ISAKMP Phase 1 dying for Site to Site tunnel between ASA and Fortigate
      I am facing strange issue on my asa and client Fortigate fw.
We have site to site tunnel with 3des and sha and DH-5 on asa
3des  sha1 and dh-5 on Fortigate.
Tunnel came up when configured after some time it went down and it is throwing below errors. Please
some one help me here.
Jul 24 17:25:13 [IKEv1 DEBUG]: IP = X.X.X.X, IKE SA Proposal # 1, Transform # 1 acceptable  Matches global IKE entry # 8
Jul 24 17:25:13 [IKEv1 DEBUG]: IP = X.X.X.X, constructing ISAKMP SA payload
Jul 24 17:25:13 [IKEv1 DEBUG]: IP = X.X.X.X, constructing Fragmentation VID + extended capabilities payload
Jul 24 17:25:13 [IKEv1]: IP = X.X.X.X, IKE_DECODE SENDING Message (msgid=0) with payloads : HDR + SA (1) + VENDOR (13) + NONE (0) total length : 104
Jul 24 17:25:13 [IKEv1]: IP = X.X.X.X, IKE_DECODE RECEIVED Message (msgid=0) with payloads : HDR + KE (4) + NONCE (10) + NONE (0) total length : 244
Jul 24 17:25:13 [IKEv1 DEBUG]: IP = X.X.X.X, processing ke payload
Jul 24 17:25:13 [IKEv1 DEBUG]: IP = X.X.X.X, processing ISA_KE payload
Jul 24 17:25:13 [IKEv1 DEBUG]: IP = X.X.X.X, processing nonce payload
Jul 24 17:25:13 [IKEv1]: IP = X.X.X.X, Unable to compute DH pair while processing SA!<<<<---------Please suggest if DH group 5 does not work with PSK.
Jul 24 17:25:13 [IKEv1 DEBUG]: IP = X.X.X.X, IKE MM Responder FSM error history (struct &0xcf9255d8)  <state>, <event>:  MM_DONE, EV_ERROR-->MM_BLD_MSG4, EV_GEN_DH_KEY-->MM_WAIT_MSG3, EV_PROCESS_MSG-->MM_WAIT_MSG3, EV_RCV_MSG-->MM_WAIT_MSG3, NullEvent-->MM_SND_MSG2, EV_SND_MSG-->MM_SND_MSG2, EV_START_TMR-->MM_BLD_MSG2, EV_BLD_MSG2
Jul 24 17:25:13 [IKEv1 DEBUG]: IP = X.X.X.X, IKE SA MM:5f1fdffc terminating:  flags 0x01000002, refcnt 0, tuncnt 0
Jul 24 17:25:13 [IKEv1 DEBUG]: IP = X.X.X.X, sending delete/delete with reason message
Mum-PRI-ASA#
Issue was solved by shifting to DH group 2 instead of 5. May be asa was not able to compute it.
Hey All,
I experienced same issue with my another tunnel. Lately I came to know it was higher level of DH computation which my ASA was not able to perform and ASA reboot worked here. See the logs for tunnel which came up after reboot.
Eror Before Reload
Aug 06 21:17:33 [IKEv1 DEBUG]: IP = xx.xx.xx.xx, constructing ISAKMP SA payload
Aug 06 21:17:33 [IKEv1 DEBUG]: IP = xx.xx.xx.xx, constructing Fragmentation VID + extended capabilities payload
Aug 06 21:17:33 [IKEv1]: IP = xx.xx.xx.xx, IKE_DECODE SENDING Message (msgid=0) with payloads : HDR + SA (1) + VENDOR (13) + NONE (0) total length : 416
Aug 06 21:17:33 [IKEv1]: IP = xx.xx.xx.xx, IKE_DECODE RECEIVED Message (msgid=0) with payloads : HDR + SA (1) + VENDOR (13) + NONE (0) total length : 108
Aug 06 21:17:33 [IKEv1 DEBUG]: IP = xx.xx.xx.xx, processing SA payload
Aug 06 21:17:33 [IKEv1]: Phase 1 failure:  Mismatched attribute types for class Group Description:  Rcv'd: Group 5  Cfg'd: Group 2
Aug 06 21:17:33 [IKEv1 DEBUG]: IP = xx.xx.xx.xx, Oakley proposal is acceptable
Aug 06 21:17:33 [IKEv1 DEBUG]: IP = xx.xx.xx.xx, processing VID payload
Aug 06 21:17:33 [IKEv1 DEBUG]: IP = xx.xx.xx.xx, Received Fragmentation VID
Aug 06 21:17:33 [IKEv1 DEBUG]: IP = xx.xx.xx.xx, IKE Peer included IKE fragmentation capability flags:  Main Mode:        True  Aggressive Mode:  True
Aug 06 21:17:33 [IKEv1]: IP = xx.xx.xx.xx, Unable to compute DH pair while processing SA!
