cancelar
Mostrando los resultados de
Buscar en lugar de
Quiere decir:
Avisos
¡Bienvenido a la nueva Comunidad de Soporte de Cisco! Nos encantaría conocer su opinión
Problemas Outgoing-Inbound GW voz
Hola.
Estoy instalando un nuevo GW de Voz 2921, y tengo problemas para realizar las llamadas. Aun no lo integro al CUCM, pero he creado un anexo en ese GW para poder realizar los llamados  y pasa nada.
Dejo una copia  del Debug y parte de SH RUN;
2921-voice#
Nov 28 02:51:59.071: %IPPHONE-6-REG_ALARM: 12: Name=SEPF029295A556F Load=SCCP69x        x.9-3-1-3 Last=CM-reset-TCP
Nov 28 02:51:59.071: %IPPHONE-6-REG_ALARM: 12: Name=SEPB4E9B0004064 Load=SCCP69x        x.9-3-1-3 Last=CM-reset-TCP
Nov 28 02:51:59.075: %IPPHONE-6-REGISTER_NEW: ephone-1:SEPF029295A556F IP:10.203        .123.11 Socket:3 DeviceType:Phone has registered.
Nov 28 02:51:59.075: %IPPHONE-6-REGISTER_NEW: ephone-2:SEPB4E9B0004064 IP:10.203        .123.12 Socket:4 DeviceType:Phone has registered.
Nov 28 02:51:59.075: %IPPHONE-6-REG_ALARM: 12: Name=SEP54781A6B1308 Load=SCCP69x        x.9-3-1-3 Last=CM-reset-TCP
Nov 28 02:51:59.075: %IPPHONE-6-REGISTER_NEW: ephone-3:SEP54781A6B1308 IP:10.203        .118.35 Socket:2 DeviceType:Phone has registered.
Nov 28 02:52:00.219: %IPPHONE-6-REGISTER_NEW: ephone-4:SEP001A4D4EADE3 IP:10.203        .117.8 Socket:1 DeviceType:Phone has registered.
Nov 28 02:52:00.615: %IPPHONE-6-REGISTER_NEW: ephone-5:SEPEAACUNA IP:10.175.33.1        1 Socket:5 DeviceType:Phone has registered.
Nov 28 02:52:43.191: //-1/FCB1CB128007/CCAPI/cc_api_display_ie_subfields:
   cc_api_call_setup_ind_common:
   cisco-username=
   ----- ccCallInfo IE subfields -----
   cisco-ani=2849
   cisco-anitype=0
   cisco-aniplan=0
   cisco-anipi=0
   cisco-anisi=0
   dest=
   cisco-desttype=0
   cisco-destplan=0
   cisco-rdie=FFFFFFFF
   cisco-rdn=
   cisco-rdntype=0
   cisco-rdnplan=0
   cisco-rdnpi=0
   cisco-rdnsi=0
   cisco-redirectreason=0   fwd_final_type =0
   final_redirectNumber =
   hunt_group_timeout =0
Nov 28 02:52:43.195: //-1/FCB1CB128007/CCAPI/cc_api_call_setup_ind_common:
   Interface=0x23749FA8, Call Info(
   Calling Number=2849,(Calling Name=)(TON=Unknown, NPI=Unknown, Screening=Not S        creened, Presentation=Allowed),
   Called Number=(TON=Unknown, NPI=Unknown),
   Calling Translated=FALSE, Subscriber Type Str=RegularLine, FinalDestinationFl        ag=FALSE,
   Incoming Dial-peer=20004, Progress Indication=ORIGINATING SIDE IS NON ISDN(3)        , Calling IE Present=TRUE,
   Source Trkgrp Route Label=, Target Trkgrp Route Label=, CLID Transparent=FALS        E), Call Id=-1
Nov 28 02:52:43.195: //-1/FCB1CB128007/CCAPI/ccCheckClipClir:
   In: Calling Number=2849(TON=Unknown, NPI=Unknown, Screening=Not Screened, Pre        sentation=Allowed)
   Out: Calling Number=2849(TON=Unknown, NPI=Unknown, Screening=Not Screened, Pr        esentation=Allowed)
Nov 28 02:52:43.195: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
Nov 28 02:52:43.195: :cc_get_feature_vsa malloc success
Nov 28 02:52:43.195:  cc_get_feature_vsa count is 1
Nov 28 02:52:43.195: :FEATURE_VSA attributes are: feature_name:0,feature_time:59        9106632,feature_id:6
Nov 28 02:52:43.195: //6/FCB1CB128007/CCAPI/cc_api_call_setup_ind_common:
   Set Up Event Sent;
