Community Member
Dual DMVPN - EIGRP Routing Problem
Hello Everyone,
I'm trying to set up an Dual DMVPN Topology with HSRP configured between the two Hub Routers.
HSRP  works fine. Concerning the VPN-Connection everything looks good too.  The Spoke Routers can connect to the Hub's LAN and the otherway around.  And the command "show crypto isakmp sa" shows two VPN-Connections (to  Hub A and Hub B)  on the Spoke Routers, but the output of "show ip  route" only has one dynamic learned entry for Hub A. The Spoke does not  learn a Route to Hub B and Hub B only learns a Route for the  Tunnel-Network of Hub A over the HSRP-LAN-Interface.
You guys got any suggestions on how to get this working ? :smileyvery-happy:
Greetings
Thomas
Spoke : show crypto isakmp sa
A_HS_01#sh cr is sa
IPv4 Crypto ISAKMP SA
dst             src             state          conn-id slot status
192.168.1.1     192.168.1.25    QM_IDLE           1002    0 ACTIVE
192.168.1.5     192.168.1.25    QM_IDLE           1081    0 ACTIVE
IPv6 Crypto ISAKMP SA
Spoke: show ip route
A_HS_01#sh ip route eigrp
     172.16.0.0/24 is subnetted, 2 subnets
D       172.16.1.0 [90/3072000] via 10.10.10.1, 00:46:33, Tunnel1
Spoke: config
interface Tunnel1
description *** HS_VPN_01 ***
bandwidth 1000
ip address 10.10.10.10 255.255.255.0
no ip redirects
ip mtu 1300
ip nhrp authentication test
ip nhrp map 10.10.10.1 192.168.1.1
ip nhrp map multicast 192.168.1.1
ip nhrp network-id 1
ip nhrp holdtime 300
ip nhrp nhs 10.10.10.1
ip nhrp cache non-authoritative
load-interval 30
delay 1000
keepalive 10 3
tunnel source FastEthernet0/1
tunnel mode gre multipoint
tunnel key 1
tunnel protection ipsec profile xxx
interface Tunnel2
description *** HS_VPN_02 ***
bandwidth 1000
ip address 10.10.11.10 255.255.255.0
no ip redirects
ip mtu 1300
ip nhrp map 10.10.11.1 192.168.1.5
ip nhrp map multicast 192.168.1.5
ip nhrp network-id 2
ip nhrp nhs 10.10.11.1
load-interval 30
delay 1050
keepalive 10 3
tunnel key 2
!interface FastEthernet0/0
description *** Kunden-LAN ***
ip address 172.16.10.1 255.255.255.0
no ip redirects
duplex auto
speed auto
interface FastEthernet0/1
description *** OUTSIDE (zum CoCo) ***
ip address 192.168.1.25 255.255.255.252
duplex auto
speed auto
router eigrp 1
network 10.10.10.0 0.0.0.255
network 10.0.0.0
network 172.16.10.0 0.0.0.255
no auto-summary
HUB A: show ip route eirp
HS_VPN_01#sh ip route eigrp
D       172.16.10.0 [90/2818560] via 10.10.10.10, 00:07:57, Tunnel1
     10.0.0.0/24 is subnetted, 2 subnets
D       10.10.11.0 [90/3072000] via 172.16.1.3, 00:52:56, FastEthernet0/0
Hub A: config
interface Tunnel1
description *** Netz HS ***
bandwidth 1000
ip address 10.10.10.1 255.255.255.0
no ip redirects
ip mtu 1300
no ip next-hop-self eigrp 1
ip nhrp map multicast dynamic
no ip split-horizon eigrp 1
load-interval 30
delay 1000
keepalive 10 3
tunnel key 1
ip address 172.16.1.2 255.255.255.0
no ip redirects
delay 1000
duplex auto
speed auto
standby 1 ip 172.16.1.254
standby 1 priority 20
standby 1 preempt
standby 1 name LAN
standby 1 track FastEthernet0/1
ip address 192.168.1.1 255.255.255.252
duplex auto
speed auto
router eigrp 1
network 172.16.1.0 0.0.0.255
no auto-summary
Hub B: sh ip route eigrp
HS_VPN_02#sh ip route eigrp
D       172.16.10.0 [90/3087360] via 172.16.1.2, 00:10:49, FastEthernet0/0
D       10.10.10.0 [90/3084800] via 172.16.1.2, 01:41:56, FastEthernet0/0
Hub B: config
interface Tunnel1
bandwidth 1000
ip address 10.10.11.1 255.255.255.0
no ip redirects
ip mtu 1300
load-interval 30
delay 1000
keepalive 10 3
tunnel key 2
tunnel protection ipsec profile HeinrichSchmidt
ip address 172.16.1.3 255.255.255.0
no ip redirects
delay 1050
duplex auto
speed auto
standby 1 priority 19
standby 1 preempt
standby 1 name LAN
ip address 192.168.1.5 255.255.255.252
duplex auto
speed auto
router eigrp 1
network 10.10.11.0 0.0.0.255
no auto-summary
Re: Dual DMVPN - EIGRP Routing Problem
Thomas,
First of all, tunnel protection and tunnel keepalives do no mix. I'm not aware of any chnages in this behavior unless it changed very recently.
