Help with DMVPN
Hi All,
I'm trying to configure DMVPN, I believe the tunnel is established ok as the VPN lights are on at both routers and I am able to ping from the router the tunnell address of the other router, however i am not able to ping the LAN address of the adjacent router.
I understand it may be to do with the routing protocol (i'm using RIP) but i have enabled it on both routers and set the other router as a neibour using the tunnel IP address
Router 1        Router 2
LAN 192.168.0.254 /24                                                          10.9.9.254 /24
                   Tunnel0
10.8.8.254        10.8.8.1
any help would be greatly appreciated
thanks
Help with DMVPN
Hi Darren,
Is that site to site, or you have hub and spokes? Can you post the config on both ends?
HTH,
Lei Tian
Help with DMVPN
Hi Lei, thanks for responding.
It's a hub and spoke, configs below
HUB
Building configuration...
Current configuration : 4626 bytes
! Last configuration change at 07:21:03 UTC Fri Aug 16 2013
version 15.2
no service pad
hostname BH-S
boot-start-marker
boot-end-marker
no logging console
enable secret 5 *******************
enable password ***************
no aaa new-model
no process cpu extended history
no process cpu autoprofile hog
memory-size iomem 10
crypto pki trustpoint TP-self-signed-*************
enrollment selfsigned
subject-name cn=IOS-Self-Signed-Certificate-**********
revocation-check none
rsakeypair TP-self-signed-*************
crypto pki certificate chain TP-self-signed-*******************
certificate self-signed 01
        quit
ip cef
no ipv6 cef
vpdn enable
vpdn-group pppoe
license udi pid *******************
controller VDSL 0
csdb tcp synwait-time 30
csdb tcp idle-time 3600
csdb tcp finwait-time 5
csdb tcp reassembly max-memory 1024
csdb tcp reassembly max-queue-length 16
csdb udp idle-time 30
csdb icmp idle-time 10
csdb session max-session 65535
crypto isakmp policy 10
hash md5
authentication pre-share
crypto isakmp key ********** address 0.0.0.0
crypto ipsec transform-set strong esp-3des esp-md5-hmac
mode tunnel
crypto ipsec profile SP
crypto ipsec profile SaferPlaces
set security-association lifetime seconds 900
set transform-set strong
interface Tunnel0
ip address 10.8.8.254 255.255.255.0
no ip redirects
ip mtu 1440
ip nhrp authentication SP1
ip nhrp map multicast dynamic
ip nhrp network-id 1
no ip split-horizon
tunnel source Dialer0
tunnel mode gre multipoint
tunnel key 0
tunnel protection ipsec profile SP
interface Ethernet0
no ip address
ip nat inside
ip virtual-reassembly in
ip tcp adjust-mss 1452
interface Ethernet0.101
encapsulation dot1Q 101
pppoe enable group global
pppoe-client dial-pool-number 1
interface ATM0
no ip address
no atm ilmi-keepalive
interface FastEthernet0
no ip address
shutdown
no cdp enable
interface FastEthernet1
no ip address
shutdown
no cdp enable
interface FastEthernet2
no ip address
shutdown
no cdp enable
interface FastEthernet3
no ip address
no cdp enable
interface Vlan1
ip address 192.168.0.254 255.255.255.0
ip nat inside
interface Dialer0
mtu 1492
ip address negotiated
ip nat outside
encapsulation ppp
dialer pool 1
dialer-group 1
ppp authentication chap callin
ppp chap hostname ***************
ppp chap password 0 ****************
ppp pap sent-username *************** password 0 **************
ppp ipcp dns request
ppp ipcp route default
router rip
network 192.168.0.0
neighbor 10.8.8.1
ip forward-protocol nd
ip http server
ip http secure-server
ip nat inside source list 2 interface Dialer0 overload
ip route 0.0.0.0 0.0.0.0 Dialer0
ip route 10.9.9.0 255.255.255.0 10.8.8.1
ip route 10.9.9.0 255.255.255.0 Tunnel0
access-list 2 permit 192.168.0.0 0.0.0.255
snmp-server community public RO
line con 0
exec-timeout 0 0
no modem enable
line aux 0
line vty 0 4
login
transport input all
end
SPOKE
Current configuration : 4117 bytes
! Last configuration change at 07:44:57 UTC Fri Aug 16 2013
version 15.3
no service pad
hostname BH-A
boot-start-marker
boot-end-marker
no logging buffered
no aaa new-model
        quit
ip cef
no ipv6 cef
vpdn enable
vpdn-group pppoe
controller VDSL 0
hash md5
crypto isakmp key ***************** address 0.0.0.0
mode tunnel
interface Tunnel0
ip address 10.8.8.1 255.255.255.0
no ip redirects
ip mtu 1440
ip nhrp map 10.8.8.254 82.69.75.27
ip nhrp map multicast 82.69.75.27
ip nhrp nhs 10.8.8.254
no ip split-horizon
tunnel key 0
tunnel protection ipsec profile SaferPlaces
interface Ethernet0
no ip address
ip nat inside
pppoe enable
interface ATM0
no ip address
shutdown
no ip address
shutdown
no ip address
shutdown
no ip address
shutdown
no ip address
interface Vlan1
ip address 10.9.9.254 255.255.255.0
ip nat inside
interface Dialer0
mtu 1470
ip nat outside
encapsulation ppp
dialer pool 1
dialer-group 1
router rip
network 10.0.0.0
neighbor 10.8.8.254
ip http server
ip nat inside source list 1 interface Dialer0 overload
ip route 192.168.0.0 255.255.255.0 Tunnel0
access-list 1 permit 10.9.9.0 0.0.0.255
line con 0
no modem enable
line aux 0
line vty 0 4
password *******************
login
transport input all
end
Help with DMVPN
If you're using RIP between sites, why do you need this static routes?
