cancelar
Mostrando los resultados de
Buscar en lugar de
Quiere decir:
Avisos
¡Bienvenido a la nueva Comunidad de Soporte de Cisco! Nos encantaría conocer su opinión
Problemas con replicacion de Base de datos CUCM ver 7.1.5
Se presentan problemas para aplicar cambios en un CUCM al verificar el cluster con el comando utils dbreplication runtimestate se presente al siguiente estatus
admin:utils dbreplication runtimestate
DB and Replication Services: ALL RUNNING
Cluster Replication State: Replication status command started at: 2016-08-08-20-16
     Replication status command COMPLETED 427 tables checked out of 427
     Errors or Mismatches Were Found:
     Use 'file view activelog cm/trace/dbl/sdi/ReplicationStatus.2016_08_08_20_16_24.out' to see the details
DB Version: ccm7_1_5_33900_10
Number of replicated tables: 427
Cluster Detailed View from PUB (10 Servers):
                                PING            REPLICATION     REPL.   DBver&  REPL.   REPLICATION SETUP
SERVER-NAME     IP ADDRESS      (msec)  RPC?    STATUS          QUEUE   TABLES  LOOP?   (RTMT) & details
DC01xxxxxxxxx     10.1.X.X      0.039   Yes     Connected       0       match   N/A     (3) PUB Setup Completed
DC01xxxxxxxxx     10.1.X.X      Failed  No      Active-Dropped  63825826        ?       N/A     (?) Setup Completed
DC01xxxxxxxxx     10.1.X.X      0.276   Yes     Connected       0       match   N/A     (3) Setup Completed
DC01xxxxxxxxx     10.1.X.X      0.170   Yes     Connected       0       match   N/A     (3) Setup Completed
DC01xxxxxxxxx    10.1.X.X      0.172   Yes     Active-Disconnect       4658332         match   N/A     (3) Setup Completed
DC02xxxxxxxxx     10.2.X.X      4.55    Yes     Off-Line        N/A     match   N/A     (3) Setup Completed
DC02xxxxxxxxx     10.2.X.X      4.91    Yes     Off-Line        N/A     match   N/A     (3) Setup Completed
DC02xxxxxxxxx     10.2.X.X      4.71    Yes     Off-Line        N/A     match   N/A     (3) Setup Completed
dc02xxxxxxxxxx     10.2.X.X      4.81    Yes     Off-Line        N/A     match   N/A     (3) Setup Completed
DC02xxxxxxxxx    10.2.X.X      4.68    Yes     Off-Line        N/A     0       N/A     (4) Setup Completed
1 RESPUESTA
Ya intentaste cualquier de
Ya intentaste cualquier de los comandos que se usan para intentar arreglar eso??
http://docwiki.cisco.com/wiki/CUCM_FAQ#How_to_fix_the_DB_replication.3F.3F
java
if this helps, please rate
www.cisco.com/go/pdi
33
Visitas
ÚTIL
Respuestas
