DMVPN Hub and Spoke behind NAT device
Hi All,
I have seen many documents stating about DMVPN Hub behind NAT or DMVPN Spoke behind NAT.
But My case i involve in both situation.
1) HUB have a Load Balancer (2 WAN Link) ISP A & B
2) Spoke have Load Balancer (2 WAN Link) ISP A & B
Now the requirement is Spoke ISP A Tunnel to HUB ISP A.  Spoke ISP B tunnel to HUB ISP B
So total of two DMVPN tunnel from spoke to hub, and i will use EIGRP and PBR to select path.
As I know at HUB site, LB must do Static NAT for HUB router IP, so spoke will point to it as tunnel destination address. At spoke LB, i will do policy route to reach HUB ISP A IP via Spoke ISP A link, HUB ISP B IP via Spoke ISP B link.
HUB and Spoke have to create 2 tunnel with two different network ID but using same source interface.
The Tunnel destination IP at spoke router is not directly belongs to HUB router. Its hold by HUB LB , and forwarded to HUB router by Static NAT.
Any problem will face with this setup? Any guide?
Sample config at HUB.
interface Tunnel0
bandwidth 1000
ip address 172.16.1.1 255.255.255.0
ip mtu 1440
ip nhrp authentication cisco123
ip nhrp map multicast dynamic
ip nhrp network-id 1
ip nhrp holdtime 600
delay 1000
tunnel source FastEthernet0/0
tunnel mode gre multipoint
tunnel key 0
tunnel protection ipsec profile cisco
interface Tunnel1
bandwidth 1000
ip address 172.17.1.1 255.255.255.0
ip mtu 1440
ip nhrp network-id 2
delay 1000
tunnel key 1
Spoke Config
interface Tunnel0
bandwidth 1000
ip address 172.16.1.2 255.255.255.0
ip mtu 1440
ip nhrp map 172.16.1.1 199.1.1.1
ip nhrp holdtime 300
ip nhrp nhs 172.16.1.1
delay 1000
tunnel destination 199.1.1.1
tunnel key 0
interface Tunnel1
bandwidth 1000
ip address 172.17.1.2 255.255.255.0
ip mtu 1440
ip nhrp map 172.17.1.1 200.1.1.1
ip nhrp nhs 172.17.1.1
delay 1500
tunnel destination 200.1.1.1
tunnel key 1
Regards, Nagis
983
