cancelar
Mostrar resultados para
Pesquisar em vez de
Queria dizer:
Comunicados
Bem-vindo à Comunidade de Suporte da Cisco, gostaríamos de ter seus comentários.
Telefones analogicos em porta FXS com recurso transferencia de chamada ativado
Ola pessoal
Possuo um roteador 2800 com uma placa com 4FXS e 4 FXO o meu tronco chega na porta fxo e tenho 4 ramais na porta FXS quero ativar o recurso de transferencia de chamada(call transfer) utilizando o seguinte link http://www.cisco.com/c/en/us/td/docs/ios/voice/fxs/configuration/guide/15_1/fxs_15_1_cg_book/fxssccpsplmft.html configurei meu roteador da seguinte forma
running-config
stcapp ccm-group 1
stcapp
stcapp feature access-code
voice service voip
voice-port 0/0/0
 no non-linear
 cptone BR
 timeouts ringing infinity
 description carol
 caller-id enable
voice-port 0/0/1
 no non-linear
 cptone BR
 description ricardo
 caller-id enable
voice-port 0/0/2
 no non-linear
 cptone BR
 description weverton
 caller-id enable
voice-port 0/3/0
voice-port 0/3/1
 supervisory disconnect dualtone mid-call
 cptone BR
 timeouts call-disconnect 5
voice-port 0/3/2
voice-port 0/3/3
sccp local FastEthernet0/1
sccp
dial-peer voice 195 pots
 incoming called-number XXXXXXXX
dial-peer voice 200 pots
 description carol
 destination-pattern 2000
 port 0/0/0
 forward-digits 0
dial-peer voice 205 pots
 description ricardo
 destination-pattern 2001
 port 0/0/1
dial-peer voice 210 pots
 destination-pattern 2002
 port 0/0/2
dial-peer voice 215 pots
 description jose
 destination-pattern 2003
 port 0/0/3
dial-peer voice 220 pots
 destination-pattern XXXXXX
 port 0/0/1
dial-peer voice 225 pots
 destination-pattern .T
 port 0/3/1
dial-peer voice 100 pots
 service stcapp
 port 0/0/0
dial-peer voice 101 pots
 service stcapp
 port 0/0/1
dial-peer voice 102 pots
 service stcapp
 port 0/0/2
dial-peer voice 103 pots
 service stcapp
 port 0/0/3
telephony-service
 timeouts transfer-recall 30
 max-conferences 8 gain -6
 call-forward pattern .T
 transfer-digit-collect orig-call
 transfer-system full-consult
 transfer-pattern .T
Quando eu ligo de fora toca no telefone conectado na porta 0/0/1 eu atendo aperto o flash ou faço um hookflash ele ate me da tom de discagem ai tento transferir para o ramal 2002, quando disco o 2 e o zero ele da tom de ocupado. Alguem ja passou por isso e possivel fazer oq estou tentando. Segue abaixo versao do IOS e CME
Cisco IOS Software, 2800 Software (C2800NM-ADVIPSERVICESK9-M), Version 15.1(3)T1, RELEASE SOFTWARE (fc2)
CONFIG (Version=8.5)
Version 8.5
Max phoneload sccp version 17
Max dspfarm sccp version 18
Cisco Unified Communications Manager Express
Desde já agradeço
3 SOLUÇÕES ACEITES
Soluções aceites
Bom dia, tudo bem?Poderia por
Bom dia, tudo bem?
Poderia por gentileza efetuar o debug voice ccapi inout e nos enviar o output para que possamos analisar o que está acontecendo?
Obrigado.
Ja temos o hook flash time
Ja temos o hook flash time que voce está utilizando:
Hookflash-in Timing is set to max=1000 ms, min=150 ms
Hookflash-out Timing is set to 400 ms
Faça um teste e mostre o resultado do debug vpm signal
Cheers Bruno Rangel Please remember to rate helpful responses using the stars bellow and identify helpful or correct answers .
Opa que bacana!
Opa que bacana! Obrigado por compartilhar... Lembre se de avaliar as respostas e ecolha as que achar mais próxima da sua resolução para marcar a discussão como lida.
12 RESPOSTAS
Bom dia, tudo bem?
Obrigado.
Segue saida do log, A parte
Segue saida do log, A parte em negrito e quando executo o hookflash. Desde já agradeço pela ajuda. Falei com um amigo da área ele acha que pode ser um BUG do IOS que ja passou por isso vou testar com outro IOS também e posto os resultados.
