cancelar
Mostrar resultados para
Pesquisar em vez de
Queria dizer:
Comunicados
Bem-vindo à Comunidade de Suporte da Cisco, gostaríamos de ter seus comentários.
Problema R2 digital
Pessoal, estou com um problema no meu R2, ao entrar e sair chamadas para a PSTN. Este mesmo R2 estava configurado em uma central MD e funciona normal, mas ao colocar este link no router eu tenho esse problema.
Vejam a minha configuração da controller e do debug vpm signal.
controller E1 0/0/1
 framing NO-CRC4
 line-termination 75-ohm
 ds0-group 0 timeslots 1-15,17-31 type r2-digital r2-compelled ani
 cas-custom 0
  country brazil use dafult
  double-answer
  category 2
  answer-signal group-b 1
  dnis-complete
   1408938 ORG     T0     None        TELE        P#9#0947374856                          D1F
ra084377.oco.brad#sh call history voice callid 1408938
Telephony call-legs: 1
SIP call-legs: 0
H323 call-legs: 0
Call agent controlled call-legs: 0
Total call-legs: 1
GENERIC:
SetupTime=908936660 ms (13:05:37.896 BR Fri Jan 8 2016)
Index=195211
PeerAddress=#9#0947374856
PeerSubAddress=
PeerId=24
PeerIfIndex=332
LogicalIfIndex=328
DisconnectCause=1F
DisconnectText=normal unspecified (31)
ConnectTime=0 ms (0)
DisconnectTime=908965390 ms (13:06:06.626 BR Fri Jan 8 2016)
CallDuration=00:00:00 sec
CallOrigin=1
ReleaseSource=3
ChargedUnits=0
InfoType=speech
TransmitPackets=0
TransmitBytes=0
ReceivePackets=0
ReceiveBytes=0
TELE:
ConnectionId=[0x4731D600 0x10000 0xD0BDF 0x66E1C70A]
IncomingConnectionId=[0x4731D600 0x10000 0xD0BDF 0x66E1C70A]
CallID=1408938
Port=0/0/1:0 (1408938)
BearerChannel=0/0/1.1
TxDuration=0 ms
VoiceTxDuration=0 ms
FaxTxDuration=0 ms
CoderTypeRate=None
NoiseLevel=0
ACOMLevel=0
SessionTarget=
ImgPages=0
CallerName=Fernando Penteado
CallerIDBlocked=False
Target tg label=OCO_VIVO
LongDurationCallDetected=no
LongDurCallTimeStamp=
LongDurCallDuration=
OriginalCallingNumber=31000
OriginalCallingOctet=0x0
OriginalCalledNumber=#9#0947374856
OriginalCalledOctet=0x0
OriginalRedirectCalledNumber=
OriginalRedirectCalledOctet=0x80
TranslatedCallingNumber=31000
TranslatedCallingOctet=0x0
TranslatedCalledNumber=#9#0947374856
TranslatedCalledOctet=0x0
TranslatedRedirectCalledNumber=
TranslatedRedirectCalledOctet=0x80
GwReceivedCalledNumber=#9#0947374856
GwReceivedCalledOctet3=0x0
GwOutpulsedCalledNumber=947374856
GwOutpulsedCalledOctet3=0x0
GwReceivedCallingNumber=31000
GwReceivedCallingOctet3=0x0
GwReceivedCallingOctet3a=0x81
GwOutpulsedCallingNumber=31000
GwOutpulsedCallingOctet3=0x0
GwOutpulsedCallingOctet3a=0x81
DSPIdentifier=0/2:6
MlppServiceDomainNW=0 (none)
MlppServiceDomainID=0
PrecedenceLevel=-1 (PRECEDENCE_LEVEL_NONE)
ra084377.oco.brad#
Jan  8 14:19:17: htsp_timer_stop3 htsp_setup_req
