ASA5505 L2L VPN does not function after move and reconfiguration
                   I have an ASA5505 that had multiple VPNs to both Cisco5505's and other Vendor security appliances.  The one in question that moved to a new IP address checks out on isa sa, ipsec sa and nat, yet there is no communication accross the tunnel.  This behavior is consistent accross all remote sites. The remote sites function normally. Below is the output with some show commands.
ASA Version 8.4(4)
hostname RitterBars
names
name 67.231.37.42 RitterLAB-ASA
name 67.231.37.45 RitterLAB-LB-WAN1
name 64.233.131.94 RitterLAB-LB-WAN3
interface Ethernet0/0
switchport access vlan 2
interface Ethernet0/1
switchport access vlan 3
interface Ethernet0/2
interface Ethernet0/3
interface Ethernet0/4
interface Ethernet0/5
interface Ethernet0/6
interface Ethernet0/7
interface Vlan1
nameif inside
security-level 100
interface Vlan2
description Port 7 on 9108
nameif outside
security-level 0
ip address dhcp setroute
interface Vlan3
no forward interface Vlan2
nameif CoreNetwork
security-level 0
ip address 172.20.10.22 255.255.255.128
boot system disk0:/asa844-k8.bin
ftp mode passive
clock timezone CST -6
clock summer-time CST recurring
object network obj-192.168.1.0
subnet 192.168.1.0 255.255.255.0
object network obj-192.168.9.0
subnet 192.168.9.0 255.255.255.0
object network obj-192.168.85.0
subnet 192.168.85.0 255.255.255.0
object network obj-10.200.1.0
subnet 10.200.1.0 255.255.255.0
object network obj-192.168.3.0
subnet 192.168.3.0 255.255.255.0
object network obj-192.168.1.2
host 192.168.1.2
object service obj-tcp-source-eq-22
service tcp source eq ssh
object service obj-tcp-source-eq-5922
service tcp source eq 5922
object network obj-192.168.1.10
host 192.168.1.10
object service obj-tcp-source-eq-5125
service tcp source eq 5125
object service obj-tcp-source-eq-80
service tcp source eq www
object network obj-192.168.1.119
host 192.168.1.119
object service obj-udp-source-eq-69
service udp source eq tftp
object network obj-192.168.1.51
host 192.168.1.51
object service obj-tcp-source-eq-443
service tcp source eq https
object service obj-tcp-source-eq-5980
service tcp source eq 5980
object network obj-192.168.1.114
host 192.168.1.114
object network obj-96.43.39.27
host 96.43.39.27
object network obj-xxx.xxx.xxx.xxx
host xxx.xxx.xxx.xxx
object-group network Inside
network-object 192.168.1.0 255.255.255.0
access-list split-tunnel extended permit ip 192.168.1.0 255.255.255.0 192.168.9.0 255.255.255.0
access-list no_nat extended permit ip 192.168.1.0 255.255.255.0 192.168.9.0 255.255.255.0
access-list no_nat extended permit ip 192.168.1.0 255.255.255.0 192.168.85.0 255.255.255.0
access-list no_nat extended permit ip 192.168.1.0 255.255.255.0 10.200.1.0 255.255.255.0
access-list no_nat extended permit ip 192.168.1.0 255.255.255.0 192.168.3.0 255.255.255.0
access-list VPN2LAB extended permit ip 192.168.1.0 255.255.255.0 192.168.85.0 255.255.255.0
access-list VPN2LAB extended permit ip 192.168.1.0 255.255.255.0 10.200.1.0 255.255.255.0
access-list Barracudalab extended permit ip 192.168.1.0 255.255.255.0 192.168.3.0 255.255.255.0
access-list inat extended permit ip 192.168.1.0 255.255.255.0 any
access-list vnat extended permit ip 192.168.1.0 255.255.255.0 host 216.163.29.244
access-list out2in extended permit tcp host 64.233.128.6 host 192.168.1.2 eq ssh
access-list out2in extended permit tcp 64.233.128.0 255.255.255.0 host 192.168.1.2 eq ssh
access-list out2in extended permit tcp 64.233.128.0 255.255.255.0 host 192.168.1.10 eq 5125
access-list out2in extended permit tcp 64.233.128.0 255.255.255.0 host 192.168.1.10 eq www
access-list out2in extended permit udp 64.233.128.0 255.255.255.0 host 192.168.1.119 eq tftp