hercules#
hercules#
*Aug 20 14:48:14.736: //2404/46B4B6F794AC/CCAPI/cc_api_call_disconnected:
   Cause Value=17, Interface=0x4B21CD14, Call Id=2404
   Call Entry(Responsed=TRUE, Cause Value=17, Retry Count=0)
*Aug 20 14:48:14.736: //2404/46B4B6F794AC/CCAPI/ccConferenceDestroy:
   Conference Id=0x22, Tag=0x0
*Aug 20 14:48:14.736: //2404/46B4B6F794AC/CCAPI/cc_api_bridge_drop_done:
   Conference Id=0x22, Source Interface=0x4B21CD14, Source Call Id=2404,
   Destination Call Id=2405, Disposition=0x0, Tag=0x0
*Aug 20 14:48:14.736: //2405/46B4B6F794AC/CCAPI/cc_api_bridge_drop_done:
   Conference Id=0x22, Source Interface=0x4B211E6C, Source Call Id=2405,
   Destination Call Id=2404, Disposition=0x0, Tag=0x0
*Aug 20 14:48:14.736: //2404/46B4B6F794AC/CCAPI/cc_generic_bridge_done:
*Aug 20 14:48:14.740: //2405/46B4B6F794AC/CCAPI/ccCallDisconnect:
   Cause Value=17, Tag=0x0, Call Entry(Previous Disconnect Cause=0, Disconnect Cause=0)
   Cause Value=17, Call Entry(Responsed=TRUE, Cause Value=17)
*Aug 20 14:48:14.740: //2405/46B4B6F794AC/CCAPI/cc_api_get_transfer_info:
   Transfer Number Is Null
*Aug 20 14:48:14.744: //2404/46B4B6F794AC/CCAPI/ccCallDisconnect:
   Cause Value=17, Tag=0x0, Call Entry(Previous Disconnect Cause=0, Disconnect Cause=17)
*Aug 20 14:48:14.744: //2404/46B4B6F794AC/CCAPI/cc_api_get_transfer_info:
*Aug 20 14:48:14.752: //2405/46B4B6F794AC/CCAPI/cc_api_call_disconnect_done:
   Disposition=0, Interface=0x4B211E6C, Tag=0x0, Call Id=2405,
   Call Entry(Disconnect Cause=17, Voice Class Cause Code=0, Retry Count=0)
   Call Disconnect Event Sent
*Aug 20 14:48:14.752: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
*Aug 20 14:48:14.752: :cc_free_feature_vsa freeing 489D0330
*Aug 20 14:48:14.752:  vsacount in free is 1
*Aug 20 14:48:14.752: //2404/46B4B6F794AC/CCAPI/cc_api_call_disconnect_done:
   Disposition=0, Interface=0x4B21CD14, Tag=0x0, Call Id=2404,
*Aug 20 14:48:14.756: :cc_free_feature_vsa freeing 489D04F0
*Aug 20 14:48:14.756: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
*Aug 20 14:48:14.756:  vsacount in free is 0
*Aug 20 14:48:20.464: //-1/558C272D94B1/CCAPI/cc_api_display_ie_subfields:
   cc_api_call_setup_ind_common:
   cisco-username=
   ----- ccCallInfo IE subfields -----
   cisco-ani=
   cisco-anitype=0
   cisco-aniplan=0
   cisco-anipi=0
   cisco-anisi=0
   dest=30292424
   cisco-desttype=0
   cisco-destplan=0
   cisco-rdie=FFFFFFFF
   cisco-rdn=
   cisco-rdntype=0
   cisco-rdnplan=0
   cisco-rdnpi=0
   cisco-rdnsi=0
   cisco-redirectreason=0   fwd_final_type =0
   final_redirectNumber =
   hunt_group_timeout =0
*Aug 20 14:48:20.464: //-1/558C272D94B1/CCAPI/cc_api_call_setup_ind_common:
   Interface=0x4B21CD14, Call Info(
   Calling Number=,(Calling Name=)(TON=Unknown, NPI=Unknown, Screening=Not Screened, Presentation=Allowed),
   Called Number=30292424(TON=Unknown, NPI=Unknown),
   Calling Translated=FALSE, Subscriber Type Str=RegularLine, FinalDestinationFlag=TRUE,
   Incoming Dial-peer=225, Progress Indication=ORIGINATING SIDE IS NON ISDN(3), Calling IE Present=FALSE,
   Source Trkgrp Route Label=, Target Trkgrp Route Label=, CLID Transparent=FALSE), Call Id=-1
*Aug 20 14:48:20.468: //-1/558C272D94B1/CCAPI/ccCheckClipClir:
   In: Calling Number=(TON=Unknown, NPI=Unknown, Screening=Not Screened, Presentation=Allowed)
   Out: Calling Number=(TON=Unknown, NPI=Unknown, Screening=Not Screened, Presentation=Allowed)
*Aug 20 14:48:20.468: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
*Aug 20 14:48:20.468: :cc_get_feature_vsa malloc success
*Aug 20 14:48:20.468:  cc_get_feature_vsa count is 1
*Aug 20 14:48:20.468: :FEATURE_VSA attributes are: feature_name:0,feature_time:1218249976,feature_id:2387
