change inside interface speed for pix 501
For some reason I can't change the speed on the inside interface on the pix 501. Whenever I try to use the command (interface ethernet1 10full) it comes back with the message: "ethernet1 can only be set to 100full".
Is there a way to change the speed? I need to do this beause of an mck box for voice over ip, it only works on 10baset network speeds.
Re: change inside interface speed for pix 501
As far as I know you can't do it because it is a four port unmanaged switch, not a single ethernet.
Hi, Try to set 10Half or leave it in auto mode. It will negotiate the Speed & duplex with peering device like phone/PC whatever.
Ninja
397
