac-address 333C.946A.0003
username "ad"
type anl
button  1:8
ephone  5
video
mac-address 0021.A0D9.7AB2
username "recept" password 12345
paging-dn 1
type 7961GE
button  1:10
ephone  6
video
mac-address 0024.14B4.29C3
username "sdavis" password 12345
fastdial 1 98142647 name Sabrina Davis
paging-dn 1
type 7970
button  1:11
ephone  7
video
mac-address 0024.14B4.2A5B
ephone-template 16
username "mduke" password trouble
type 7970
button  1:12
ephone  8
video
mac-address 0024.14B4.2AB1
ephone-template 16
username "nhubbard" password nadine
paging-dn 1
type 7970
button  1:13 2m28
ephone  9
video
mac-address 0024.14B4.2B02
username "gbrown" password 12345
paging-dn 1
type 7970
button  1:14
ephone  10
video
mac-address 0021.1BFC.88BF
ephone-template 16
username "Spare5" password 12345
type 524G
button  1:15
ephone  11
video
mac-address 0021.1BFC.88BB
ephone-template 16
username "mjackson" password Spare
type 524G
button  1:16
ephone  12
video
mac-address 0021.1BFC.88BC
ephone-template 16
username "Spare4" password 12345
type 524G
button  1:17
ephone  13
video
mac-address 0021.1BFC.88BE
ephone-template 16
username "bmiles" password 55555
type 524G
button  1:18
ephone  14
video
mac-address 0021.1BFC.88C0
ephone-template 16
username "jporter" password spare
type 524G
button  1:19
ephone  15
video
mac-address 0021.1BFC.88BD
username "cbrown" password 54321
paging-dn 1
type 524G
button  1:20
ephone  16
video
mac-address 0021.1BFC.88C3
ephone-template 16
username "spare1" password 12345
type 524G
button  1:21
ephone  17
video
mac-address 0021.1BFC.88C2
username "meetingrm" password 12345
paging-dn 1
type 524G
button  1:22
ephone  18
video
mac-address 0004.F2E1.ED89
username "conference"
paging-dn 1
type 7937
button  1:23
ephone  19
video
mac-address 001F.E152.F1FF
username "ssva"
paging-dn 1
mtp
type CIPC
button  1:24
ephone  20
video
mac-address 0021.706B.57FD
ephone-template 16
username "spare2"
mtp
type CIPC
button  1:25
ephone  21
video
mac-address 0021.7084.AFA8
ephone-template 16
username "spare3"
mtp
type CIPC
button  1:26
banner login ^CCCisco Configuration Assistant. Version: 1.8. Wed Apr 01 15:26:01 EDT 2009^C
line con 0
exec-timeout 0 0
no modem enable
line aux 0
line 2
no activation-character
no exec
transport preferred none
transport input all
line vty 5 100
ntp master
end
Community Member
Re: URGENT!! NEED HELP CONFIGURING AN AUTO ATTENDANT SCRIPT USIN
How do you want to auto attendant to flow? What options? Dial by name? First or last? You need to provide details for options on Auto attendant. What version of CUE?
To use CCA or Web GUI to setup you need access to the UC. If you want to use CUE Editor then we need to know the version of CUE.
Community Member
That is my exact dilemna. The client swears that they DO NOT HAVE ANY other than CCA 3.1 on site. The client did not mention Cisco Unity Express or anything other application in the environment in which they use to make VoIP changes. The client did not configure the auto attendant script that is now corrupted. I believe they hired someone to do it for them. I am hired to pretty much clean up their VoIP nightmare. I remember reading something in the CCA manual that you can modify the auto attendant settings in CCA.
What I am asking is, with what I have (the configuration only), is there a way in IOS that I can configure an auto attendant script INTO the configuration, copy the config and it go live after a copy run start, per se.
Thank you in advance for all that take the time in providing me with the insight I need to complete this.
Community Member
AA scripts don't exist in CME, only CUE and even then I'm pretty sure you can't write a script in a the CLI interface for CUE.  Mario is pretty much giving you your two main options to do it on the unit.  An alternative that I've used before is to write the script on another 500 unit and then download and upload it to the one affected, but it takes a little planning to make sure you do the steps in the right order if you're using CLI.  Mario is also correct, you need to have access to the UC in order to affect ANY of the solutions.  The CME config looks pretty default, you should be able to access the CUE GUI by going to http://10.1.10.1 the username and password MIGHT be the same as the one used for the UC admin, depending on how it is setup.  This is your best option.
Community Member
Trying to access that URL is not working. First thank you Bryan and Mario for even answering my question. I really need help. So CUE runs on the router right now? I know that ip is configured for the integrated service module. What I want to know now is, is there someone I can get a sample script from a UC500 and modify it based on my configuration. What do I need to use to edit the file, save and so forth? Is there a simple guide that can walk me through what to look for in the config to apply to the script just for a basic aa script?
I need this done today so any help you give...I'm definitely using.
Community Member
You have to use either the script editor or the GUI to even edit the script, so that's why I was suggesting using the GUI because frankly, it's the easiest and quickest way. Yes, CUE does run on the UC520 as a module, that's why you have to have Dial-Peers and loopback interfaces to access it, but that's all there and you shouldn't worry about it.  You can't perse edit an existing script without using one of the tools/options above.
If you can't access the URL from a PC, it may be a simple gateway issue.  I have many installations that the gateway for the network is not the UC520 (192.168.10.1 in your case) but another firewall/router/server/etc.  You can simply add a route into the command line of the PC:  route add 10.1.10.0 mask 255.255.255.0 192.168.10.1
Copy and past the above into the command interface on the PC and try the URL again, this may solve the access issue.
Community Member
I should have mentioned that I am not on the internal network. I'm on another network at this time so that route wouldn't work for what I'm trying to accomplish. So about the script editor...is it possible for me to acquire
1) The script editor via download (had issues finding the appropriate download link yesterday)
2) A sample UC500 script that I can edit
3) A guide for me to use that will show me what the script really means and how I can take the information contained in my config and apply it to a modified script.
I would then want to upload that script to my problem environment to see if it works.
Thanks Bryan. I can't thank you enough.
Community Member
Your better off going onsite and using either CCA or Web GUI.  Since you do not have experience with this the CUE Editor will only make things more complicated.  Onsit should take you about 10-15 minutes max to setup, with CUE Editor could take you hours.
Community Member
Actually, if you're using VPN to access the network, it still will work, it's how I manage all of mine.
1) Script editor is going to be dependent on the version of CUE you have on the UC.  If you can, run a sho ver on the CUE side of the UC.  This will give you the version for CUE.
2) I've attached a copy of one of the default scripts from the latest software pack.
3)  This is the first one I could find for the script editor, but I couldn't find a great one for CUE off-hand.  I know there is one around. You might also look on Youtube.  Most of the VOD's that Cisco has put out can be seen there as well for the UC series.
http://www.cisco.com/en/US/partner/docs/voice_ip_comm/unity_exp/rel3_2/administrator/script/aasamp.html
The crux of it all is that you're going to have to access the CUE module to upload the script.  If you can get that access fixed, you'll be able to access the GUI and things will go a lot quicker and smoother.
967