Aug 06 21:17:33 [IKEv1 DEBUG]: IP = xx.xx.xx.xx, IKE MM Initiator FSM error history (struct &0xd0778588)  , :  MM_DONE, EV_ERROR-->MM_BLD_MSG3, EV_GEN_DH_KEY-->MM_WAIT_MSG2, EV_PROCESS_MSG-->MM_WAIT_MSG2, EV_RCV_MSG-->MM_WAIT_MSG2, NullEvent-->MM_SND_MSG1, EV_SND_MSG-->MM_SND_MSG1, EV_START_TMR-->MM_BLD_MSG1, EV_BLD_MSG1
Aug 06 21:17:33 [IKEv1 DEBUG]: IP = xx.xx.xx.xx, IKE SA MM:64cf4b96 terminating:  flags 0x01000022, refcnt 0, tuncnt 0
Aug 06 21:17:33 [IKEv1 DEBUG]: IP = xx.xx.xx.xx, sending delete/delete with reason message
Isakmp phase completion After reload
Aug 25 10:40:35 [IKEv1]: IP = xx.xx.xx.xx, IKE_DECODE RECEIVED Message (msgid=0) with payloads : HDR + SA (1) + VENDOR (13) + NONE (0) total length : 108
Aug 25 10:40:35 [IKEv1 DEBUG]: IP = xx.xx.xx.xx, processing SA payload
Aug 25 10:40:35 [IKEv1]: Phase 1 failure:  Mismatched attribute types for class Group Description:  Rcv'd: Group 5  Cfg'd: Group 2
Aug 25 10:40:35 [IKEv1 DEBUG]: IP = xx.xx.xx.xx, Oakley proposal is acceptable
Aug 25 10:40:35 [IKEv1 DEBUG]: IP = xx.xx.xx.xx, processing VID payload
Aug 25 10:40:35 [IKEv1 DEBUG]: IP = xx.xx.xx.xx, Received Fragmentation VID
Aug 25 10:40:35 [IKEv1 DEBUG]: IP = xx.xx.xx.xx, IKE Peer included IKE fragmentation capability flags:  Main Mode:        True  Aggressive Mode:  True
Aug 25 10:40:35 [IKEv1 DEBUG]: IP = xx.xx.xx.xx, constructing ke payload
Aug 25 10:40:35 [IKEv1 DEBUG]: IP = xx.xx.xx.xx, constructing nonce payload
Aug 25 10:40:35 [IKEv1 DEBUG]: IP = xx.xx.xx.xx, constructing Cisco Unity VID payload
Aug 25 10:40:35 [IKEv1 DEBUG]: IP = xx.xx.xx.xx, constructing xauth V6 VID payload
Aug 25 10:40:35 [IKEv1 DEBUG]: IP = xx.xx.xx.xx, Send IOS VID
Aug 25 10:40:35 [IKEv1 DEBUG]: IP = xx.xx.xx.xx, Constructing ASA spoofing IOS Vendor ID payload (version: 1.0.0, capabilities: 20000001)
Aug 25 10:40:35 [IKEv1 DEBUG]: IP = xx.xx.xx.xx, constructing VID payload
Aug 25 10:40:35 [IKEv1 DEBUG]: IP = xx.xx.xx.xx, Send Altiga/Cisco VPN3000/Cisco ASA GW VID
Aug 25 10:40:35 [IKEv1]: IP = xx.xx.xx.xx, IKE_DECODE SENDING Message (msgid=0) with payloads : HDR + KE (4) + NONCE (10) + VENDOR (13) + VENDOR (13) + VENDOR (13) + VENDOR (13) + NONE (0) total length : 320
SENDING PACKET to xx.xx.xx.xx
Hi Gagandeep,
From the debug logs attached, I see following in both cases:
Debug is complaining about mismatch in DH-group.
Could you please show me all the isakmp policies configured on ASA? whats the ASA code running?
Santhosh
Matching  ISAKMP policies were configured on both devices as my ASA was trying to compute DH pair.Issue was with DH pair computation which worked after reboot.
you are right about below logs:
but for phase 1, DH group 5 was also there but log is not showing match debug event.
3952
