Group lock does not work ?
Hello
Could you please help me.
i tested group lock feature againts cisco acs.
in my tests i had three groups that were configured in concentrator
group 1 with rights 1. (in concentrator configuration, ipsec-section, the group lock (GL) was first on and then off) user uses this group for group authentication.
group 2 witch rights 2 (in concentrator configuration, ipsec-section, the group lock ( GL) was off
group 3 with rights 3 (in concentrator configuration, ipsec-section, the group lock ( GL ) was on
Acs returned the new group to the concentrator via parameter class 25
now i am asking if the following is the default behaviour: If either of the group has group lock off, the group can be changed. In another words i thought that the group-authentication group(name) and group(name) provided by ACS must both be configured as group lock off, or else the group cannot be changed.
Test1
group 1 with GL on --> change to Group2 with GL off --> succeeded group change ??? wrong behaviour ?
test2
group 1 with GL on --> change to Group3 with GL on --> No group change--> OK
test3
Group 1 with GL off --> change to Group2 with GL off --> succeeded group change OK
test4
Group 2 with GL off --> change to Group3 with GL on --> succeeded group change ??? wrong behaviour ?
Any help will be appreciated
TIA
Best Regards,
Susanna
121