Spoke:
HUB:
Delete those routes and add network statemens for the tunnel subnet in the RIP.
Help with DMVPN
hey, RIP wasn't working so i added the static routes instead whilst troubleshooting. Can you give me an example of the network statement for RIP? Thanks
Help with DMVPN
I've made some progress with this but its still not complete, I have RIP working  at least in one direction. It seems the spoke doesn't have the local VLAN subnet (10.9.9.0/24) . in its routing table? But now has a RIP entry for the VLAN subnet of the hub which pings ok.
S*    0.0.0.0/0 [1/0] via 62.3.83.27
                is directly connected, Dialer0
      10.0.0.0/8 is variably subnetted, 2 subnets, 2 masks
C        10.8.8.0/24 is directly connected, Tunnel0
L        10.8.8.1/32 is directly connected, Tunnel0
      ISP IP is subnetted, 1 subnets
C       ISP IP is directly connected, Dialer0
      public subnet is subnetted, 1 subnets
C        public IP is directly connected, Dialer0
R     192.168.0.0/24 [120/1] via 10.8.8.254, 00:00:15, Tunnel0
Any advice is greatly appreciated.
Latest running configs
HUB
Current configuration : 4525 bytes
version 15.2
no service pad
hostname BH-SiteLink
boot-start-marker
boot-end-marker
no logging console
no aaa new-model
        quit
ip cef
no ipv6 cef
vpdn enable
vpdn-group pppoe
controller VDSL 0
hash md5
crypto isakmp key ************* address 0.0.0.0
mode tunnel
crypto ipsec profile ************
interface Tunnel0
no ip redirects
ip mtu 1440
no ip split-horizon
tunnel key 0
interface Ethernet0
no ip address
ip nat inside
interface ATM0
no ip address
no ip address
shutdown
no cdp enable
no ip address
shutdown
no cdp enable
no ip address
shutdown
no cdp enable
no ip address
no cdp enable
interface Vlan1
ip nat inside
interface Dialer0
mtu 1470
ip nat outside
encapsulation ppp
dialer pool 1
dialer-group 1
ppp pap sent-username ************ password 0 **************
router rip
network 10.0.0.0
network 192.168.0.0
ip http server
ip route 192.168.0.0 255.255.255.0 Vlan1
access-list 1 remark CCP_ACL Category=16
access-list 1 permit 192.168.0.0 0.0.0.255
access-list 2 remark CCP_ACL Category=2
line con 0
exec-timeout 0 0
no modem enable
line aux 0
line vty 0 4
login
transport input all
end
SPOKE
Current configuration : 4104 bytes
! Last configuration change at 07:25:19 UTC Thu Aug 22 2013
version 15.3
no service pad
hostname BH-ArrayLinks
boot-start-marker
boot-end-marker
no logging buffered
no aaa new-model
subject-name cn=IOS-Self-Signed-Certificate-*****************
rsakeypair TP-self-signed-3608216806
        quit
ip cef
no ipv6 cef
vpdn enable
vpdn-group pppoe
license udi pid***************
controller VDSL 0
hash md5
crypto isakmp key **************** address 0.0.0.0
mode tunnel
crypto ipsec profile **************
interface Tunnel0
no ip redirects
ip mtu 1440
ip nhrp map 10.8.8.254 HUB IP
ip nhrp map multicast HUB IP
no ip split-horizon
tunnel key 0
interface Ethernet0
no ip address
ip nat inside
interface ATM0
no ip address
shutdown
no ip address
shutdown
no ip address
shutdown
no ip address
shutdown
no ip address
interface Vlan1
ip nat inside
interface Dialer0
mtu 1470
ip nat outside
encapsulation ppp
dialer pool 1
dialer-group 1
ppp chap hostname ****************
router rip
network 10.0.0.0
ip http server
ip route 10.9.9.0 255.255.255.0 Vlan1
line con 0
no modem enable
line aux 0
line vty 0 4
login
transport input all
end
319