access-list out2in extended permit tcp 64.233.128.0 255.255.255.0 host 192.168.1.51 eq https
access-list out2in extended permit ip 64.233.128.0 255.255.255.0 192.168.1.0 255.255.255.0
access-list out2in extended permit tcp any host 192.168.1.10 eq 5125
access-list out2in extended permit tcp any host 192.168.1.10 eq www
access-list out2in extended permit tcp any 192.168.1.0 255.255.255.0 eq ftp
access-list out2in extended permit tcp any 192.168.1.0 255.255.255.0 eq ftp-data
access-list out2in extended permit udp any host 192.168.1.119 eq tftp
access-list out2in extended permit tcp any host 192.168.1.51 eq https
access-list out2in extended permit icmp any any
pager lines 24
logging console alerts
logging asdm informational
mtu inside 1500
mtu outside 1500
mtu CoreNetwork 1500
ip local pool vpn-pool 192.168.9.10-192.168.9.250
icmp unreachable rate-limit 1 burst-size 1
asdm image disk0:/asdm-649.bin
no asdm history enable
arp timeout 14400
nat (inside,any) source static obj-192.168.1.0 obj-192.168.1.0 destination static obj-192.168.9.0 obj-192.168.9.0 no-proxy-arp
nat (inside,any) source static obj-192.168.1.0 obj-192.168.1.0 destination static obj-192.168.85.0 obj-192.168.85.0 no-proxy-arp
nat (inside,any) source static obj-192.168.1.0 obj-192.168.1.0 destination static obj-10.200.1.0 obj-10.200.1.0 no-proxy-arp
nat (inside,any) source static obj-192.168.1.0 obj-192.168.1.0 destination static obj-192.168.3.0 obj-192.168.3.0 no-proxy-arp
nat (inside,outside) source static obj-192.168.1.2 interface service obj-tcp-source-eq-22 obj-tcp-source-eq-5922
nat (inside,outside) source static obj-192.168.1.10 interface service obj-tcp-source-eq-5125 obj-tcp-source-eq-5125
nat (inside,outside) source static obj-192.168.1.10 interface service obj-tcp-source-eq-80 obj-tcp-source-eq-80
nat (inside,outside) source static obj-192.168.1.119 interface service obj-udp-source-eq-69 obj-udp-source-eq-69
nat (inside,outside) source static obj-192.168.1.51 interface service obj-tcp-source-eq-443 obj-tcp-source-eq-5980
nat (inside,outside) source static obj-192.168.1.114 obj-96.43.39.27
nat (inside,CoreNetwork) source dynamic obj-192.168.1.0 interface destination static obj-xxx.xxx.xxx.xxx obj-xxx.xxx.xxx.xxx
nat (inside,outside) source dynamic Inside interface
nat (inside,outside) after-auto source dynamic any interface
access-group out2in in interface outside
route CoreNetwork 172.20.30.0 255.255.255.248 172.20.10.1 1
route CoreNetwork 216.163.29.244 255.255.255.255 172.20.10.1 1
timeout xlate 3:00:00
timeout pat-xlate 0:00:30
timeout conn 0:00:00 half-closed 0:10:00 udp 0:02:00 icmp 0:00:02
timeout sunrpc 0:10:00 h323 0:05:00 h225 1:00:00 mgcp 0:05:00 mgcp-pat 0:05:00
timeout sip 0:30:00 sip_media 0:02:00 sip-invite 0:03:00 sip-disconnect 0:02:00
timeout sip-provisional-media 0:02:00 uauth 0:05:00 absolute
timeout tcp-proxy-reassembly 0:01:00
timeout floating-conn 0:00:00
dynamic-access-policy-record DfltAccessPolicy
user-identity default-domain LOCAL
aaa authentication ssh console LOCAL
http server enable
http 192.168.1.0 255.255.255.0 inside
no snmp-server location
no snmp-server contact
snmp-server enable traps snmp authentication linkup linkdown coldstart
crypto ipsec ikev1 transform-set ESP-3DES-SHA esp-3des esp-sha-hmac
crypto ipsec ikev1 transform-set psset esp-aes-256 esp-sha-hmac
crypto ipsec ikev1 transform-set ESP-AES-128-SHA esp-aes esp-sha-hmac
crypto ipsec ikev1 transform-set ESP-AES-128-MD5 esp-aes esp-md5-hmac
crypto ipsec ikev1 transform-set ESP-AES-192-SHA esp-aes-192 esp-sha-hmac
crypto ipsec ikev1 transform-set ESP-AES-192-MD5 esp-aes-192 esp-md5-hmac
crypto ipsec ikev1 transform-set ESP-AES-256-SHA esp-aes-256 esp-sha-hmac
crypto ipsec ikev1 transform-set ESP-AES-256-MD5 esp-aes-256 esp-md5-hmac
