Guide for configuring an ASA for two factor auth
I've searched CSC as best as I can so I appologize if this is a duplicate topic.  I have an ASA5505 v8.4(1), ASDM version 6.4(1).  According to the release notes you can setup two factor authentication in these later versions of ASA code.  What I can't find is any guide that tells you what the steps are to actually set it up.  We're testing RSA's SecureID for PCI compliance.  If anyopne has a link to a document that gives some insight into this I'd appreciate it.
David
Everyone's tags (1)
1 REPLY
David,
Two factor requires no additional configuration, i.e. you have one password based on two parts.
The ASA just works as a relay, it forwards the username/pass to AAA server which validates if it's OK (in a typical scenario).
Now double authentication is something that might need a bit more config - i.e. you have to provide two passwords for two different machanisms.
Marcin.
421
