Users might experience few discrepancies in Search results. We are working on this on our side. We apologize for the inconvenience it may have caused.
VPN ID settings on SPA-942
Does anybodu know if its possible to configure VPN ID on SPA-942.
For example if the  customer has two separate VPN (VPN ID1 and VPN ID2) and wants his computer to  run over VPN ID2. Is it possile to configure the SPA-942 to communicate over VPN  ID1?
//Anna
Everyone's tags (1)
Silver
Re: VPN ID settings on SPA-942
If you login to the phone, you can set it manually under the system tab.
System  Configuration
Restricted Access Domains:
Enable Web Server:Web Server Port:
Enable Web Admin Access:Admin Passwd:
User Password:
Internet  Connection Type
Connection Type:
Static IP Settings
Static IP:NetMask:
Gateway:
PPPoE Settings
PPPoE Login Name:PPPoE  Login Password:
PPPoE Service Name:
Optional  Network Configuration
HostName:Domain:
Primary DNS:Secondary  DNS:
DNS Server Order:DNS  Query Mode:
Syslog Server:Debug  Server:
Debug Level:Primary  NTP Server:
Secondary NTP Server:
VLAN  Settings
Enable VLAN:Enable CDP:
VLAN ID:PC  Port VLAN Highest Priority:
Enable PC Port VLAN Tagging:PC Port VLAN  ID:
I do not have the PC-port parameters on my SPA. Do I have an old firmware maybe? We currently run on 5.2.8.
The only VLAN-settings I can change are Enable VLAN, VLAN ID and Enable CDP
Works fine now after firmwareupgrade
1637
