Community Member
XML Service example (text example) does not work on 502/504 (7.4.3) OK on 525G
test:
<CiscoIPPhoneText>
  <Title>Cisco XML Test Message Demo</Title>
  <Prompt />
  <Text>Please join us for John's Birthday Celebration in the cafeteria</Text>
</CiscoIPPhoneText>
addied to the phone as a soft key   -  fnc=xml;url=http://xxx.xxx.com/sipura/text.py;nme=test
  • on 525G John's Birthday Message is displayed and have Update and Exit softkeys displayed (expected behavior)
  • of 504G Message is displayed and status of Requesting.....  shown and CANCEL softkey
Re: XML Service example (text example) does not work on 502/504
Hi Doctor;
Thanks for highlighting...I'll escalate it to check if it is a bug.
regards
Alberto
Dear Sir;
Defect with bug id CSCtf13705 has been created. Stay tuned for resolution.
Regards and thanks for highlighting this and helping us to make our products better.
Alberto
Dear Doctor;
Defect has been resolved. I have a test firmware I would like you to test to verify the solution is ok for you. Please ping me at amontill at cisco dot com for providing you the test firmware.
Regards;
Alberto
Community Member
this now works on 502/504 running 7.4.4
Stuart
Hi Stuart;
Thanks for your feedback to help us improve on quality.
Alberto
Community Member
You can use the MyServices app on the iPhone to test your application
2840
