Certificate error when using AnyConnect with AD and SecurID auth on a few clients
We have an ASA5510 set up with AnyConnect Essentials, with clients connecting from both XP and Win7.
This works as expected on most clients, but on 3 XP clients we get a strange error.
They get the software installed and connects successfully the first time.
On every connection attempt after that, they get a message saying "VPN connection terminated, the certificate was not found on smart card or smart card not present".
We do not use certificates for authentication at all (only LDAP and securid).
Trying to connect with a known good username/password on one of these computers, gives the same error.
Connecting with one of the problem users on a known working VPN setup/PC works every time.
If we remove the AnyConnect Client from one of the problem computers and then installs it again, it works the first time (as before).
Then all attempts after that gives the samme error.
The connection profile and settings for the affected users are identical to all others who work.
What could the problem be ?
1 ACCEPTED SOLUTION
Re: Certificate error when using AnyConnect with AD and SecurID
upgrade to
3.0.5075 solved my problem
Try Clearing the SSL State on Internet Explorer Options in Windows XP. Go to control panel, internet options, content, "Clear SSL State"
Also, under "content" go to the Certificate's tab and under "Trusted Root Cert Authorities" see if the SSL Certiciate for yor ASA5510 Appliance is listed as the Public IP of the outside interface. If not, add it to this list and try connecting again.
Thank you for the suggestions.
Tried clearing the SSL state with no success.
We are using a GoDaddy certificate for the device, so the GoDaddy root cert was already present.
What is strange is that connecting through the webpage works (after it has checked for updates etc), but directly from AnyConnect Secure Mobility Client gives the mentioned certificate error.
Best Regards,
Are
I see the same error after upgrading to version 3.0.4235, but only with people that use isabel/smartcardreaders.
upgrade to
Thank you for the information.
Just upgrading didn't work, but removing the client completely and then installing ver. 3.0.5075 worked.
3139
