When a SPA8800 is added to a UC320 can I then use more than 4 SIP trunks?
Everyone's tags (2)
1 ACCEPTED SOLUTION
Re: When a SPA8800 is added to a UC320 can I then use more than
No, the presence or absence of SPA8800s in the system does not affect the number of SIP trunks you can have - it is still four.  The FXO ports do contribute to the overall maximum number of simultaneous active calls supported by the system though, so you need to take that into account in your design.
And you will get quicker responses if you post UC300 questions in the corresponding community as per the other Dave's post.
Cheers,
Dave.
Hi Paul,
Just letting you know that there is a UC300 series forum HERE which should get you a more specific answer in there than in the UC500 forums.
Cheers,
David.
Cheers, David Trad. **When you rate a persons post, you are indicating a thank you or that it helped, but at the same time you are also helping to maintain the community spirit - You don't have to rate posts and you wont be looked down upon :) *
Cheers,
Dave.
Silver
I have moved this thread from the SBCS-UC500 area to the UC300 area.
Cindy Toy
Cisco Small Business
Community Manager
Regards, Cindy If my response answered your question, please mark the response as answered. Thank you!
David, thank you for your answer, and sorry for the post location.
Regards, Paul
868
