How to disable LAN-LAN tunnel using CLI on vpn 3030
I know there is a option that you can check to disable the LAN-LAN tunnel in the Browser when configuring the VPN concentrator 3030. But is this option availiable in the CLI or menu driven on the VPN concentrator. I want to connect to the box and turn off "LAN-LAN tunnel connection" using CLI instead of using the browser.
1 REPLY
Re: How to disable LAN-LAN tunnel using CLI on vpn 3030
I am not sure if this can be done
167
