Community Member
How do I apply an ACL to a LAN-to-LAN tunnel?
I have an ASA with a active IPSec LAN-to-LAN tunnel and I'm wanting to limit what ports and IPs my extranet partner is able to reach. How do I apply an ACL to a LAN-to-LAN tunnel to limit ingress and egress traffic through the tunnel?
Thanks in advance!
2 ACCEPTED SOLUTIONS
Re: How do I apply an ACL to a LAN-to-LAN tunnel?
It will work similarly. You need to use VPN filters. If you are using 8.0, then you can use the following doc:
http://www.cisco.com/en/US/products/hw/vpndevc/ps2030/products_configuration_example09186a00808c9a87.shtml
Hall of Fame Super Blue
Community Member
Thanks for the link but I am trying to limit access in regards to a LAN-to-LAN tunnel and not remote access. Any more thoughts?
Thanks in advance!
Community Member
Thanks a lot guys, that was the info I needed! :-)
145
