Community Member
DMVPN Dual Hub Dual Layout - Connect Hubs
I have a Dual Hub Dual DMVPN Layout.
One Hub at our main site, one at our DR site.
The two sites are connected via a MPLS connection only.
I want to create a tunnel between the two sites for backup purposes in case the MPLS goes down.
Can I utilize the DMVPN networks somehow or should I build a separate tunnel for this? (GRE or VTI)
319