*Aug 20 14:48:20.468: //2406/558C272D94B1/CCAPI/cc_api_call_setup_ind_common:
   Set Up Event Sent;
   Call Info(Calling Number=(TON=Unknown, NPI=Unknown, Screening=Not Screened, Presentation=Allowed),
   Called Number=30292424(TON=Unknown, NPI=Unknown))
*Aug 20 14:48:20.468: //2406/558C272D94B1/CCAPI/cc_process_call_setup_ind:
   Event=0x4B1C9660
*Aug 20 14:48:20.468: //-1/xxxxxxxxxxxx/CCAPI/cc_setupind_match_search:
   Try with the demoted called number 30292424
*Aug 20 14:48:20.472: //2406/558C272D94B1/CCAPI/ccCallSetContext:
   Context=0x489D6C24
*Aug 20 14:48:20.472: //2406/558C272D94B1/CCAPI/cc_process_call_setup_ind:
   >>>>CCAPI handed cid 2406 with tag 225 to app "_ManagedAppProcess_Default"
*Aug 20 14:48:20.472: //2406/558C272D94B1/CCAPI/ccCallProceeding:
   Progress Indication=NULL(0)
*Aug 20 14:48:20.476: //2406/558C272D94B1/CCAPI/ccCallSetupRequest:
   Destination=, Calling IE Present=FALSE, Mode=0,
   Outgoing Dial-peer=220, Params=0x489E70DC, Progress Indication=ORIGINATING SIDE IS NON ISDN(3)
*Aug 20 14:48:20.476: //2406/558C272D94B1/CCAPI/ccCheckClipClir:
   Destination Pattern=30292424, Called Number=30292424, Digit Strip=TRUE
   Redirect Number=, Display Info=
   Account Number=, Final Destination Flag=TRUE,
   Guid=558C272D-4681-11E5-94B1-FBD786665372, Outgoing Dial-peer=220
*Aug 20 14:48:20.480: //2406/558C272D94B1/CCAPI/cc_api_display_ie_subfields:
   ccCallSetupRequest:
   cisco-username=
   cisco-ani=
   cisco-anitype=0
   cisco-aniplan=0
   cisco-anipi=0
   cisco-anisi=0
   dest=30292424
   cisco-desttype=0
   cisco-destplan=0
   cisco-rdie=FFFFFFFF
   cisco-rdn=
   cisco-rdntype=0
   cisco-rdnplan=0
   cisco-rdnpi=0
   cisco-rdnsi=0
*Aug 20 14:48:20.480: //2406/558C272D94B1/CCAPI/ccIFCallSetupRequestPrivate:
   Interface=0x4B211E6C, Interface Type=6, Destination=, Mode=0x0,
   Call Params(Calling Number=,(Calling Name=)(TON=Unknown, NPI=Unknown, Screening=Not Screened, Presentation=Allowed),
   Called Number=30292424(TON=Unknown, NPI=Unknown), Calling Translated=FALSE,
   Subscriber Type Str=RegularLine, FinalDestinationFlag=TRUE, Outgoing Dial-peer=220, Call Count On=FALSE,
   Source Trkgrp Route Label=, Target Trkgrp Route Label=, tg_label_flag=0, Application Call Id=)
*Aug 20 14:48:20.480: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
*Aug 20 14:48:20.480: :cc_get_feature_vsa malloc success
*Aug 20 14:48:20.480:  cc_get_feature_vsa count is 2
*Aug 20 14:48:20.480: :FEATURE_VSA attributes are: feature_name:0,feature_time:1218249528,feature_id:2388
*Aug 20 14:48:20.480: //2407/558C272D94B1/CCAPI/ccIFCallSetupRequestPrivate:
   SPI Call Setup Request Is Success; Interface Type=6, FlowMode=1
*Aug 20 14:48:20.480: //2407/558C272D94B1/CCAPI/ccCallSetContext:
   Context=0x489E708C
*Aug 20 14:48:20.480: //2406/558C272D94B1/CCAPI/ccSaveDialpeerTag:
*Aug 20 14:48:20.488: //2407/558C272D94B1/CCAPI/cc_api_call_proceeding:
   Interface=0x4B211E6C, Progress Indication=NULL(0)
*Aug 20 14:48:20.488: //2407/558C272D94B1/CCAPI/cc_api_call_cut_progress:
   Interface=0x4B211E6C, Progress Indication=INBAND(8), Signal Indication=INTERCEPT(2),
   Cause Value=0
   Call Entry(Responsed=TRUE)
*Aug 20 14:48:20.492: //2406/558C272D94B1/CCAPI/ccCallCutProgress:
   Progress Indication=INBAND(8), Signal Indication=INTERCEPT(2), Cause Value=0
   Voice Call Send Alert=FALSE, Call Entry(Alert Sent=FALSE)
*Aug 20 14:48:20.492: //2406/558C272D94B1/CCAPI/ccGenerateToneInfo:
   Stop Tone On Digit=FALSE, Tone=Null,
   Tone Direction=Network, Params=0x0, Call Id=2406
*Aug 20 14:48:20.492: //2406/558C272D94B1/CCAPI/ccConferenceCreate:
