DMVPN problem with NAT
Hi All,
We are running DMVPN EIGRP topology in our network. The DMVPN hub aggregates all the spoke router networks via the tunnel. ALso the Spoke routers allow internet traffic by using NAT and only private traffic flows through the DMVPN tunnel. The IPSec is up and running fine and EIGRP works good.
Brief configs on Hub and Spoke are as below:
Spoke router:
interface Tunnel0
description VPN tunnel
bandwidth 400
ip address 172.28.1.159 255.255.252.0
ip nhrp authentication xxx
ip nhrp map 172.28.1.1 6x.xx.x.x
ip nhrp network-id 100000
ip nhrp holdtime 360
ip nhrp nhs 172.28.1.1
ip summary-address eigrp 100 10.159.0.0 255.255.0.0 5
delay 40000
qos pre-classify
tunnel source Serial0/0/1:0
tunnel destination 6x.xx.x.x
tunnel key xxxx
tunnel protection ipsec profile pppp
Hub Router:
interface Tunnel0
bandwidth 100000
ip address 172.28.1.1 255.255.252.0
no ip redirects
ip nhrp map multicast dynamic
ip nhrp network-id 100002
no ip split-horizon eigrp 100
load-interval 30
delay 40000
qos pre-classify
tunnel source GigabitEthernet0/1
tunnel mode gre multipoint
tunnel key xxxx
Rt#sh ip nat trans | i :500
udp 20x.y.y.y:500 10.159.99.251:500 6.x.x.x:500 6.x.x.x:500
The problem is when I get this entry in the NAT table of Spoke router, Crypto breaks and EIGRP goes down on the spoke router and DMVPN tunnel is completely down.
10.159.99.251 is gig0/0.99 private ip of the spoke router. I am not sure why we have some many entries for this UDP 500 ISAKMP connection instead of just one.
This happens even if any PC behind the Spoke router tries to establish IPSec connection with the hub router( which is not at all necessary)
Praful
1 REPLY
Anonymous
N/A
Re: DMVPN problem with NAT
For the NAT-Transparency Aware enhancement to work, you must use IPSec transport mode on the transform set. Also, even though NAT-Transparency (IKE and IPSec) can support two peers (IKE and IPSec) being translated to the same IP address (using the User Datagram Protocol [UDP] ports to differentiate them [this would be Peer Address Translation]), this functionality is not supported for DMVPN. All DMVPN spokes must have a unique IP address after they have been NAT translated. They can have the same IP address before they are NAT translated.
http://www.cisco.com/en/US/products/sw/iosswrel/ps1839/products_feature_guide09186a0080110ba1.html
187
