ASA will not take setting from ASDM
I am setting up a new ASA 5505
ASA Version 7.2.(4) ASDM Version 5.2(4)
I am using the Startup Wizard and I want to set the inside to 192.168.10.1 because I will be VPN'ing to another ASA already at 192.168.1.1.
I run through the wizard, change DHCP, disable DMZ option (not needed). I click the final save setting.
And the setting are not saved.
ASDM is locked out but Router still at same IP, even after power cycle.....
[ERROR] Interface vlan1
                ASDM received an error while sending this command.  Click Resend and, if the browser
prompts you to verify a new certificate or to provide a username and password, please do so.
"I have accept the certificate and am still using the default user name and password"
      Interface vlan1
[ERROR] ip address  192.168.10.1 255.255.255.0
                Command not sent.
[ERROR] Interface vlan3
                Command not sent.
      Interface vlan3
[ERROR] shutdown
                Command not sent.
[ERROR] ip address  10.10.50.1 255.255.255.0
                Command not sent.
[ERROR] no dhcpd address 192.168.1.2-192.168.1.33 inside
                Command not sent.
Any suggestions on what I am missing??
Client does have internet access, but I not going to try the VPN unitl I have different internal ranges.
1 ACCEPTED SOLUTION
Re: ASA will not take setting from ASDM
One way around this is to set the inside IP Address using a console cable ... Then go back to using the ASDM on the new IP address.  You will probably also need to change the addresses from where you are allowed to manage your ASA.
I used to have conflicts between the DHCP settings and the IP address of the interface on the PIX.  Don't remember if it's the same for the ASA.... but you may need to remove the DHCP, change the IP address and reconfigure the DHCP
Using the Console did fix issue
This command below reset DHCPD, ASDM, etc
conf factory-default 192.168.10.1 255.255.255.0
write memory
Thanks for the Suggestions
2256