   (confID=0x4A081574, callID1=0x966, gcid=558C272D-468111E5-94B1FBD7-86665372, tag=0x0)
*Aug 20 14:48:20.492: //2407/558C272D94B1/CCAPI/ccConferenceCreate:
   (confID=0x4A081574, callID2=0x967, gcid=558C272D-468111E5-94B1FBD7-86665372, tag=0x0)
   Conference Id=0x4A081574, Call Id1=2406, Call Id2=2407, Tag=0x0
*Aug 20 14:48:20.492: //2406/558C272D94B1/CCAPI/cc_api_bridge_done:
   Conference Id=0x23, Source Interface=0x4B21CD14, Source Call Id=2406,
   Destination Call Id=2407, Disposition=0x0, Tag=0xFFFFFFFF
*Aug 20 14:48:20.496: //2407/558C272D94B1/CCAPI/cc_api_bridge_done:
   Conference Id=0x23, Source Interface=0x4B211E6C, Source Call Id=2407,
   Destination Call Id=2406, Disposition=0x0, Tag=0xFFFFFFFF
*Aug 20 14:48:20.496: //2406/558C272D94B1/CCAPI/cc_generic_bridge_done:
*Aug 20 14:48:20.496: //2406/558C272D94B1/CCAPI/ccConferenceCreate:
   Call Entry(Conference Id=0x23, Destination Call Id=2407)
*Aug 20 14:48:20.496: //2407/558C272D94B1/CCAPI/ccConferenceCreate:
   Call Entry(Conference Id=0x23, Destination Call Id=2406)
*Aug 20 14:48:20.496: //2406/558C272D94B1/CCAPI/cc_api_caps_ind:
   Destination Interface=0x4B211E6C, Destination Call Id=2407, Source Call Id=2406,
   Caps(Codec=0x1, Fax Rate=0x2, Vad=0x2,
   Modem=0x2, Codec Bytes=160, Signal Type=2)
   Caps(Playout Mode=1, Playout Initial=60(ms), Playout Min=40(ms),
   Playout Max=1000(ms), Fax Nom=300(ms))
*Aug 20 14:48:20.500: //2407/558C272D94B1/CCAPI/cc_api_caps_ind:
   Destination Interface=0x4B21CD14, Destination Call Id=2406, Source Call Id=2407,
*Aug 20 14:48:20.500: //2407/558C272D94B1/CCAPI/cc_api_caps_ack:
   Caps(Codec=g711ulaw(0x1), Fax Rate=FAX_RATE_VOICE(0x2), Vad=ON(0x2),
   Modem=ON(0x2), Codec Bytes=160, Signal Type=2, Seq Num Start=4551)
*Aug 20 14:48:20.500: //2406/558C272D94B1/CCAPI/cc_api_caps_ack:
   Modem=ON(0x2), Codec Bytes=160, Signal Type=2, Seq Num Start=4182)
*Aug 20 14:48:20.504: //2407/558C272D94B1/CCAPI/cc_api_voice_mode_event:
   Call Id=2407
   Call Entry(Context=0x489E708C)
*Aug 20 14:48:20.504: //2406/558C272D94B1/CCAPI/cc_api_voice_mode_event:
   Call Id=2406
   Call Entry(Context=0x489D6C24)
*Aug 20 14:48:20.508: //2406/558C272D94B1/CCAPI/cc_process_notify_bridge_done:
   Conference Id=0x23, Call Id1=2406, Call Id2=2407
*Aug 20 14:48:26.948: //2407/558C272D94B1/CCAPI/cc_api_call_connected:
   Interface=0x4B211E6C, Data Bitmask=0x1, Progress Indication=DESTINATION IS NON ISDN(2),
   Connection Handle=0
   Call Entry(Connected=TRUE, Responsed=TRUE, Retry Count=0)
*Aug 20 14:48:26.948: //2406/558C272D94B1/CCAPI/ccCallConnect:
   Progress Indication=DESTINATION IS NON ISDN(2), Data Bitmask=0x1
   Call Entry(Connected=TRUE, Responsed=TRUE)
hercules#
hercules#
hercules#
*Aug 20 14:48:34.576: //2407/558C272D94B1/CCAPI/cc_api_call_feature:
   Feature Type=5, Interface=0x4B211E6C, Call Id=2407
*Aug 20 14:48:34.576: //2406/558C272D94B1/CCAPI/ccCallFeature:
   Feature Type=5, Call Id=2406
*Aug 20 14:48:44.456: //2407/558C272D94B1/CCAPI/cc_api_call_feature:
*Aug 20 14:48:44.456: //2406/558C272D94B1/CCAPI/ccCallFeature:
*Aug 20 14:48:54.652: //2407/558C272D94B1/CCAPI/cc_api_call_disconnected:
   Cause Value=16, Interface=0x4B211E6C, Call Id=2407
   Call Entry(Responsed=TRUE, Cause Value=16, Retry Count=0)
*Aug 20 14:48:54.652: //2406/558C272D94B1/CCAPI/ccConferenceDestroy:
   Conference Id=0x23, Tag=0x0
*Aug 20 14:48:54.652: //2406/558C272D94B1/CCAPI/cc_api_bridge_drop_done:
   Destination Call Id=2407, Disposition=0x0, Tag=0x0
*Aug 20 14:48:54.652: //2407/558C272D94B1/CCAPI/cc_api_bridge_drop_done:
   Destination Call Id=2406, Disposition=0x0, Tag=0x0
*Aug 20 14:48:54.652: //2406/558C272D94B1/CCAPI/cc_generic_bridge_done:
*Aug 20 14:48:54.656: //2406/558C272D94B1/CCAPI/ccCallDisconnect:
   Cause Value=16, Tag=0x0, Call Entry(Previous Disconnect Cause=0, Disconnect Cause=0)
   Cause Value=16, Call Entry(Responsed=TRUE, Cause Value=16)
*Aug 20 14:48:54.656: //2406/558C272D94B1/CCAPI/cc_api_get_transfer_info:
*Aug 20 14:48:54.656: //2407/558C272D94B1/CCAPI/ccCallDisconnect:
   Cause Value=16, Tag=0x0, Call Entry(Previous Disconnect Cause=0, Disconnect Cause=16)
*Aug 20 14:48:54.656: //2407/558C272D94B1/CCAPI/cc_api_get_transfer_info:
*Aug 20 14:48:54.664: //2406/558C272D94B1/CCAPI/cc_api_call_disconnect_done:
   Disposition=0, Interface=0x4B21CD14, Tag=0x0, Call Id=2406,
   Call Entry(Disconnect Cause=16, Voice Class Cause Code=0, Retry Count=0)
*Aug 20 14:48:54.664: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
*Aug 20 14:48:54.664: :cc_free_feature_vsa freeing 489D04F0
*Aug 20 14:48:54.664:  vsacount in free is 1
*Aug 20 14:48:54.664: //2407/558C272D94B1/CCAPI/cc_api_call_disconnect_done:
   Disposition=0, Interface=0x4B211E6C, Tag=0x0, Call Id=2407,
*Aug 20 14:48:54.668: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
*Aug 20 14:48:54.668: :cc_free_feature_vsa freeing 489D0330
*Aug 20 14:48:54.668:  vsacount in free is 0
hercules#
Qual o numero de origem e o
Qual o numero de origem e o destino da chamada?
Uma curiosidade, qual o tipo de aparelho telefônico que você está usando na FXS? Telefone de mesa e ou sem fio?
Ola bruno. Estou ligando a
Ola bruno.
Estou ligando a partir do celular 9982-1XXX para o 30292XXX, depois tento transferir para o ramal 2001.
O telefone que tento transferir e este com fio o que recebe a ligacao e sem fio mas ja testei com um igual ao da foto também a ligacao chega na FXO.
https://images.tcdn.com.br/img/img_prod/207469/2386_2_20140805100013.jpg
Att.
Boa tarde, Não sei se é o
Boa tarde,
Não sei se é o caso. Lembro no passado de ter problemas para transferir por causa do timing hookflash-out 500.
Tinha que acertar o tempo certo para o tipo de telefone que estávamos utilizando.
Attn
Daniel
Daniel Sobrinho
Dsobrinho,obrigado por
Dsobrinho,obrigado por responder vou testar isso.
Bruno segue saida do comando.
FXS
hercules#sh voice port 0/0/0
Foreign Exchange Station 0/0/0 Slot is 0, Sub-unit is 0, Port is 0
 Type of VoicePort is FXS  VIC3-4FXS/DID
 Operation State is DORMANT
 Administrative State is UP
 No Interface Down Failure
 Description is carol
 Noise Regeneration is enabled
 Non Linear Processing is disabled
 Non Linear Mute is disabled
 Non Linear Threshold is -21 dB
 Music On Hold Threshold is Set to -38 dBm
 In Gain is Set to 0 dB
 Out Attenuation is Set to 3 dB
 Echo Cancellation is enabled
 Echo Cancellation NLP mute is disabled
 Echo Cancellation NLP threshold is -21 dB
 Echo Cancel Coverage is set to 128 ms
 Echo Cancel worst case ERL is set to 6 dB
 Playout-delay Mode is set to adaptive
 Playout-delay Nominal is set to 60 ms
 Playout-delay Maximum is set to 1000 ms
 Playout-delay Minimum mode is set to default, value 40 ms
 Playout-delay Fax is set to 300 ms
 Connection Mode is normal
 Connection Number is not set
 Initial Time Out is set to 15 s
 Interdigit Time Out is set to 10 s
 Call Disconnect Time Out is set to 60 s
 Supervisory Disconnect Time Out is set to 750 ms
 Ringing Time Out is set to infinity
 Wait Release Time Out is set to 30 s
 Companding Type is u-law
 Region Tone is set for BR
 Analog Info Follows:
 Currently processing none
 Maintenance Mode Set to None (not in mtc mode)
 Number of signaling protocol errors are 0
 Impedance is set to 600r Ohm
 Station name None, Station number None
 Caller ID Info Follows:
 Standard ETSI DTMF
 Output attenuation is set to 14 dB
