el 02-07-2014 05:50 AM
hola, tengo el sig problema tengo un router cisco 2911 con enlace E1 hacia una central harris 2020 estamos migrando a telefonia ip
Resulta que hace un tiempo empezo un problema que no tiene solucion
me arroja estos errores
**ERROR**: Module-CCPRI Function-CCPRI_Go Error-Event received for an unrecognized call: 97
**ERROR**: CCPMSG_OutCall: fails with cause 0x22
ISDN Se0/0/1:15 **ERROR**: handle_l2d_srq_mail: Layer 1 inactive
me aparecen canales en fail que cada ves que hago sh voice call summary va cambiando de canal y depronto desaparece y funciona normal
si alguine tiene info porfavor lo agradesco
adjunto la config del router
Building configuration...
Current configuration : 7850 bytes
! No configuration change since last restart
version 15.1
service password-encryption
hostname Canal13-Ppal2-Harris2
boot-start-marker
boot-end-marker
card type e1 0 0
logging buffered 51200 warnings
no aaa new-model
network-clock-participate wic 0
no ipv6 cef
ip source-route
ip cef
isdn switch-type primary-qsig
crypto pki trustpoint TP-self-signed-1478352511
enrollment selfsigned
subject-name cn=IOS-Self-Signed-Certificate-1478352511
revocation-check none
rsakeypair TP-self-signed-1478352511
crypto pki certificate chain TP-self-signed-1478352511
certificate self-signed 01
3082022B 30820194 A0030201 02020101 300D0609 2A864886 F70D0101 05050030
31312F30 2D060355 04031326 494F532D 53656C66 2D536967 6E65642D 43657274
69666963 6174652D 31343738 33353235 3131301E 170D3133 31313034 31373035
34365A17 0D323030 31303130 30303030 305A3031 312F302D 06035504 03132649
4F532D53 656C662D 5369676E 65642D43 65727469 66696361 74652D31 34373833
35323531 3130819F 300D0609 2A864886 F70D0101 01050003 818D0030 81890281
8100C3D9 F4122BBA D60E4D76 1802E40A 9297BB4D 6AD986CF E3CEFDA9 FE8579FC
9757AD03 3793B945 F1B4D0C9 5F86F08A F4746566 2CABFAF0 043C848C 00735BD5
B9122926 0D7BD3FB 081A6D83 F765E15B DAFEFDD6 3AFD404A C62C9D2F 26428A23
E0C4654F 55DC43A9 24FF9947 18E46778 B31237E4 CA5DB3B1 3CE08A03 862986F4
50F30203 010001A3 53305130 0F060355 1D130101 FF040530 030101FF 301F0603
551D2304 18301680 14B27A89 BB6454E8 62A97EC7 4B5F4E69 4A284222 F4301D06
03551D0E 04160414 B27A89BB 6454E862 A97EC74B 5F4E694A 284222F4 300D0609
2A864886 F70D0101 05050003 81810056 3A26BD0E D5C2729C 710EADE3 67C8A976
EFECA042 2A389EEA CB0C4B38 551C5DDC CF4652FD 81BDD832 09047D00 44C752CA
2DF2BCB0 83ECFDE8 E2509830 6D5D0338 69328472 66E32D56 0C06B697 028C6C57
22839199 B1498E81 6A153424 37A62991 7F4E64EF 5BD325FF 531F3999 AB8C1C02
C694E04B B17E2638 39A6EF4F CC6503
quit
voice-card 0
dsp services dspfarm
voice call send-alert
voice call carrier capacity active
voice rtp send-recv
voice service voip
ip address trusted list
ipv4 0.0.0.0 0.0.0.0
qsig decode
fax protocol t38 version 0 ls-redundancy 0 hs-redundancy 0 fallback none
h323
h225 h245-address on-connect
modem passthrough nse codec g711alaw
voice class codec 1
codec preference 1 g729r8
codec preference 2 g711alaw
codec preference 3 g711ulaw
voice class h323 1
h225 timeout tcp establish 3
h225 timeout setup 2
license udi pid CISCO2911/K9 sn FTX1745AH79
hw-module pvdm 0/0
redundancy
controller E1 0/0/0
framing NO-CRC4
pri-group timeslots 1-31
description Conexion PSTN Movistar "SOLO LLAMADAS ENTRANTES"
controller E1 0/0/1
framing NO-CRC4
description Conexion HARRIS TRANSITORIA ******ANEXOS HARRIS - PSTN*******
interface Embedded-Service-Engine0/0
no ip address
shutdown
interface GigabitEthernet0/0
