Flow between VPN Client and Site-to-Site VPN
Looking for an ASA 8.0 sample configuration for enabling traffic flow between a Cisco VPN remote access client and destination host connected via LAN/Site-to-Site tunnel.  Both remote access client and site-to-site tunnel terminate on the same ASA device.
Thanks in advance.
-Rey
1 ACCEPTED SOLUTION
Re: Flow between VPN Client and Site-to-Site VPN
Hello Rey,
Here is a config example for what you are looking for.
http://www.cisco.com/en/US/products/hw/vpndevc/ps2030/products_configuration_example09186a008046f307.shtml
Hope this helps.
P.S: This uses TACACS+ for authentication which you can substitute with your method of authentication.
Prapanch
As long as both VPN sessions are working, you can try the configuration below:
access-list nonat permit ip
nat (inside) 0 access-list nonat
http://www.cisco.com/en/US/products/hw/vpndevc/ps2030/products_configuration_example09186a00804675ac.shtml
Hope this helps.
NT
Message was edited by: Nagaraja Thanthry
Thanks!
Hello Rey,
Hope this helps.
Prapanch
Thanks!  This is my answer!
240
