help with l2tpv3
I'm trying to setup l2tpv3 with the information on this page.
http://www.networkworld.com/community/node/26272.
When I assign an IP to both fasteth interfaces, I get this error when I assign xconnect to them. "Incompatible with ip address command on fasteth2/0"
If I make both interfaces with unassigned IP's, I do not get the error, but the tunnel is not up.
When configuring l2tpv3, do the interfaces need an IP? I understand  you need to setup a loopback, which I did.
Re: help with l2tpv3
Ok it looks like I got the tunnel up from help on this page.
http://blog.ipexpert.com/2009/08/31/l2tpv3-dynamic-and-manual-sessions/
But i'm still confused on if you're supposed to assign the interfaces IP addresses or not. I can't ping across the tunnel
show l2tun session all
%No active L2F tunnels
L2TP Session Information Total tunnels 1 sessions 1
Session id 38724 is down, tunnel id 21774
Call serial number is 0
Remote tunnel name is
  Internet address is 192.168.1.2
  Session is L2TP signalled
  Session state is wait-for-tunnel, time since change 00:00:00
    0 Packets sent, 0 received
    0 Bytes sent, 0 received
  Last clearing of "show vpdn" counters never
    Receive packets dropped:
      out-of-order:             0
      total:                    0
    Send packets dropped:
      exceeded session MTU:     0
      total:                    0
  Session vcid is 100
  Session Layer 2 circuit, type is Ethernet, name is FastEthernet0/0
  Circuit state is UP
    Remote session id is 0, remote tunnel id 0
  DF bit off, ToS reflect disabled, ToS value 0, TTL value 255
  No session cookie information available
  UDP checksums are disabled
  SSS switching enabled
  No FS cached header information available
  Sequencing is off
  Unique ID is 2
%No active PPTP tunnels
377