description Red Lan Telefonia
ip address 10.13.3.17 255.255.255.0
duplex auto
speed auto
h323-gateway voip interface
h323-gateway voip bind srcaddr 10.13.3.17
interface GigabitEthernet0/1
no ip address
shutdown
duplex auto
speed auto
interface GigabitEthernet0/2
no ip address
shutdown
duplex auto
speed auto
interface Serial0/0/0:15
no ip address
encapsulation hdlc
isdn switch-type primary-net5
isdn incoming-voice voice
no cdp enable
interface Serial0/0/1:15
no ip address
encapsulation hdlc
isdn timer T310 120000
isdn protocol-emulate network
no cdp enable
ip forward-protocol nd
ip http server
no ip http secure-server
ip route 0.0.0.0 0.0.0.0 10.13.3.1
control-plane
voice-port 0/0/0:15
voice-port 0/1/0
voice-port 0/1/1
voice-port 0/1/2
voice-port 0/1/3
voice-port 0/0/1:15
voice-port 0/2/0
voice-port 0/2/1
voice-port 0/2/2
voice-port 0/2/3
voice-port 0/3/0
voice-port 0/3/1
voice-port 0/3/2
voice-port 0/3/3
mgcp profile default
dial-peer voice 1 voip
description Anexos IP
preference 1
destination-pattern [23]...
session target ipv4:10.13.3.6
incoming called-number .
voice-class codec 1
voice-class h323 1
dtmf-relay h245-alphanumeric
fax rate disable
ip qos dscp cs5 media
no vad
dial-peer voice 2 voip
preference 2
session target ipv4:10.13.3.7
voice-class codec 1
voice-class h323 1
fax rate disable
no vad
dial-peer voice 3 voip
preference 3
session target ipv4:10.13.3.5
voice-class codec 1
voice-class h323 1
fax rate disable
no vad
dial-peer voice 10 pots
tone ringback alert-no-PI
description Anexos Harris 2000
destination-pattern 4...
fax rate disable
direct-inward-dial
port 0/0/1:15
prefix 2
dial-peer voice 11 pots
description PSTN SLM
destination-pattern 92[2-9]......
fax rate disable
direct-inward-dial
port 0/0/1:15
forward-digits 9
dial-peer voice 12 pots
description SLM Nros 800
destination-pattern 9800......
fax rate disable
direct-inward-dial
port 0/0/1:15
prefix 9800
dial-peer voice 13 pots
description SLM Nros 600
destination-pattern 9600.......
fax rate disable
direct-inward-dial
port 0/0/1:15
prefix 9600
dial-peer voice 14 pots
description SLM Nros Emergencia
destination-pattern 91[034].
fax rate disable
direct-inward-dial
port 0/0/1:15
prefix 91
dial-peer voice 15 pots
description Nros LDN Otras Regiones
destination-pattern 90[2-7]........
fax rate disable
direct-inward-dial
port 0/0/1:15
prefix 90
dial-peer voice 16 pots
description Nros LDI
destination-pattern 900T
fax rate disable
direct-inward-dial
port 0/0/1:15
prefix 900
dial-peer voice 17 pots
description sistema ADELACU
destination-pattern 0
fax rate disable
direct-inward-dial
port 0/0/1:15
forward-digits 1
dial-peer voice 18 pots
description Anexos Harris 3000
destination-pattern 5...
fax rate disable
direct-inward-dial
port 0/0/1:15
prefix 3
dial-peer voice 19 pots
description Nros CEL PSTN
destination-pattern 909........
fax rate disable
direct-inward-dial
port 0/0/1:15
prefix 909
dial-peer voice 21 pots
destination-pattern 91[125678].[2-7]........
fax rate disable
direct-inward-dial
port 0/0/1:15
prefix 91
no dial-peer outbound status-check pots
gateway
timer receive-rtp 1200
gatekeeper
shutdown
banner exec ^CC^C
banner login ^CC^C
Descubra y salve sus notas favoritas. Vuelva a encontrar las respuestas de los expertos, guías paso a paso, temas recientes y mucho más.
¿Es nuevo por aquí? Empiece con estos tips. Cómo usar la comunidad Guía para nuevos miembros
Navegue y encuentre contenido personalizado de la comunidad
