cisco vpn connect problem with 3g dongle
I am trying to connect cisco vpn but every time i am getting following error while trying to connect from huawei 3g usb dongle in win8. for win7 it works fine with no issue. Also the problem is only form datacard, form lan and wireless interaface i can easily connect to vpn without any issue. Any help/idea/suggestion highly appreciated?
Cisco Systems VPN Client Version 5.0.07.0440
Copyright (C) 1998-2010 Cisco Systems, Inc. All Rights Reserved.
Client Type(s): Windows, WinNT
Running on: 6.2.9200
25     08:06:46.846  12/25/13  Sev=Info/4    CM/0x63100002
Begin connection process
26     08:06:46.848  12/25/13  Sev=Info/4    CM/0x63100004
Establish secure connection
27     08:06:46.848  12/25/13  Sev=Info/4    CM/0x63100024
Attempt connection with server "116.68.208.113"
28     08:06:46.849  12/25/13  Sev=Info/6    IKE/0x6300003B
Attempting to establish a connection with 116.68.208.113.
29     08:06:46.855  12/25/13  Sev=Info/4    IKE/0x63000001
Starting IKE Phase 1 Negotiation
30     08:06:46.858  12/25/13  Sev=Info/4    IKE/0x63000013
SENDING >>> ISAKMP OAK AG (SA, KE, NON, ID, VID(Xauth), VID(dpd), VID(Frag), VID(Nat-T), VID(Unity)) to 116.68.208.113
31     08:06:47.145  12/25/13  Sev=Info/4    IPSEC/0x63700008
IPSec driver successfully started
32     08:06:47.145  12/25/13  Sev=Info/4    IPSEC/0x63700014
Deleted all keys
33     08:06:52.144  12/25/13  Sev=Info/4    IKE/0x63000021
Retransmitting last packet!
34     08:06:52.144  12/25/13  Sev=Info/4    IKE/0x63000013
SENDING >>> ISAKMP OAK AG (Retransmission) to 116.68.208.113
35     08:06:57.144  12/25/13  Sev=Info/4    IKE/0x63000021
36     08:06:57.144  12/25/13  Sev=Info/4    IKE/0x63000013
37     08:07:02.145  12/25/13  Sev=Info/4    IKE/0x63000021
38     08:07:02.145  12/25/13  Sev=Info/4    IKE/0x63000013
39     08:07:07.145  12/25/13  Sev=Info/4    IKE/0x63000017
Marking IKE SA for deletion  (I_Cookie=97205EA6A12866F0 R_Cookie=0000000000000000) reason = DEL_REASON_PEER_NOT_RESPONDING
40     08:07:07.645  12/25/13  Sev=Info/4    IKE/0x6300004B
Discarding IKE SA negotiation (I_Cookie=97205EA6A12866F0 R_Cookie=0000000000000000) reason = DEL_REASON_PEER_NOT_RESPONDING
41     08:07:07.645  12/25/13  Sev=Info/4    CM/0x63100014
Unable to establish Phase 1 SA with server "116.68.208.113" because of "DEL_REASON_PEER_NOT_RESPONDING"
42     08:07:07.645  12/25/13  Sev=Info/5    CM/0x63100025
Initializing CVPNDrv
43     08:07:07.645  12/25/13  Sev=Info/6    CM/0x63100046
Set tunnel established flag in registry to 0.
44     08:07:07.645  12/25/13  Sev=Info/4    IKE/0x63000001
IKE received signal to terminate VPN connection
45     08:07:08.146  12/25/13  Sev=Info/4    IPSEC/0x63700014
Deleted all keys
46     08:07:08.146  12/25/13  Sev=Info/4    IPSEC/0x63700014
Deleted all keys
47     08:07:08.146  12/25/13  Sev=Info/4    IPSEC/0x63700014
Deleted all keys
48     08:07:08.146  12/25/13  Sev=Info/4    IPSEC/0x6370000A
IPSec driver successfully stopped
49     08:19:59.202  12/25/13  Sev=Info/4    CM/0x63100002
50     08:19:59.202  12/25/13  Sev=Info/4    CM/0x63100004
51     08:19:59.202  12/25/13  Sev=Info/4    CM/0x63100024
52     08:19:59.202  12/25/13  Sev=Info/6    IKE/0x6300003B
53     08:19:59.202  12/25/13  Sev=Info/4    IKE/0x63000001
54     08:19:59.218  12/25/13  Sev=Info/4    IKE/0x63000013
55     08:19:59.656  12/25/13  Sev=Info/4    IPSEC/0x63700008
56     08:19:59.656  12/25/13  Sev=Info/4    IPSEC/0x63700014
Deleted all keys
57     08:20:04.656  12/25/13  Sev=Info/4    IKE/0x63000021
58     08:20:04.656  12/25/13  Sev=Info/4    IKE/0x63000013
59     08:20:09.656  12/25/13  Sev=Info/4    IKE/0x63000021
60     08:20:09.656  12/25/13  Sev=Info/4    IKE/0x63000013
61     08:20:14.656  12/25/13  Sev=Info/4    IKE/0x63000021
62     08:20:14.656  12/25/13  Sev=Info/4    IKE/0x63000013
63     08:20:19.656  12/25/13  Sev=Info/4    IKE/0x63000017
Marking IKE SA for deletion  (I_Cookie=46B8917FD54C64AC R_Cookie=0000000000000000) reason = DEL_REASON_PEER_NOT_RESPONDING
64     08:20:20.156  12/25/13  Sev=Info/4    IKE/0x6300004B
Discarding IKE SA negotiation (I_Cookie=46B8917FD54C64AC R_Cookie=0000000000000000) reason = DEL_REASON_PEER_NOT_RESPONDING
65     08:20:20.156  12/25/13  Sev=Info/4    CM/0x63100014
66     08:20:20.156  12/25/13  Sev=Info/5    CM/0x63100025
67     08:20:20.156  12/25/13  Sev=Info/6    CM/0x63100046
68     08:20:20.156  12/25/13  Sev=Info/4    IKE/0x63000001
69     08:20:20.156  12/25/13  Sev=Info/4    IPSEC/0x63700014
Deleted all keys
70     08:20:20.156  12/25/13  Sev=Info/4    IPSEC/0x63700014
Deleted all keys
71     08:20:20.156  12/25/13  Sev=Info/4    IPSEC/0x63700014
Deleted all keys
72     08:20:20.156  12/25/13  Sev=Info/4    IPSEC/0x6370000A
VIP Purple
Re: cisco vpn connect problem with 3g dongle
The setup you are running (3G with Windows 8) is not supported with the legacy VPN-Client. it can work, but often enough it doesn't.
The best way to resolve that problem is to migrate to AnyConnect where your scenario is supported. Or you could try other clients like the one from Shrew-Soft.
Don't stop after you've improved your network! Improve the world by lending money to the working poor: http://www.kiva.org/invitedby/karsteni
Hi Karsten,
Thank you for the reply !!! & best wishes for the new year 2014.
The problem is like this, if i select datacard connection type to NDIS it works but it doesnt work when i select RAS(modem) connection type for 3G datacard it doesnt. (NDIS and RAS(Modem) connection types are the 2 modes currently supporetd by the datacard.). Is there any case the users are experiencing from the similar problem? and what they have done to solve the issues? And thank you for the workaroung, i have checked the shrew-soft with win7 and it was working fine but not on win8, i will check shrew-soft on win8 very soon. Also we can move to the anyconnect solution but just want to know if this can solve our problem or not? whether there will be any issues with anyconnect solution for win 8 or not? can you please confim.
Thank you
1004
