2851 Router VPN - stack for level DMA/Timer Interrupt running low 36/9000
I have a site to site VPN. On my hub router I am seeing the following message EVERY minute in the log!
%sys-6-stacklow: stack for level DMA/Timer Interrupt running low, 36/9000
I have been trying to figure out what the DMA/Timer Interrupt is and what is causing it to run low.
If I run the "show stacks" command I can see:
<output omitted>
Interrupt level stacks:
Level     Called     Unused/Size     Name
2      1578216246     36/9000     DMA/Timer Interrupt
I am also occasionaly seeing the following
%crypto--4-pkt_replay_error:decrypt: replay check failed connection id=7 sequence number=16171319
I don't know if they are related or not, but I need to find out what is causing the DMA/timer interrupt messages.
Thanks.
463
