Hub and Spoke with only 1 spoke working?
Hi, running a PIX515E hub (6.3(1)) with ASA 5505 spokes (7.2(3)). I'm attaching the configs. I've been using http://www.cisco.com/en/US/customer/products/hw/vpndevc/ps2030/products_configuration_example09186a0080093bd3.shtml
to configure the hub for the second spoke (the first spoke is up and working). I thought I could just replicate what i'm doing on spoke 1 and add the Lan address to the existing NoNat ACL and add a new one for the new cryptomap, but when i try to initiate it from the hub side I get "IPSEC(sa_initiate): ACL = deny; no sa created" yet when i do a Sho ACL for 102 and NoNAT they have hits (yes they increment when i attempt to connect).
ideas?
1 ACCEPTED SOLUTION
Re: Hub and Spoke with only 1 spoke working?
I did see that - and could you try:-
clear xlate
at the command line please?
and if possible - a reload on the pix?
The config's look OK - you say the no-nat and the crypto acl's are being hit, do you see packets encap/decap - encryp/decryp when you input the command:-
show crypto ipsec sa peer 216.124.91.221
from the hub pix?
Herein lies my problem. If I do a sho crypto ipsec sa command (my version doesn't understand the peer option). All i see is spoke1 there is no SA for spoke2. Hence the message "IPSEC(sa_initiate): ACL = deny; no sa created".
OK
Looking at your config again (closer this time) I see:-
static (outside,inside) 10.11.16.0 10.11.16.0 netmask 255.255.255.0 0 0
You should not need this - as you have defined a no-nat, remove the above and test again please?
Yeah, this doesn't change anything unfortunately. As you can see on the Hub, it's also there for Spoke1 and i have no problems with it.
clear xlate
I tried a simple reload of the Hub last night and that seems to have made it happy. Thanks for your help :)
Sadly - sometimes a reload fixes all!
Good to know your issue is resolved.
132