Regarding meritum, does the spoke see neighbors via both tunnel interfaces. I'd check also eigro topo:
- show ip eigrp neigh
- sh ip eigrp topology 172.16.0.0/24
Hope that helps, you might get a better/faster response to this in routing forums on CSC :-)
Marcin
Community Member
Hey Marcin,
thanks for your reply and the hint with the tunnel keepalives, I did not know this, since I am still a trainee as an ict-specialist and oriantated oneself on exicsting configurations when I did this :-P
unfortunatly I only see one eigrp neighbor on the spoke throug Tunnel Interface 1:
A_HS_01#sh ip eigrp neigh
IP-EIGRP neighbors for process 1
H   Address                 Interface       Hold Uptime   SRTT   RTO  Q  Seq
                                            (sec)         (ms)       Cnt Num
0   10.10.10.1              Tu1               10 00:35:35    1   200  0  22
I hope you did mean "sh ip eigrp topology" for the network 172.16.1.0 /24 because for 172.16.0.0 /24 I only get the message "% IP-EIGRP (AS 1): Route not in topology table"
A_HS_01#sh ip eigrp topology 172.16.1.0 255.255.255.0
IP-EIGRP (AS 1): Topology entry for 172.16.1.0/24
  State is Passive, Query origin flag is 1, 1 Successor(s), FD is 3072000
  Routing Descriptor Blocks:
  10.10.10.1 (Tunnel1), from 10.10.10.1, Send flag is 0x0
      Composite metric is (3072000/281600), Route is Internal
      Vector metric:
        Minimum bandwidth is 1000 Kbit
        Total delay is 20000 microseconds
        Reliability is 255/255
        Load is 1/255
        Minimum MTU is 1300
        Hop count is 1
Your idea with the routing forums sounds good to me :-) is there a way to move this post to that forum or do i need to write a new one ?
Greetings.
Thomas
Thomas,
I think only moderators can move a thread around, I'm not one.
But it seems it might be too early to move the thread to routing.
An adjacancy should be formed via both tunnels.
I see another possible configuration problem.
You're using same tunnel source interface and same ipsec profile "xxx" you are missing a "shared" keyword on it.
Once you have this in, can you please check (after shut/no shut on tunnel interfaces just in case)
On hub and spokes.
"show crypto isa sa"
"show crypto ipsec sa | i ident|caps|spi"
"show ip nhrp detail"
Marcin
Community Member
Marcin,
you are talking about the source interface on the spoke ? unfortunatly it has to be the same interface, because we are using cisco 1841 with only two interfaces, one for LAN and one for WAN, or is it possible to create subinterfaces? if it will be nessasary to do so? how will I do it, as there is only one LAN-Networkaddresspace and I think the subinterfaces will have an address conflict then :-(?
Further its not realy clear to me what you mean with a shared keyword in the ipsec profile. In the profile itself I only can set the following things.
identity
isakmp-profile
pfs
security-association
transform-set
Regards, Thomas
edit:
I now created two seperate ipsec profiles for each tunnel but still no success...
Thomas,
Regarding shared keyword :-)
BB_966(config)#int tu 0
BB_966(config-if)#tunnel protection ipsec profile BOGUS ?
  shared  Use a shared socket for the crypto connection.
A bit more about this you can find here:
http://www.cisco.com/en/US/docs/ios/sec_secure_connectivity/configuration/guide/share_ipsec_w_tun_protect_ps6441_TSD_Products_Configuration_Guide_Chapter.html#wp1047623
I don't think you need ot create subinterfaces. Shared keyword should be enough.
That being said, I don't even know if we have IPsec and NHRP up, that's why I asked for additional outputs in my previous post.
Marcin
1358
