Help with site-to-site VPN - need to route smoe traffic to internet
I have configured a site-to-site VPN over a DSL as a remote location to our corp ASA.  It all seems to be working and the DSL site can access the many subnets we have, however we have a requirement where we need some hard coded devices on the DSL to get to a web site as 80.171.156.78 which is off our corp ASA and I want it to go over the Internet rather that through the VPN as I'd have to do something with NAT to allow this public to be accessible 'internally' through the VPN.
See these handheld devices are hardcoded to get to 80.171.156.78 so they can use their 3G or home wifi to get there, now we have a VPN and have installed wifi, so they connect and try and get to 80.171.156.60 through the VPN, so I wanted to see if I can do some split tunneling?
version 12.4
no service pad
hostname ciscodsl
boot-start-marker
boot-end-marker
logging message-counter syslog
no aaa new-model
dot11 syslog
ip source-route
no ip dhcp use vrf connected
ip dhcp pool my-Pool
   network 192.168.200.0 255.255.255.0
   default-router 192.168.200.1
   dns-server 192.168.21.10 192.168.21.11
ip cef
ip domain name AW
ip name-server 4.2.2.2
no ipv6 cef
crypto isakmp policy 100
encr *
authentication pre-share
crypto isakmp key **** address 80.171.156.*
crypto ipsec security-association lifetime seconds 1800
crypto ipsec transform-set AW-TSET *
crypto map AWCCNP 321 ipsec-isakmp
set peer 80.171.156.*
set transform-set AW-TSET
set pfs *
match address 123
archive
log config
  hidekeys
interface ATM0
no ip address
no atm ilmi-keepalive
pvc 0/38
  encapsulation aal5mux ppp dialer
  dialer pool-member 1
interface FastEthernet0
spanning-tree portfast
interface FastEthernet1
interface FastEthernet2
interface FastEthernet3
interface Vlan1
ip address 192.168.200.1 255.255.255.0
ip virtual-reassembly
interface Vlan11
ip address 11.11.11.1 255.255.255.0
interface Dialer1
ip address negotiated
ip access-group inbound in
encapsulation ppp
dialer pool 1
dialer-group 1
ppp authentication chap pap callin
ppp chap hostname *
ppp chap password 0 *
ppp pap sent-username *
ppp ipcp dns request
crypto map AWCCNP
ip forward-protocol nd
ip route 0.0.0.0 0.0.0.0 Dialer1
no ip http server
no ip http secure-server
ip access-list extended inbound
permit ahp host 80.171.156.60 any log
permit esp host 80.171.156.60 any log
permit udp host 80.171.156.60 any eq isakmp log
permit udp host 80.171.156.60 any eq non500-isakmp log
deny   icmp any any timestamp-request log
deny   icmp any any timestamp-reply log
permit icmp any any log
permit udp host 158.43.128.33 any eq ntp log
permit tcp host 80.171.156.60 any eq telnet log
permit tcp host 80.171.156.60 any eq 22 log
permit tcp host 80.171.156.60 any eq ftp-data log
permit tcp host 80.171.156.60 any eq ftp log
permit tcp host 80.171.156.60 any eq www log
permit tcp host 80.171.156.60 any eq 443 log
deny   ip any any log
access-list 23 permit 80.171.156.60
access-list 123 permit ip 192.168.200.0 0.0.0.255 any log
control-plane
line con 0
logging synchronous
no modem enable
line aux 0
line vty 0 4
access-class 23 in
logging synchronous
login local
transport input ssh
scheduler max-task-time 5000
end
119