   Call Info(Calling Number=2849(TON=Unknown, NPI=Unknown, Screening=Not Screene        d, Presentation=Allowed),
   Called Number=(TON=Unknown, NPI=Unknown))
Nov 28 02:52:43.195: //6/FCB1CB128007/CCAPI/cc_process_call_setup_ind:
   Event=0x22D53830
Nov 28 02:52:43.195: //6/FCB1CB128007/CCAPI/ccCallSetContext:
   Context=0x39E6FFF8
   >>>>CCAPI handed cid 6 with tag 20004 to app "_ManagedAppProcess_Default"
Nov 28 02:52:43.195: //6/FCB1CB128007/CCAPI/ccCallSetupAck:
   Call Id=6
Nov 28 02:52:43.195: //6/FCB1CB128007/CCAPI/cc_api_set_transfer_info:
   Transfer Number=, Transfer Reason=0x0
Nov 28 02:52:43.195: //6/FCB1CB128007/CCAPI/ccGenerateToneInfo:
   Stop Tone On Digit=TRUE, Tone=Dial Tone,
   Tone Direction=Network, Params=0x0, Call Id=6
Nov 28 02:52:43.195: //6/FCB1CB128007/CCAPI/ccSetDigitTimeouts:
   Initial Digit Timeout=-1000(ms), Inter Digit Timeout=-1000(ms)
   Call Entry(Inter Digit Timeout=10000(ms), Initial Digit Timeout=10000(ms))
Nov 28 02:52:43.195: //6/FCB1CB128007/CCAPI/ccCallReportDigits:
   (callID=0x6, digit_event=0x1, enable=TRUE, consume=FALSE)
   Enabled=TRUE, Call Id=6
Nov 28 02:52:43.195: //6/FCB1CB128007/CCAPI/cc_api_call_report_digits_done:
   (vdbPtr=0x23749FA8, callID=0x6, disp=0, digit_event=0x1, enable=TRUE, consume        =FALSE)
   Enabled=TRUE, Disposition=0x0, Interface=0x23749FA8, Call Id=6
   Call Entry(Initial Digit Timeout=15000(ms), Inter Digit Timeout=10000(ms))
Nov 28 02:52:44.843: //6/FCB1CB128007/CCAPI/cc_api_call_digit_begin:
   Destination Interface=0x0, Destination Mask=0x3, Destination Call Id=-1,
   Source Call Id=6, Digit=9, DigitBeginFlags=0x0,
   Rtp Timestamp=0xBB8, Rtp Expiration=0x0
Nov 28 02:52:44.843: //6/FCB1CB128007/CCAPI/cc_api_call_digit_end:
   Source Call Id=6, Digit=9, Duration=100,
   Xrule Calling Tag=0, Xrule Called Tag=0, Digit Tone Mode=DTMF
   Call Entry(Handoff Depth=0)
Nov 28 02:52:44.843: //6/FCB1CB128007/CCAPI/ccCallReportDigits:
   (callID=0x6, digit_event=0x0, enable=FALSE, consume=FALSE)
Nov 28 02:52:44.843: //6/FCB1CB128007/CCAPI/cc_api_call_report_digits_done:
   (vdbPtr=0x23749FA8, callID=0x6, disp=0, digit_event=0x0, enable=FALSE, consum        e=FALSE)
Nov 28 02:52:44.843: //6/FCB1CB128007/CCAPI/ccCallDisconnect:
   Cause Value=28, Tag=0x0, Call Entry(Previous Disconnect Cause=0, Disconnect C        ause=0)
   Cause Value=28, Call Entry(Responsed=TRUE, Cause Value=28)
Nov 28 02:52:44.843: //6/FCB1CB128007/CCAPI/cc_api_get_transfer_info:
   Transfer Number=NULL
chile-mampil-2921-voice#
Nov 28 02:53:10.599: //6/FCB1CB128007/CCAPI/cc_api_call_disconnect_done:
   Disposition=0, Interface=0x23749FA8, Tag=0x0, Call Id=6,
   Call Entry(Disconnect Cause=28, Voice Class Cause Code=0, Retry Count=0)
   Call Disconnect Event Sent
Nov 28 02:53:10.599: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
Nov 28 02:53:10.599: :cc_free_feature_vsa freeing 23B5A440
Nov 28 02:53:10.599:  vsacount in free is 0
Nov 28 02:55:38.646: %IPPHONE-6-UNREGISTER_NORMAL: ephone-2:SEPB4E9B0004064 IP:1        0.203.123.12 Socket:4 DeviceType:Phone has unregistered normally.
Nov 28 02:55:40.358: %IPPHONE-6-UNREGISTER_NORMAL: ephone-4:SEP001A4D4EADE3 IP:1        0.203.117.8 Socket:1 DeviceType:Phone has unregistered normally.