Jan  8 14:19:17:  Orig called num:#9#0947374856
Jan  8 14:19:17: htsp_process_event: [0/0/1:0(1), R2_Q421_IDLE, E_HTSP_SETUP_REQ]
Jan  8 14:19:17: r2_q421_seize(0/0/1:0(1)) E_HTSP_SETUP_REQ DNIS=947374856 ANI=31000
Jan  8 14:19:17: r2_q421_seize(0/0/1:0(1)) Tx SEIZUREvnm_dsp_set_sig_state:[R2 Q.421 0/0/1:0(1)] set signal state = 0x0
Jan  8 14:19:17: htsp_timer - 5000 msec
Jan  8 14:19:17: htsp_process_event: [0/0/1:0(1), R2_Q421_OG_SEIZE, E_DSP_SIG_1100]
Jan  8 14:19:17: r2_q421_seize_ack(0/0/1:0(1)) Rx SEIZE ACK
Jan  8 14:19:17: r2_reg_start_dialing(0/0/1:0(1))
Jan  8 14:19:17: r2_reg_process_event: [0/0/1:0(1), R2_REG_IDLE, E_R2_REG_START_DIAL(93)]
Jan  8 14:19:17: r2_reg_start_dial_delay(0/0/1:0(1)) dialout delay 200
Jan  8 14:19:17: r2_reg_timer(0/0/1:0(1)) 200 msec
Jan  8 14:19:17: r2_reg_process_event: [0/0/1:0(1), R2_REG_IDLE, E_R2_REG_EVENT_TIMER(86)]
Jan  8 14:19:17: r2_reg_start_dial(0/0/1:0(1))
Jan  8 14:19:17: R2 Outgoing Voice(0/1): DSX (E1 0/0/1:0): STATE: R2_OUT_IDLE R2 Got Event R2_START
Jan  8 14:19:17: r2_reg_generate_digits(0/0/1:0(1)): Tx digit '#'
Jan  8 14:19:17: r2_reg_generate_digits(0/0/1:0(1)): Tx digit '9'
Jan  8 14:19:17: htsp_digit_ready_up(0/0/1:0(1)): Rx digit='1'
Jan  8 14:19:17: R2 Outgoing Voice(0/1): DSX (E1 0/0/1:0): STATE: R2_OUT_PROCESS_A R2 Got Event 1
Jan  8 14:19:17: htsp_digit_ready(0/0/1:0(1)): Rx digit='#'
Jan  8 14:19:17: R2 Outgoing Voice(0/1): DSX (E1 0/0/1:0): STATE: R2_OUT_PROCESS_A R2 Got Event R2_TONE_OFF
Jan  8 14:19:17: r2_reg_generate_digits(0/0/1:0(1)): Tx digit '4'
Jan  8 14:19:17: r2_reg_generate_digits(0/0/1:0(1)): Tx digit '7'
Jan  8 14:19:18: htsp_digit_ready_up(0/0/1:0(1)): Rx digit='1'
Jan  8 14:19:18: R2 Outgoing Voice(0/1): DSX (E1 0/0/1:0): STATE: R2_OUT_PROCESS_A R2 Got Event 1
Jan  8 14:19:18: r2_reg_generate_digits(0/0/1:0(1)): Tx digit '#'
Jan  8 14:19:18: htsp_digit_ready(0/0/1:0(1)): Rx digit='#'
Jan  8 14:19:18: R2 Outgoing Voice(0/1): DSX (E1 0/0/1:0): STATE: R2_OUT_PROCESS_A R2 Got Event R2_TONE_OFF
Jan  8 14:19:18: r2_reg_generate_digits(0/0/1:0(1)): Tx digit '3'
Jan  8 14:19:18: r2_reg_generate_digits(0/0/1:0(1)): Tx digit '7'
Jan  8 14:19:18: r2_reg_generate_digits(0/0/1:0(1)): Tx digit '4'
Jan  8 14:19:18: r2_reg_generate_digits(0/0/1:0(1)): Tx digit '8'
Jan  8 14:19:18: r2_reg_generate_digits(0/0/1:0(1)): Tx digit '5'
Jan  8 14:19:18: r2_reg_generate_digits(0/0/1:0(1)): Tx digit '6'
Jan  8 14:19:22: htsp_digit_ready_up(0/0/1:0(1)): Rx digit='3'
Jan  8 14:19:22: R2 Outgoing Voice(0/1): DSX (E1 0/0/1:0): STATE: R2_OUT_PROCESS_A R2 Got Event 3
Jan  8 14:19:22: r2_reg_generate_digits(0/0/1:0(1)): Tx digit '#'
Jan  8 14:19:22:  Check collect call pattern for Brazil
Jan  8 14:19:22:  collect call pattern not configured!!