 Caller ID is transmitted after 1 ring(s)
 Translation profile (Incoming):
 Translation profile (Outgoing):
 lpcor (Incoming):
 lpcor (Outgoing):
 Voice card specific Info Follows:
 Signal Type is loopStart
 Ring Frequency is 25 Hz
 Hook Status is On Hook
 Ring Active Status is inactive
 Ring Ground Status is inactive
 Tip Ground Status is inactive
 Digit Duration Timing is set to 100 ms
 InterDigit Duration Timing is set to 100 ms
 No disconnect acknowledge
 Ring Cadence is defined by CPTone Selection
 Ring Cadence are [10 40] * 100 msec
 Ringer Equivalence Number is set to 1
hercules#
FXS
hercules#sh voice port 0/0/1
Foreign Exchange Station 0/0/1 Slot is 0, Sub-unit is 0, Port is 1
 Description is ricardo
 Standard ETSI DTMF
 lpcor (Incoming):
 lpcor (Outgoing):
hercules#
FXO
hercules#sh voice port 0/3/1
Foreign Exchange Office 0/3/1 Slot is 0, Sub-unit is 3, Port is 1
 Type of VoicePort is FXO
 Description is PSTN 30292424
 Non Linear Processing is enabled
 Connection Mode is plar
 Connection Number is 3029XXXX
 Call Disconnect Time Out is set to 5 s
 Power Denial Disconnect Time Out is set to 1000 ms
 Ringing Time Out is set to 180 s
 lpcor (Incoming):
 lpcor (Outgoing):
 Battery-Reversal is enabled
 Number Of Rings is set to 1
 Supervisory Disconnect is dualtone mid-call
 Answer Supervision is inactive
 Ring Detect Status is inactive
 Dial Out Type is dtmf
 Pulse Rate Timing is set to 10 pulses/second
 InterDigit Pulse Duration Timing is set to 750 ms
 Percent Break of Pulse is 65 percent
 GuardOut timer is 2000 ms
 Minimum ring duration timer is 125 ms
 Hookflash-in Timing is set to 600 ms
 Supervisory Disconnect Timing (loopStart only) is set to 350 ms
 OPX Ring Wait Timing is set to 6000 ms
 Secondary dialtone is disabled
hercules#
eu fiz o hookflash em 500,
eu fiz o hookflash em 500, 1000 e 1550 segue os logs em abaixo. Todos sem sucesso
com hookflash de 500
hercules(config-voiceport)#
*Aug 28 20:26:27.711: htsp_process_event: [0/0/0, FXSLS_CONNECT, E_DSP_SIG_0100]fxsls_offhook_onhook, HF duration Max=1000, HF duration Min=150
*Aug 28 20:26:27.711: htsp_timer - 1000 msec
*Aug 28 20:26:28.011: htsp_process_event: [0/0/0, FXSLS_CONNECT, E_DSP_SIG_1100]fxsls_offhook_offhookhtsp_hook_flash_ind
*Aug 28 20:26:28.011: htsp_timer_stop htsp_call_feature:feature 5
*Aug 28 20:26:28.015: htsp_process_event: [0/3/1, FXOLS_CONNECT, E_HTSP_HOOKFLASH]fxols_hookflash, interval=500
*Aug 28 20:26:28.015: [0/3/1] set signal state = 0x4 timestamp = 0
*Aug 28 20:26:28.015: [0/3/1] set signal state = 0xC timestamp = 500
*Aug 28 20:26:28.287: htsp_process_event: [0/3/1, FXOLS_CONNECT, E_DSP_SIG_0110]fxols_rvs_battery
*Aug 28 20:26:28.287: htsp_timer_stop2
*Aug 28 20:26:28.787: htsp_process_event: [0/3/1, FXOLS_CONNECT, E_DSP_SIG_0110]fxols_rvs_battery
*Aug 28 20:26:28.787: htsp_timer_stop2
com hookflash de 1000
*Aug 28 20:32:37.887: htsp_process_event: [0/0/0, FXSLS_CONNECT, E_DSP_SIG_0100]fxsls_offhook_onhook, HF duration Max=1000, HF duration Min=150
*Aug 28 20:32:37.887: htsp_timer - 1000 msec
*Aug 28 20:32:38.191: htsp_process_event: [0/0/0, FXSLS_CONNECT, E_DSP_SIG_1100]fxsls_offhook_offhookhtsp_hook_flash_ind
*Aug 28 20:32:38.191: htsp_timer_stop htsp_call_feature:feature 5
*Aug 28 20:32:38.191: htsp_process_event: [0/3/1, FXOLS_CONNECT, E_HTSP_HOOKFLASH]fxols_hookflash, interval=1000
*Aug 28 20:32:38.191: [0/3/1] set signal state = 0x4 timestamp = 0
*Aug 28 20:32:38.191: [0/3/1] set signal state = 0xC timestamp = 1000
*Aug 28 20:32:38.463: htsp_process_event: [0/3/1, FXOLS_CONNECT, E_DSP_SIG_0110]fxols_rvs_battery
*Aug 28 20:32:38.463: htsp_timer_stop2
*Aug 28 20:32:39.467: htsp_process_event: [0/3/1, FXOLS_CONNECT, E_DSP_SIG_0110]fxols_rvs_battery