Nov 28 02:55:40.662: %IPPHONE-6-UNREGISTER_NORMAL: ephone-3:SEP54781A6B1308 IP:1        0.203.118.35 Socket:2 DeviceType:Phone has unregistered normally.
Nov 28 02:55:41.650: %IPPHONE-6-UNREGISTER_NORMAL: ephone-1:SEPF029295A556F IP:1        0.203.123.11 Socket:3 DeviceType:Phone has unregistered normally.
Nov 28 02:55:48.654: %IPPHONE-6-UNREGISTER_NORMAL: ephone-5:SEPEAACUNA IP:10.175        .33.11 Socket:5 DeviceType:Phone has unregistered normally.
Nov 28 02:56:10.598: //-1/xxxxxxxxxxxx/CCAPI/ccAppShutdownMode:
   remove it from the queue
isdn switch-type primary-net5
voice-card 0
dspfarm
dsp services dspfarm
voice class codec 1
codec preference 1 g711ulaw
codec preference 2 g711alaw
codec preference 3 g729r8
voice translation-rule 1
rule 1 /.*/ /2542600/  ---> N° de telefono (E1)
voice translation-rule 2
rule 1 /^254/ //
voice translation-profile Anexos
translate called 2
voice translation-profile Cabecera
translate calling 1
license udi pid CISCO2921/K9 sn FTX1723ALVJ
hw-module pvdm 0/0
username cisco privilege 15 password 0 cisco
redundancy
controller E1 0/0/0
framing NO-CRC4
pri-group timeslots 1-31
control-plane
voice-port 0/0/0:15
translation-profile incoming Anexos
translation-profile outgoing Cabecera
bearer-cap Speech
mgcp profile default
dial-peer voice 1 pots
destination-pattern 9T
direct-inward-dial
port 0/0/0:15
dial-peer voice 2 voip
destination-pattern 2...
session target ipv4:10.203.120.157
dtmf-relay rtp-nte h245-alphanumeric
gatekeeper
shutdown
call-manager-fallback
max-conferences 8 gain -6
transfer-system full-consult
ip source-address 10.203.124.189 port 2000
max-ephones 100
max-dn 100
system message primary Telefonia en Contingencia
time-format 24
banner login ^CC
*                     AUTHORIZED ACCESS ONLY                     *
* THIS SYSTEM IS RESTRICTED TO DUKE ENERGY AUTHORIZED USERS ONLY.*
*  THE UNAUTHORIZED ACCESS, USE OR MODIFICATION OF THIS SYSTEM,  *
*  DATA CONTAINED IN THIS SYSTEM OR DATA IN TRANSIT TO OR FROM   *
*         THIS SYSTEM IS SUBJECT TO CRIMINAL PENALTIES           *
*                     AND CIVIL LIABILITY.                       *
^C
line con 0
login local
line aux 0
line 2
no activation-character
no exec
transport preferred none
transport input all
transport output pad telnet rlogin lapb-ta mop udptn v120 ssh
stopbits 1
line vty 0 4
privilege level 15
login local
transport input telnet ssh
line vty 5 15
privilege level 15
login local
scheduler allocate 20000 1000
ntp peer 148.134.153.65
end
Saludos cordiales.
1 RESPUESTA
Re: Problemas Outgoing-Inbound GW voz
Hola,
Por favor check los trunks CUCM con GWY y (dialpeer voip)
voice call send-alert
voice call carrier capacity active
voice rtp send-recv
voice service voip
ip address trusted list
  ipv4 10.X.X.X 255.255.248.X
allow-connections h323 to sip
allow-connections sip to h323
allow-connections sip to sip
redirect ip2ip
fax protocol t38 version 0 ls-redundancy 0 hs-redundancy 0 fallback none
sip
  bind control source-interface GigabitEthernet0/0
  bind media source-interface GigabitEthernet0/0
  registrar server expires max 600 min 60
  redirect contact order best-match
voice class codec 1
codec preference 3 g729br8
codec preference 4 g729r8
voice class h323 1
  h225 timeout tcp establish 4
description "-------[Rede de Voz]"
ip address 10.X.X.X  255.255.248.X
no ip redirects
no ip unreachables
no ip proxy-arp
ip flow ingress
h323-gateway voip interface
h323-gateway voip bind srcaddr 10.X.X.X
dial-peer voice 401 voip
description -------------[dialplan-to-CCM-01]
preference 1
session target ipv4:10.x.x.x
voice-class codec 1
voice-class h323 1
dtmf-relay h245-signal rtp-nte h245-alphanumeric
fax-relay ecm disable
no fax-relay sg3-to-g3
fax protocol pass-through g711ulaw
Best regards,
Daniel Sobrinho
Daniel Sobrinho
285
Visitas
ÚTIL
Respuestas
