VPN issue to UC500 CUE with release 8.x
My partner continues to have VPN issue to the CUE via a browser or pinging the CUE address.    As a remote user they can gain access to their internal network, they can surf the Internet (split tunnel) but they cannot get to CUE.  This worked fine on 7.x software and only noticed this when going to 8.0.
I couldn't find any previous cases with this decription, any suggestions.
- Vern
1 REPLY
Community Member
Re: VPN issue to UC500 CUE with release 8.x
Hi Vern,
You might need to check and make sure CCA placed the following in your configuration after you upgraded:
ip nat inside source list 1 interface FastEthernet0/0 overload
ip route 10.1.10.1 255.255.255.255 Integrated-Service-Engine0/0
That's the first place I would start, if still no go we will then need to see how the VPN traffic is being routed.
Cheers,
David.
Cheers, David Trad. **When you rate a persons post, you are indicating a thank you or that it helped, but at the same time you are also helping to maintain the community spirit - You don't have to rate posts and you wont be looked down upon :) *
180