*Aug 28 20:32:39.467: htsp_timer_stop2
com hookflash de 1550
*Aug 28 20:34:52.047: htsp_process_event: [0/0/0, FXSLS_CONNECT, E_DSP_SIG_0100]fxsls_offhook_onhook, HF duration Max=1000, HF duration Min=150
*Aug 28 20:34:52.047: htsp_timer - 1000 msec
*Aug 28 20:34:52.347: htsp_process_event: [0/0/0, FXSLS_CONNECT, E_DSP_SIG_1100]fxsls_offhook_offhookhtsp_hook_flash_ind
*Aug 28 20:34:52.347: htsp_timer_stop htsp_call_feature:feature 5
*Aug 28 20:34:52.351: htsp_process_event: [0/3/1, FXOLS_CONNECT, E_HTSP_HOOKFLASH]fxols_hookflash, interval=1550
*Aug 28 20:34:52.351: [0/3/1] set signal state = 0x4 timestamp = 0
*Aug 28 20:34:52.351: [0/3/1] set signal state = 0xC timestamp = 1550
*Aug 28 20:34:52.623: htsp_process_event: [0/3/1, FXOLS_CONNECT, E_DSP_SIG_0110]fxols_rvs_battery
*Aug 28 20:34:52.623: htsp_timer_stop2
*Aug 28 20:34:54.171: htsp_process_event: [0/3/1, FXOLS_CONNECT, E_DSP_SIG_0110]fxols_rvs_battery
*Aug 28 20:34:54.175: htsp_timer_stop2
Porém eu notei que quando aperto o hookflash ele gera o seguinte log
*Aug 28 20:37:29.243: htsp_process_event: [0/0/0, FXSLS_CONNECT, E_DSP_SIG_0100]fxsls_offhook_onhook, HF duration Max=1000, HF duration Min=150
*Aug 28 20:37:29.243: htsp_timer - 1000 msec
*Aug 28 20:37:29.547: htsp_process_event: [0/0/0, FXSLS_CONNECT, E_DSP_SIG_1100]fxsls_offhook_offhookhtsp_hook_flash_ind
*Aug 28 20:37:29.547: htsp_timer_stop htsp_call_feature:feature 5
*Aug 28 20:37:29.547: htsp_process_event: [0/3/1, FXOLS_CONNECT, E_HTSP_HOOKFLASH]fxols_hookflash, interval=500
*Aug 28 20:37:29.547: [0/3/1] set signal state = 0x4 timestamp = 0
*Aug 28 20:37:29.547: [0/3/1] set signal state = 0xC timestamp = 500
*Aug 28 20:37:29.819: htsp_process_event: [0/3/1, FXOLS_CONNECT, E_DSP_SIG_0110]fxols_rvs_battery
*Aug 28 20:37:29.819: htsp_timer_stop2
*Aug 28 20:37:30.319: htsp_process_event: [0/3/1, FXOLS_CONNECT, E_DSP_SIG_0110]fxols_rvs_battery
*Aug 28 20:37:30.319: htsp_timer_stop2
tentando analisar o log depois que aberto o flash ou faço o hookflash ele me mostra
*Aug 28 20:47:42.855: htsp_process_event: [0/0/0, FXSLS_CONNECT, E_DSP_SIG_0100]fxsls_offhook_onhook, HF duration Max=1000, HF duration Min=150
*Aug 28 20:47:42.855: htsp_timer - 1000 msec
*Aug 28 20:47:43.159: htsp_process_event: [0/0/0, FXSLS_CONNECT, E_DSP_SIG_1100]fxsls_offhook_offhookhtsp_hook_flash_ind
*Aug 28 20:47:43.159: htsp_timer_stop htsp_call_feature:feature 5
Pelo que pude entender ele detecta o hookflash mas a feature que ele esta detectando é a feature 5 e segundo a saida do comando "show stcapp features code" , codigo 5 é "toggle between two calls"
hercules#sh stcapp feature codes
  stcapp feature access-code disabled
  stcapp feature speed-dial disabled
  stcapp call-control mode is feature mode
    #1 -- hangup last active call
    #2 -- transfer
    #3 -- conference
    #4 -- drop last conferee
    #5 -- toggle between two calls
hercules#
e logo em seguida ele gera isso
*Aug 28 20:47:43.159: htsp_process_event: [0/3/1, FXOLS_CONNECT, E_HTSP_HOOKFLASH]fxols_hookflash, interval=400
*Aug 28 20:47:43.159: [0/3/1] set signal state = 0x4 timestamp = 0
*Aug 28 20:47:43.159: [0/3/1] set signal state = 0xC timestamp = 400
*Aug 28 20:47:43.431: htsp_process_event: [0/3/1, FXOLS_CONNECT, E_DSP_SIG_0110]fxols_rvs_battery
*Aug 28 20:47:43.431: htsp_timer_stop2
*Aug 28 20:47:43.835: htsp_process_event: [0/3/1, FXOLS_CONNECT, E_DSP_SIG_0110]fxols_rvs_battery
*Aug 28 20:47:43.835: htsp_timer_stop2
que sinceramente nao entendi esse fxols_rvs_battery, o interessante que quando ele me da o tom de discagem eu disco 2, ele fica esperando o outro digito quando digito o zero ele da sinal de ocupado.