Jan  8 14:19:22: htsp_digit_ready(0/0/1:0(1)): Rx digit='#'
Jan  8 14:19:22: R2 Outgoing Voice(0/1): DSX (E1 0/0/1:0): STATE: R2_OUT_PROCESS_B R2 Got Event R2_TONE_OFF
Jan  8 14:19:22: r2_reg_generate_digits(0/0/1:0(1)): Tx digit '2'un
Jan  8 14:19:24: htsp_timer_stop3
Jan  8 14:19:24: htsp_process_event: [0/0/1:0(1), R2_Q421_OG_SEIZE_ACK, E_DSP_DIALING_DONE]
Jan  8 14:19:24: r2_q421_dial_done(0/0/1:0(1)) E_HTSP_RELEASE_REQ
Jan  8 14:19:24: r2_reg_dial_done(0/0/1:0(1)d all
Jan  8 14:19:27: htsp_process_event: [0/0/1:0(1), R2_Q421_OG_SEIZE_ACK, E_HTSP_RELEASE_REQ]
Jan  8 14:19:27: r2_q421_clr_fwd(0/0/1:0(1)) E_HTSP_RELEASE_REQ
Jan  8 14:19:27: r2_reg_channel_disconnected(0/0/1:0(1))
Jan  8 14:19:27: R2 Outgoing Voice(0/1): DSX (E1 0/0/1:0): STATE: R2_OUT_PROCESS_B R2 Got Event R2_STOP
Jan  8 14:19:27: r2_q421_clr_fwd(0/0/1:0(1)) Tx CLEAR FWDvnm_dsp_set_sig_state:[R2 Q.421 0/0/1:0(1)] set signal state = 0x8
Jan  8 14:19:27: htsp_timer - 1000 msec
Jan  8 14:19:27: r2_reg_process_event: [0/0/1:0(1), R2_REG_DIALING, E_R2_REG_DISCONNECT(91)]
Jan  8 14:19:27: r2_reg_disconnect_dial(0/0/1:0(1))
Jan  8 14:19:27: R2 Outgoing Voice(0/1): DSX (E1 0/0/1:0): STATE: R2_OUT_IDLE R2 Got Event R2_STOP
Jan  8 14:19:27: r2_reg_timer_stop(0/0/1:0(1))
Jan  8 14:19:27: htsp_process_event: [0/0/1:0(1), R2_Q421_OG_CLR_FWD, E_DSP_SIG_1000]
Jan  8 14:19:27: r2_q421_clr_fwd_idle(0/0/1:0(1)) Rx IDLE
Jan  8 14:19:27: htsp_timer_stop
Jan  8 14:19:27: r2_q421_clr_fwd_idle(0/0/1:0(1)) Tx IDLEvnm_dsp_set_sig_state:[R2 Q.421 0/0/1:0(1)] set signal state = 0x8
Jan  8 14:19:27: r2_reg_process_event: [0/0/1:0(1), R2_REG_IDLE, E_R2_REG_DISCONNECT(91)]
Jan  8 14:19:27: r2_reg_disconnect_idle(0/0/1:0(1))erm no
Jan  8 14:19:27: r2_reg_timer_stop(0/0/1:0(1)) mon
ra084377.oco.brad#
ra084377.oco.brad#
ra084377.oco.brad#
ra084377.oco.brad#conf t
Enter configuration commands, one per line.  End with CNTL/Z.
ra084377.oco.brad(config)#controll
ra084377.oco.brad(config)#controller e1 0/0/1
3 RESPOSTAS
Segue configuração padrão
Segue configuração padrão para o Brasil:
controller E1 0/0
 framing NO-CRC4
 cas-custom 0
  country brazil
  category 2
No entanto, a operadora pode exigir alguma alteração nos parâmetros, é bom checar com ela.
Abs
Opa
Opa
Consegui com estes parâmetros
controller E1 0/1/1
framing NO-CRC4
cas-custom 0
  country brazil
  seizure-ack-time 50
  dnis-complete
  trunk-group OCO_VIVO
Para poder efetuar chamadas, tive que remover o category 2, e para poder receber chamadas eu tive que aplicar o seizure-ack-time 50.
Valeu
Outro ponto, a operadora está
Outro ponto, a operadora está esperando todos os dígitos enviados (contando o #9#) ?
71
Apresentações
Útil
Respostas
CriarFaça o para criar o conteúdo
