dmvpn problem
I have 3 tunnels. both three tunnel are using same phrasels.
tunnel 10 is OK but tunnel 20 and 30 have problem.
sh dmvpn
Legend: Attrb --> S - Static, D - Dynamic, I - Incomplete
        N - NATed, L - Local, X - No Socket
        # Ent --> Number of NHRP entries with same NBMA peer
        NHS Status: E --> Expecting Replies, R --> Responding
        UpDn Time --> Up or Down Time for a Tunnel
Interface: Tunnel10, IPv4 NHRP Details
IPv4 NHS: 10.72.60.1 RE
Type:Spoke, Total NBMA Peers (v4/v6): 1
# Ent  Peer NBMA Addr Peer Tunnel Add State  UpDn Tm Attrb    Target Network
    1   172.19.4.199      10.72.60.1    UP    2d00h    S      10.72.60.1/32
Interface: Tunnel20, IPv4 NHRP Details
IPv4 NHS: 10.72.216.1  E
    1     10.72.56.2     10.72.216.1  NHRP    never    S     10.72.216.1/32
Interface: Tunnel30, IPv4 NHRP Details
IPv4 NHS: 10.72.220.1  E
    1     10.72.56.3     10.72.220.1  NHRP 00:51:08    S     10.72.220.1/32
sh dmvpn detail
Intferface Tunnel10 is up/up, Addr. is 10.72.60.136, VRF ""
   Tunnel Src./Dest. addr: 10.72.206.50/MGRE, Tunnel VRF ""
   Protocol/Transport: "multi-GRE/IP", Protect "ES1AT1N"
Intferface Tunnel20 is up/up, Addr. is 10.72.216.136, VRF ""
   Tunnel Src./Dest. addr: 10.72.56.138/MGRE, Tunnel VRF ""
Intferface Tunnel30 is up/up, Addr. is 10.72.220.136, VRF ""
   Tunnel Src./Dest. addr: 172.33.3.30/MGRE, Tunnel VRF ""
    1     10.72.56.3     10.72.220.1  NHRP 00:51:31    S     10.72.220.1/32
Crypto Session Details:
Interface: Tunnel10
Session: [0x464A6DDC]
  IKE SA: local 10.72.206.50/500 remote 172.19.4.199/500 Active
          Capabilities:(none) connid:1391 lifetime:21:31:27
  Crypto Session Status: UP-ACTIVE
  fvrf: (none), Phase1_id: 172.19.4.199
  IPSEC FLOW: permit 47 host 10.72.206.50 host 172.19.4.199
        Active SAs: 2, origin: crypto map
        Inbound:  #pkts dec'ed 491241 drop 0 life (KB/Sec) 4080336/77488
        Outbound: #pkts enc'ed 473374 drop 190 life (KB/Sec) 4248170/77488
   Outbound SPI : 0x34D68081, transform : esp-3des esp-md5-hmac
    Socket State: Open
Interface: Tunnel20
Session: [0x464A6BFC]
  IKE SA: local 10.72.56.138/500 remote 10.72.56.2/500 Active
          Capabilities:(none) connid:1500 lifetime:23:58:18
  fvrf: (none), Phase1_id: 10.72.56.2
  IPSEC FLOW: permit 47 host 10.72.56.138 host 10.72.56.2
        Active SAs: 4, origin: crypto map
        Inbound:  #pkts dec'ed 0 drop 0 life (KB/Sec) 4385497/87
        Outbound: #pkts enc'ed 513 drop 10 life (KB/Sec) 4385495/87
   Outbound SPI : 0x15DC71A8, transform : esp-3des esp-md5-hmac
    Socket State: Open
Interface: Tunnel30
Session: [0x464A6CEC]
  IKE SA: local 172.33.3.30/500 remote 10.72.56.3/500 Active
          Capabilities:(none) connid:1499 lifetime:23:57:09
  fvrf: (none), Phase1_id: 10.72.56.3
  IPSEC FLOW: permit 47 host 172.33.3.30 host 10.72.56.3
        Inbound:  #pkts dec'ed 0 drop 0 life (KB/Sec) 4592562/96
        Outbound: #pkts enc'ed 1112 drop 11 life (KB/Sec) 4592561/96
   Outbound SPI : 0x91AE285F, transform : esp-3des esp-md5-hmac
    Socket State: Open
#sh crypto isakmp sa
IPv4 Crypto ISAKMP SA
dst             src             state          conn-id status
10.72.56.2      10.72.56.138    QM_IDLE           1501 ACTIVE
10.72.56.2      10.72.56.138    MM_NO_STATE       1500 ACTIVE (deleted)
10.72.56.3      172.33.3.30     QM_IDLE           1499 ACTIVE
172.19.4.199    10.72.206.50    QM_IDLE           1391 ACTIVE
sh crypto ipsec sa
interface: Tunnel10
    Crypto map tag: Tunnel10-head-0, local addr 10.72.206.50
   protected vrf: (none)
   local  ident (addr/mask/prot/port): (10.72.206.50/255.255.255.255/47/0)
