Backup VPN connection does not work
Hi expert,
Our customer has three data centers (HK, KW and NT). The VPN connections between each data center are working properly. (HK --> KW, HK-->NT and KW -->NT)
However, the fail over does not work. e.g. if VPN between HK and NT is down, HK traffic cannot go to alternative VPN connection to NT (i.e. HK --> KW --> NT).
Please let me know how to config the routers to have "resilient" service and what commands are missing.
Below please find the three routers' config files for your reference
rdge
Anita
=========== start of config file
! VPNHK01
crypto isakmp policy 10
authentication pre-share
group 2
crypto isakmp policy 20
group 2
crypto isakmp key bigsecret address 192.168.100.2
crypto isakmp key bigsecret address 192.168.100.6
crypto ipsec transform-set vpn-test esp-3des esp-sha-hmac
crypto map static-crypt 10 ipsec-isakmp
description VPN between HK and NT
set peer 192.168.100.2
set transform-set vpn-test
match address 110
crypto map static-crypt1 20 ipsec-isakmp
description VPN between HK and KW
set peer 192.168.100.6
match address 110
interface FastEthernet0/0
description connect to VPNNT01
ip address 192.168.100.1 255.255.255.252
interface FastEthernet1/0
description connect to VPNKW01
ip address 192.168.100.5 255.255.255.252
interface FastEthernet1/1
ip address 192.168.200.1 255.255.255.0
router ospf 50
network 192.168.200.0 0.0.0.255 area 0
access-list 110 permit ip 192.168.200.0 0.0.0.255 192.168.210.0 0.0.0.255
access-list 110 permit ip 192.168.200.0 0.0.0.255 192.168.220.0 0.0.0.255
VPNKW01
group 2
group 2
crypto isakmp key bigsecret address 192.168.100.5
crypto isakmp key bigsecret address 192.168.100.9
crypto map static-crypt1 10 ipsec-isakmp
description VPN between KW and HK
set peer 192.168.100.5
match address 120
crypto map static-crypt2 20 ipsec-isakmp
description VPN between KW and NT
set peer 192.168.100.9
match address 120
description connect to VPNHK01
ip address 192.168.100.6 255.255.255.252
ip address 192.168.100.10 255.255.255.252
  ip address 192.168.220.1 255.255.255.0
router ospf 50
network 192.168.220.0 0.0.0.255 area 0
access-list 120 permit ip 192.168.220.0 0.0.0.255 192.168.210.0 0.0.0.255
access-list 120 permit ip 192.168.220.0 0.0.0.255 192.168.200.0 0.0.0.255
VPNNT01
group 2
group 2
crypto isakmp key bigsecret address 192.168.100.1
crypto isakmp key bigsecret address 192.168.100.10
description VPN between NT and HK
set peer 192.168.100.1
match address 130
description VPN between NT and KW
set peer 192.168.100.10
match address 130
ip address 192.168.100.2 255.255.255.252
ip address 192.168.100.9 255.255.255.252
ip address 192.168.210.1 255.255.255.0
router ospf 50
network 192.168.210.0 0.0.0.255 area 0
access-list 130 permit ip 192.168.210.0 0.0.0.255 192.168.200.0 0.0.0.255
access-list 130 permit ip 192.168.210.0 0.0.0.255 192.168.220.0 0.0.0.255
==== end of config file
159