crypto ipsec ikev1 transform-set ESP-3DES-MD5 esp-3des esp-md5-hmac
crypto ipsec ikev1 transform-set ESP-DES-SHA esp-des esp-sha-hmac
crypto ipsec ikev1 transform-set ESP-DES-MD5 esp-des esp-md5-hmac
crypto map samap 1 match address VPN2LAB
crypto map samap 1 set peer RitterLAB-ASA
crypto map samap 1 set ikev1 transform-set ESP-AES-256-SHA
crypto map samap 2 match address Barracudalab
crypto map samap 2 set peer RitterLAB-LB-WAN1 RitterLAB-LB-WAN3
crypto map samap 2 set ikev1 transform-set ESP-3DES-SHA
crypto map samap interface outside
crypto isakmp identity address
crypto ikev1 enable outside
crypto ikev1 policy 10
authentication pre-share
encryption aes-256
hash sha
group 2
lifetime 86400
crypto ikev1 policy 11
encryption 3des
hash sha
group 2
lifetime 86400
telnet timeout 5
ssh 192.168.1.0 255.255.255.0 inside
ssh timeout 5
ssh key-exchange group dh-group1-sha1
console timeout 0
management-access inside
dhcpd dns 64.233.128.10 64.233.128.11
dhcpd auto_config outside
dhcpd address 192.168.1.100-192.168.1.150 inside
dhcpd enable inside
threat-detection basic-threat
threat-detection statistics access-list
no threat-detection statistics tcp-intercept
ntp server 66.187.233.4 source outside
ntp server 64.99.80.30 source outside
webvpn
username xxx.xxx.xxx.xxx password xxx.xxx.xxx.xxx encrypted privilege 15
username xxx.xxx.xxx.xxx attributes
vpn-group-policy WebVPNpolicy
tunnel-group 67.231.37.42 type ipsec-l2l
tunnel-group 67.231.37.42 ipsec-attributes
ikev1 pre-shared-key xxx.xxx.xxx.xxx
tunnel-group 67.231.37.45 type ipsec-l2l
tunnel-group 67.231.37.45 ipsec-attributes
tunnel-group 64.233.131.94 type ipsec-l2l
tunnel-group 64.233.131.94 ipsec-attributes
class-map inspection_default
match default-inspection-traffic
policy-map type inspect dns preset_dns_map
parameters
  message-length maximum 512
policy-map global_policy
class inspection_default
  inspect ftp
  inspect h323 h225
  inspect h323 ras
  inspect netbios
  inspect rsh
  inspect rtsp
  inspect skinny
  inspect esmtp
  inspect sqlnet
  inspect sunrpc
  inspect xdmcp
  inspect ip-options
  inspect tftp
service-policy global_policy global
prompt hostname context
no call-home reporting anonymous
call-home
profile CiscoTAC-1
  no active
  destination address http https://tools.cisco.com/its/service/oddce/services/DDCEService
  destination address email callhome@cisco.com
  destination transport-method http
  subscribe-to-alert-group diagnostic
  subscribe-to-alert-group environment
  subscribe-to-alert-group inventory periodic monthly
  subscribe-to-alert-group configuration periodic monthly
  subscribe-to-alert-group telemetry periodic daily
Cryptochecksum:bcdf7281cbf323ff6af7457149529a5b
: end
RitterBars# sh isa sa
IKEv1 SAs:
   Active SA: 2
    Rekey SA: 0 (A tunnel will report 1 Active and 1 Rekey SA during rekey)
Total IKE SA: 2
1   IKE Peer: 67.231.37.45
    Type    : L2L             Role    : responder
    Rekey   : no              State   : MM_ACTIVE
2   IKE Peer: 67.231.37.42
    Type    : L2L             Role    : initiator
There are no IKEv2 SAs
RitterBars# sh ipsec sa
interface: outside
    Crypto map tag: samap, seq num: 1, local addr: 96.43.41.168
      local ident (addr/mask/prot/port): (192.168.1.0/255.255.255.0/0/0)
      remote ident (addr/mask/prot/port): (192.168.85.0/255.255.255.0/0/0)
      current_peer: 67.231.37.42
      #pkts encaps: 4, #pkts encrypt: 4, #pkts digest: 4
      #pkts decaps: 0, #pkts decrypt: 0, #pkts verify: 0
      #pkts compressed: 0, #pkts decompressed: 0
      #pkts not compressed: 4, #pkts comp failed: 0, #pkts decomp failed: 0
      #pre-frag successes: 0, #pre-frag failures: 0, #fragments created: 0