Att.
Pessoal resolvi cagada minha
Pessoal resolvi cagada minha eu tinha um "connection plar" para o numero real e usava um dial-peer para jogar para a FXS, ai coloquei o connection plar direto para o ramal e a transferencia funcionou. resolveu me desculpem. Muito obrigado pela ajuda e bom contar com a comunidade.
Att.
Opa que bacana!
Vc consegue transferir entre
Vc consegue transferir entre ramais?
Manda um show voice port do ramal que você está usando.
Faça um novo teste e envio o resultado do debug vpm signal
debug e consigo ligar entre
debug e consigo ligar entre ramais
*Aug 28 20:16:45.399: htsp_timer - 1000 msec
*Aug 28 20:16:45.703: htsp_process_event: [0/0/0, FXSLS_CONNECT, E_DSP_SIG_1100]fxsls_offhook_offhookhtsp_hook_flash_ind
*Aug 28 20:16:45.703: htsp_timer_stop htsp_call_feature:feature 5
*Aug 28 20:16:45.703: htsp_process_event: [0/3/1, FXOLS_CONNECT, E_HTSP_HOOKFLASH]fxols_hookflash, interval=400
*Aug 28 20:16:45.703: [0/3/1] set signal state = 0x4 timestamp = 0
*Aug 28 20:16:45.703: [0/3/1] set signal state = 0xC timestamp = 400
*Aug 28 20:16:45.975: htsp_process_event: [0/3/1, FXOLS_CONNECT, E_DSP_SIG_0110]fxols_rvs_battery
*Aug 28 20:16:45.975: htsp_timer_stop2
*Aug 28 20:16:46.375: htsp_process_event: [0/3/1, FXOLS_CONNECT, E_DSP_SIG_0110]fxols_rvs_battery
*Aug 28 20:16:46.375: htsp_timer_stop2
*Aug 28 20:16:53.879: htsp_process_event: [0/0/0, FXSLS_CONNECT, E_DSP_SIG_0100]fxsls_offhook_onhook, HF duration Max=1000, HF duration Min=150
*Aug 28 20:16:53.879: htsp_timer - 1000 msec
*Aug 28 20:16:54.879: htsp_process_event: [0/0/0, FXSLS_CONNECT, E_HTSP_EVENT_TIMER]fxsls_connect_wait_release_req
*Aug 28 20:16:54.879: htsp_timer_stop
*Aug 28 20:16:54.883: htsp_process_event: [0/3/1, FXOLS_CONNECT, E_HTSP_RELEASE_REQ]fxols_offhook_release
*Aug 28 20:16:54.883: htsp_timer_stop
*Aug 28 20:16:54.883: htsp_timer_stop2
*Aug 28 20:16:54.883: htsp_timer_stop3
*Aug 28 20:16:54.883: [0/3/1] set signal state = 0x4 timestamp = 0
*Aug 28 20:16:54.883: htsp_timer - 2000 msec
*Aug 28 20:16:54.883: htsp_process_event: [0/0/0, FXSLS_WAIT_RELEASE_REQ, E_HTSP_RELEASE_REQ]fxsls_waitrls_req_rls
*Aug 28 20:16:54.883: [0/0/0] set signal state = 0x4 timestamp = 0
*Aug 28 20:16:54.887: htsp_process_event: [0/0/0, FXSLS_ONHOOK, E_DSP_SIG_0100]fxsls_onhook_onhook
*Aug 28 20:16:55.151: htsp_process_event: [0/3/1, FXOLS_GUARD_OUT, E_DSP_SIG_0110]
*Aug 28 20:16:56.883: htsp_process_event: [0/3/1, FXOLS_GUARD_OUT, E_HTSP_EVENT_TIMER]fxols_guard_out_timeout
*Aug 28 20:16:56.883: htsp_process_event: [0/3/1, FXOLS_ONHOOK, E_DSP_SIG_0100]
132
Apresentações
59
Kudo
12
Respostas
