cancelar
Mostrar resultados para
Pesquisar em vez de
Queria dizer:
Comunicados
Bem-vindo à Comunidade de Suporte da Cisco, gostaríamos de ter seus comentários.
Problema certificados
Boa tarde,
Tenho este problema relativamente aos certificados dos meus callmanagers.
"At Wed Jul 15 13:00:29 WEST 2015 on node 10.95.194.31; the following SyslogSeverityMatchFound events generated:  SeverityMatch - Emergency : 60438: Jul 15 12:00:00.88 UTC :  %CCM_UNKNOWN-CERT-0-CertExpiryEmergency: Certificate Expiry EMERGENCY_ALARM  Message:Certificate expiration Notification. Certificate name:tomcat Unit:tomcat Type:own-cert Expiration:Tue Jul 22 20:05:04:000 WEST 20 App ID:Cisco Certificate Monitor Cluster ID: Node ID:SC1V-UCM1   SeverityMatch - Emergency : 60439: Jul 15 12:00:00.88 UTC :  %CCM_UNKNOWN-CERT-0-CertExpiryEmergency: Certificate Expiry EMERGENCY_ALARM  Message:Certificate expiration Notification. Certificate name:ipsec Unit:ipsec Type:own-cert Expiration:Tue Jul 22 20:05:06:000 WEST 2014 App ID:Cisco Certificate Monitor Cluster ID: Node ID:SC1V-UCM1   SeverityMatch - Emergency : 60440: Jul 15 12:00:00.89 UTC :  %CCM_UNKNOWN-CERT-0-CertExpiryEmergency: Certificate Expiry EMERGENCY_ALARM  Message:Certificate expiration Notification. Certificate name:CallManager Unit:CallManager Type:own-cert Expiration:Tue Jul 22 20:16:50:0 App ID:Cisco Certificate Monitor Cluster ID: Node ID:SC1V-UCM1   SeverityMatch - Emergency : 60441: Jul 15 12:00:00.90 UTC :  %CCM_UNKNOWN-CERT-0-CertExpiryEmergency: Certificate Expiry EMERGENCY_ALARM  Message:Certificate expiration Notification. Certificate name:CAPF Unit:CAPF Type:own-cert Expiration:Tue Jul 22 20:16:51:000 WEST 2014 / App ID:Cisco Certificate Monitor Cluster ID: Node ID:SC1V-UCM1   SeverityMatch - Emergency : 60442: Jul 15 12:00:00.90 UTC :  %CCM_UNKNOWN-CERT-0-CertExpiryEmergency: Certificate Expiry EMERGENCY_ALARM  Message:Certificate expiration Notification. Certificate name:DCV-UCM1 Unit:ipsec-trust Type:trust-cert Expiration:Tue Jul 22 19:31:24:00 App ID:Cisco Certificate Monitor Cluster ID: Node ID:SC1V-UCM1   SeverityMatch - Emergency : 60443: Jul 15 12:00:00.91 UTC :  %CCM_UNKNOWN-CERT-0-CertExpiryEmergency: Certificate Expiry EMERGENCY_ALARM  Message:Certificate expiration Notification. Certificate name:CAPF-0e8921c2 Unit:CallManager-trust Type:trust-cert Expiration:Tue Jul 22  App ID:Cisco Certificate Monitor Cluster ID: Node ID:SC1V-UCM1   SeverityMatch - Emergency : 60444: Jul 15 12:00:00.91 UTC :  %CCM_UNKNOWN-CERT-0-CertExpiryEmergency: Certificate Expiry EMERGENCY_ALARM  Message:Certificate expiration Notification. Certificate name:CAPF-0e8921c2 Unit:CAPF-trust Type:trust-cert Expiration:Tue Jul 22 20:16:5 App ID:Cisco Certificate Monitor Cluster ID: Node ID:SC1V-UCM1"
Alguma diga como resolver?
Obrigado.
2 RESPOSTAS
Olá José Luiz,Pelo logs o
Olá José Luiz,
Pelo logs o certificado do CAPF do CUCM expirou.
Verifique este documento com os passos necessários para resolver o seu problema:
http://www.cisco.com/cisco/web/support/BR/112/1121/1121863_117299-problemsolution-product-00.html
Att
Leonardo Santana
Obrigado Leonardo :)
50
Apresentações
Útil
Respostas
CriarFaça o para criar o conteúdo
