ada5500 vpn same interface
I have gotten this working for clients who are vpned in and then are able to access sites in which the ASA has a site to site tunnel. Can this also be done between site to site tunnels? I can't seem to get it work. ASA A has a site to site with ASA B and ASA C. I want users at ASA C to access ASA B without making a separate tunnel between ASA B and ASA C by having the traffic come from ASA B to ASA A and then have it go out the same interface toward ASA C. Sifficently, complicated?
Thx
Hall of Fame Super Blue
Re: ada5500 vpn same interface
Yes it can be done on an ASA device.
You will need to add the command "same-security-traffic permit intra-interface". You then need to make sure that traffic coming out of tunnel from site B is defined as intersting traffic in the IPSEC crypto map for site C and vice-versa.
Jon
Please find attached a configuration example:
http://cisco.com/en/US/products/hw/vpndevc/ps2030/products_configuration_example09186a00804675ac.shtml
Please rate if this helped.
Daniel
Daniel,
Thx much. Problem turned out to be at site C which was a Watchguard. It is now working.
Bill
Thanks Jon,
The problem turned out to be at Site C which was Watchguard. Got it working.
121