   remote ident (addr/mask/prot/port): (172.19.4.199/255.255.255.255/47/0)
   current_peer 172.19.4.199 port 500
     PERMIT, flags={origin_is_acl,}
    #pkts encaps: 476355, #pkts encrypt: 476355, #pkts digest: 476355
    #pkts decaps: 494340, #pkts decrypt: 494340, #pkts verify: 494340
    #pkts compressed: 0, #pkts decompressed: 0
    #pkts not compressed: 0, #pkts compr. failed: 0
    #pkts not decompressed: 0, #pkts decompress failed: 0
    #send errors 190, #recv errors 0
     local crypto endpt.: 10.72.206.50, remote crypto endpt.: 172.19.4.199
     path mtu 1500, ip mtu 1500, ip mtu idb ATM0/1/0.1
     current outbound spi: 0x34D68081(886472833)
     PFS (Y/N): N, DH group: none
     inbound esp sas:
      spi: 0x9B52E0A7(2605899943)
        transform: esp-3des esp-md5-hmac ,
        in use settings ={Tunnel, }
        conn id: 3821, flow_id: NETGX:1821, sibling_flags 80000046, crypto map: Tunnel10-head-0
        sa timing: remaining key lifetime (k/sec): (4078769/77427)
        IV size: 8 bytes
        replay detection support: Y
        Status: ACTIVE
     inbound ah sas:
     inbound pcp sas:
     outbound esp sas:
        conn id: 3822, flow_id: NETGX:1822, sibling_flags 80000046, crypto map: Tunnel10-head-0
        sa timing: remaining key lifetime (k/sec): (4247287/77427)
        IV size: 8 bytes
        Status: ACTIVE
     outbound ah sas:
     outbound pcp sas:
interface: Tunnel30
    Crypto map tag: Tunnel30-head-0, local addr 172.33.3.30
   local  ident (addr/mask/prot/port): (172.33.3.30/255.255.255.255/47/0)
   remote ident (addr/mask/prot/port): (10.72.56.3/255.255.255.255/47/0)
   current_peer 10.72.56.3 port 500
    #pkts encaps: 1135, #pkts encrypt: 1135, #pkts digest: 1135
    #pkts decaps: 0, #pkts decrypt: 0, #pkts verify: 0
    #send errors 11, #recv errors 0
     local crypto endpt.: 172.33.3.30, remote crypto endpt.: 10.72.56.3
     path mtu 1500, ip mtu 1500, ip mtu idb FastEthernet0/1
     current outbound spi: 0x91AE285F(2444109919)
     inbound esp sas:
      spi: 0x52899E63(1384750691)
        conn id: 4391, flow_id: NETGX:2391, sibling_flags 80000046, crypto map: Tunnel30-head-0
        sa timing: remaining key lifetime (k/sec): (4592562/36)
        IV size: 8 bytes
        Status: ACTIVE
     inbound ah sas:
     inbound pcp sas:
     outbound esp sas:
        conn id: 4392, flow_id: NETGX:2392, sibling_flags 80000046, crypto map: Tunnel30-head-0
        sa timing: remaining key lifetime (k/sec): (4592557/36)
        IV size: 8 bytes
        Status: ACTIVE
     outbound ah sas:
     outbound pcp sas:
interface: Tunnel20
    Crypto map tag: Tunnel20-head-0, local addr 10.72.56.138
   local  ident (addr/mask/prot/port): (10.72.56.138/255.255.255.255/47/0)
   remote ident (addr/mask/prot/port): (10.72.56.2/255.255.255.255/47/0)
   current_peer 10.72.56.2 port 500
    #pkts encaps: 542, #pkts encrypt: 542, #pkts digest: 542
     local crypto endpt.: 10.72.56.138, remote crypto endpt.: 10.72.56.2
     path mtu 1514, ip mtu 1514, ip mtu idb Loopback0
     current outbound spi: 0xE85EB28B(3898520203)
     inbound esp sas:
      spi: 0x36A9A258(917086808)
        conn id: 4393, flow_id: NETGX:2393, sibling_flags 80000046, crypto map: Tunnel20-head-0
        sa timing: remaining key lifetime (k/sec): (4569494/52)
        IV size: 8 bytes
        Status: ACTIVE
     inbound ah sas:
     inbound pcp sas:
     outbound esp sas:
        conn id: 4394, flow_id: NETGX:2394, sibling_flags 80000046, crypto map: Tunnel20-head-0
        sa timing: remaining key lifetime (k/sec): (4569489/52)
        IV size: 8 bytes
        Status: ACTIVE
     outbound ah sas:
     outbound pcp sas:
461
