Community Member
VM Timestamping
This is probably a simple fix, but I can't seem to find it.
When a VM is left it gets a timestamp. When that message is forwarded to another user the timestamp seems to be overwritten. Is there a way to keep the original timestamp for the VM, or is there a quick way to retrieve it?
Jorge
1 ACCEPTED SOLUTION
Community Member
Re: VM Timestamping
Unfortunately, there's no way to play the original timestamp for a forwarded message.
Marcos Hernandez
Technical Marketing Engineer
Cisco Systems, Inc.
Community Member
Re: VM Timestamping
Marcos Hernandez
Cisco Systems, Inc.
Community Member
Re: VM Timestamping
That stinks. But thanks for the response, I'll let my client know.
4169