      #PMTUs sent: 0, #PMTUs rcvd: 0, #decapsulated frgs needing reassembly: 0
      #send errors: 0, #recv errors: 0
      local crypto endpt.: 96.43.41.168/0, remote crypto endpt.: 67.231.37.42/0
      path mtu 1500, ipsec overhead 74, media mtu 1500
      current outbound spi: 6F98A015
      current inbound spi : 6DD466F0
    inbound esp sas:
      spi: 0x6DD466F0 (1842636528)
         transform: esp-aes-256 esp-sha-hmac no compression
         in use settings ={L2L, Tunnel, }
         slot: 0, conn_id: 1122304, crypto-map: samap
         sa timing: remaining key lifetime (kB/sec): (4374000/28182)
         IV size: 16 bytes
         replay detection support: Y
         Anti replay bitmap:
          0x00000000 0x00000001
    outbound esp sas:
      spi: 0x6F98A015 (1872273429)
         sa timing: remaining key lifetime (kB/sec): (4373999/28182)
         IV size: 16 bytes
         Anti replay bitmap:
    Crypto map tag: samap, seq num: 2, local addr: 96.43.41.168
      remote ident (addr/mask/prot/port): (192.168.3.0/255.255.255.0/0/0)
      current_peer: 67.231.37.45
      #pkts encaps: 0, #pkts encrypt: 0, #pkts digest: 0
      #pkts not compressed: 0, #pkts comp failed: 0, #pkts decomp failed: 0
      local crypto endpt.: 96.43.41.168/0, remote crypto endpt.: 67.231.37.45/0
      path mtu 1500, ipsec overhead 58, media mtu 1500
      current outbound spi: 51AF17EA
      current inbound spi : 859BC586
    inbound esp sas:
      spi: 0x859BC586 (2241578374)
         transform: esp-3des esp-sha-hmac no compression
         slot: 0, conn_id: 1118208, crypto-map: samap
         sa timing: remaining key lifetime (sec): 28152
         IV size: 8 bytes
         Anti replay bitmap:
    outbound esp sas:
      spi: 0x51AF17EA (1370429418)
         IV size: 8 bytes
         Anti replay bitmap:
RitterBars# sh nat int inside
Manual NAT Policies (Section 1)
1 (inside) to (any) source static obj-192.168.1.0 obj-192.168.1.0   destination static obj-192.168.9.0 obj-192.168.9.0 no-proxy-arp
    translate_hits = 0, untranslate_hits = 0
2 (inside) to (any) source static obj-192.168.1.0 obj-192.168.1.0   destination static obj-192.168.85.0 obj-192.168.85.0 no-proxy-arp
    translate_hits = 18, untranslate_hits = 0
3 (inside) to (any) source static obj-192.168.1.0 obj-192.168.1.0   destination static obj-10.200.1.0 obj-10.200.1.0 no-proxy-arp
4 (inside) to (any) source static obj-192.168.1.0 obj-192.168.1.0   destination static obj-192.168.3.0 obj-192.168.3.0 no-proxy-arp
5 (inside) to (outside) source static obj-192.168.1.2 interface   service obj-tcp-source-eq-22 obj-tcp-source-eq-5922
6 (inside) to (outside) source static obj-192.168.1.10 interface   service obj-tcp-source-eq-5125 obj-tcp-source-eq-5125
    translate_hits = 0, untranslate_hits = 9094
7 (inside) to (outside) source static obj-192.168.1.10 interface   service obj-tcp-source-eq-80 obj-tcp-source-eq-80
    translate_hits = 0, untranslate_hits = 126
8 (inside) to (outside) source static obj-192.168.1.119 interface   service obj-udp-source-eq-69 obj-udp-source-eq-69
9 (inside) to (outside) source static obj-192.168.1.51 interface   service obj-tcp-source-eq-443 obj-tcp-source-eq-5980
    translate_hits = 0, untranslate_hits = 195
10 (inside) to (outside) source static obj-192.168.1.114 obj-96.43.39.27
11 (inside) to (CoreNetwork) source dynamic obj-192.168.1.0 interface   destination static obj-216.163.29.244 obj-216.163.29.244
    translate_hits = 107, untranslate_hits = 0
12 (inside) to (outside) source dynamic Inside interface
    translate_hits = 35387, untranslate_hits = 2940
Manual NAT Policies (Section 3)
1 (inside) to (outside) source dynamic any interface
    translate_hits = 291, untranslate_hits = 78
Everyone's tags (6)
599
