Dual DMVPN Dual Hub Request for Help?
                   Hello Anyone with DMVPN experience,
                    Can you please have a look at my DMVPN queries in the attached document?
                    Thank you
                    Phuc Le
1 ACCEPTED SOLUTION
Bronze
Hi Phuc Le,
I found for you a quite detailed design and implementation guide. Please read carefully and implement a test bed. I'm sure you will get support for specific issues if you run into problems.
http://www.cisco.com/en/US/docs/solutions/Enterprise/WAN_and_MAN/DMVPN_2_Phase2.html
These documents are carefully written and I never encountered any problems with such reference implementations.
Also: Please don't formulate your questions in an attached document, this makes it diffucult for us to give you answers.
Best regards, MiKa
Bronze
Just curious, are these questions from a test or some sort of homerwork? Why not try learningnetwork.cisco.com?
Hi M.Kafka,
It's not a test or homework.
I would like to make sure what correct commands to use to build a Dual Hub Dual Cloud - Spoke to Spoke Deploymet, because I have seen variations and not sure if they are typos (unintentional errors or not).
Can you or someone assist please.
Thank you
Phuc
Bronze
Hi Phuc Le,
Best regards, MiKa
Dear Mika,
Thank you so much for your time in finding me this document. It is very useful.
Happy new year
Phuc Le
291
